- Connecting waterhoses to orig. oil cooler on S2
- Mondeo, Which oil?
- Suspect Head Gasket Failure
- 2.0 zetec
- the right chip
- Cossie T3 on S2 help plz
- facet silver top pump on an s2
- Rev counter probs...
- anybody got a t34 on 1600 cvh??????
- ZVH black top????
- Quicker zetec S
- cos rims
- how do you do the timing on small turbo esc
- mk5 xr3i alternator trouble
- series 2 boost problems
- Cosworth stem seals/guides
- Metering Unit to injector lines..what order?
- turbo problem!!
- Cambelt cover.....needed?
- cossie engine GURU's
- CVH crankshaft
- s1 rs turbo runnin very warm
- big bhp escos
- ybp head gasket
- Aligning a clutch on RST
- Blacktop ZVH
- HT lead combination.....help please
- cosworth yb main bearings
- help on escort cossy
- mk6 escort 1.8 si
- rs500 intercooler boost pressure!! help...
- Need help on buying new exhaust for Mondeo Zetec S V6
- cossy wheels