View Full Version : Technical help Q & A
- Bumper distortion
- Thermostat problems on the horizon
- Courier 1.8 td Drain Fuel Tank How To?
- Head scratcher
- Focus ST 225 central locking issue
- Zetec turbo, turbo help which one??
- MK4 Escort alternator identification please...
- Mk1 focus 1.8 tdci diesel obd2?
- Oil Cooling
- Transit connect over revving
- Sportka ABS
- MK6 Fiesta no spark
- Fiesta Zetec S Radio Code Wanted
- Ford Escort MK2 VAN wings
- mk1 focus 1.6 starter removal
- cosworth throttle body differences
- few issues on my saph cossie
- Sierra brake upgrade???
- Mondeo Clutch Problem
- Diesel bleed.
- 1.8 TDCi head gasket or worse ?
- focus 16ti-VCT question
- St170 project
- Mondeo ST220 brake upgrade Focus ST225
- CVH Trigger wheel & CPS
- Ford Focus Mk2 Central locking
- Ford Focus St 2006 Central Locking Issue. Please Help
- Help please
- Mondeo heated seat NOT elements
- zvh 1.8 turbo what head gasket do i need
- Escort mk4 battery light/alternator question
- Mk4 puma conversion
- XR3i 1.6 cvh help Mixture settings ??
- Compbrake adjustable top mounts ?
- Ford KA Heating Matrix
- Chassis Number of Escort MK1 Questions
- Cossy yb rotation
- XR3i Turbo Zvh conversion trouble any ideas ?
- Escort 1990 XR3i Running Issues Plz Help
- Escort 1990 XR3i Running Issues Plz Help help
- MAP sensor location help!
- Matt lewis cosworth fan loom
- Transit mk7 starts first time but won't run
- Rs turbo badly misfiring and wont idle
- 3 door cosworth front offset on 17s and E38 brembos
- Tensioner help Mondy MK3
- swirl pot query
- brake bias issue
- Fiesta 1.4 mk6 idle / Electrical issue
- Oil recommendations?
- E38 brembo calipers! cosworth conversion help!
- AP disc direction
- 2002 Fusion All Spark Plugs Swimming In Oil
- Brakes binding
- Focus Mk2 Brake Upgrade Options
- Fiesta MK3 zetec conversion
- Cosworth AFR gauge readings all over the place
- Smoke coming from engine?!
- Whiteish looking smoke.....Help?
- would a exhaust manifold leak cause a serious stutter?
- zetec 1.6 s
- granada wheel
- zetec 1.6 s
- bosch 044 fuel pump running constant on prime
- Tricky one here! bosch 044 on cosworth priming issues?
- Electrical Nightmare
- Work van won't start please help
- co2 settings for cosworth stage 3?
- St170 turbo
- Oil leak, mk1 1.8 focus tdci
- focus st170 new clutch problem.
- Sapphire 4x4 running rich while driving along
- swapping shims in zetec se engine without removing cams
- How to fit Sapphire rear anti roll bar to a 3 door?
- Spacers for my mk5 fiesta 1.3
- Fuel metering head
- cosworth black smoke running rich? backfires when revved hard thick black sooty plugs
- tuned ST170 engine
- cosworth radiator staying cold!!!!
- Escort MFI Poor Starting..
- MK5 Fiesta anti-roll bar bush change
- A nice quick one for someone who knows
- Sierra 2.9 xr4x4 cut out/off when hot
- help ! manifold removal transit connect 1.8 endura
- escort van 1.8 turbo conversion help
- No one has the answer
- Mondeo st24 2.5 juddering>??
- Supertech piston rings
- Radiator help
- Temp guage / sensor problem
- mondeo tdci wont start
- Newbie needs a little help please
- Air filter replacement Ford Ka
- Cosworth v6 injector upgrade
- cosworth serious hesitating under accelerating!
- cossie uprated drive shafts
- How to meassure fuel pressure
- cosworth not firing on cylinders 2 and 4 any HELP!!
- tddi- evry mod
- Transit asm auto gearbox and glowplug lights flashing not igniting
- Rose jointed tubular bottom arms
- Best tail pipe
- Focus st225 powerflex helpppp
- cosworth no pulse from injectors?
- 2000 focus zetec usb light ?
- carbon/kevlar lightweightdoors - how to install?
- Cos 4x4 master cylinder brake question
- Focus st2 facelift problem
- 2001 escort 55 n/a flywheel
- Mk5 fiesta locks
- Valve springs
- cosworth abs system - minus the abs part
- XR3i Rev Counter problem
- 3 door sieera base model tunnel?
- Mk1 focus diesel problems
- locked out of focus st, both key and fob
- pinto/YB alternator compatible?
- orion/ st170 brakes?
- saph cos 2wd exhaust
- Ford Taunus TC3/Cortina MK5 steering boss
- Mondeo st220 miltek exhaust system worth it or not
- Kit car engine decision!
- Sheered V band bolt
- Noise on front end st170
- injector cleaning
- Help Needed Please
- Cosworth hybrid gearbox using the mt75 Help!
- 2.0 zetec turbo wont rev up
- Mk5 fiesta alternator wiring zetec turbo
- S2 rs turbo lost spark
- 2.9 flooding and missfireing
- Mk7 best wheels and ride height?
- cosworth l8 ecu'd car problem
- 1600 Crossflow turbo help please
- Focus tddi
- Changing Injectors
- Diesel Fiesta wont start
- 1.6 Duratec. What is the difference?
- Focus mk1 1.6 - engine noises...
- Ford Ka 97 will not start after hitting a speed bump
- Vacuum hoses for Focus ST225
- 4x4 sapphire - need help with the spec + small problem
- Cosworth engine gurus help wanted
- Sierra DOHC Idle Issue
- Ford Sierra mk2 2.0 dohc
- 2008 mk6 fiesta zetec s 1.6 16v petrol
- Ford Focus 2010 Bonnet Lock Broken
- st170 gearbox problem
- 2.9 12V injectors
- MK4 XR3i gearbox problem
- headgasket choice and o-ringing?
- Saph Coz rear disc type & size
- flashing glow plug light
- Best engine oil to put in a mk2 FRS ?
- Turbo rebuild
- Zetec turbo compression advice
- Lowering mk2 focus saloon
- Engine warning light after Cambelt change on Fusion 1,4
- Advice on engine swap
- sierra coilover problems
- Rotating T34 compressor housing?
- Bike carbs on ST170 manifold
- Focus RS Mk1 fuel pump loom
- Ford ka zetec eating petrol
- HELP@@ Zetec mk2 cortina steering rack conversion
- track rod end
- t34 comp size
- How to test your EFI fuel system performance
- Turbo theory question
- Oil contamination on timing belt on my mondeo xr5
- focus rs mk2 sat nav removal ???
- New coilovers/suspension arms, strange feeling?
- Cosworth 4x4 pf09 tps setting up
- T3 turbo ?
- Car won't turn over :(
- Window switch replacement?
- 2006 Mk6.5 Fiesta, Center brake light removal?
- Sierra dohc fuel sender
- Ap cp5200
- 2 Litre Zetec into MK3 Escort
- Smoking/oil loss
- Question for carb masters, ford escort 1.6 cvh, weber 28/32 TLDM problems.
- Thread size water temp sender
- excessive handbrake travel
- Bike Carb PCV worries
- Sierra LSD
- Ford Kuga - Engine Malfunction... DPF??
- need help please with escort van brakes
- Forscan help?
- Help with tranny 2.2 dura?
- 2000 Mondeo 1.6 No Power
- Custom inlet manifold urgent help!!!
- Mtx gearlinkage
- MT75 gearbox problems
- High revs
- Fuel Tank Venting Problems
- Upgrading to 044 Fuel Pump
- cambelt change 1.8td
- Focus st boost problems
- More rs2000 problems :(
- Help with ERST into Orion Efi starting problems
- Zetec turbo water pipes
- BOA starter with type 9
- Puma 1.4 Overheated Suspect Heater Control Valve Big help needed!
- St170 imrc control unit
- braided fuel pipe leak
- can anyone identify this and is it important
- Bike body's on fiesta rs 1800 zetec
- Coincidence or big ends gone?
- Fiesta rs turbo tps sensor
- heated rear window problem
- Puma radio interference when ignition on or engine running.
- Ford fiesta MK4 zetec s Knocking/clicking sound?
- Speed Sensor Ford Focus
- Heater button
- Please help codeing injectors
- Cosworth just backfiring on ignition
- Ford Transit 2.0l 2005 FWD Wont Start
- 07 plate Mondeo 2.2tdci ST155 eml light reset (manually reset?)
- What bhp figures can i expect from my fezz turbo
- Vgate scanner software
- Ford ib5 rebuild
- Mondeo 04 TDCI code PO251
- fiesta mk6 / recaros help
- Diffrence off XR3I 1,6 CVH
- My YB has stopped fueling
- fluid leak after dropping the rad. It's bright green
- Cosworth fuel rails
- Mk2 cosworth engine mounting
- Sierra Sapphire Cosworth No Compression In 3 Cylinders
- escort xr3i cabriolet window issue
- Mondeo ST TDCi turbo issues
- 4x4 saph boost miss fire problem
- over fueling
- 2001 Focus 1.6 engine swap???
- 4X4 sapphire and escort cosworth front hub
- 2002 Transit tdci
- lambda sensor fitment
- cortina cosworth fuel pump wiring
- Cossie Block sender thread sizes
- 2003 1.6 Focus Smoking and Oil in Cylinders
- no temperature
- mk5 fiesta zetec oil stem seals - which colour which end?!
- Ford Escort - Honda s2000 Engine Question
- Non Start
- Focus rs mk1, turbo oil feed pipe.
- Fitting a rs2000 mtx gearbox into s2 rs turbo
- binding brakes/Tyre change?
- mk 4 fiesta zetec turbo
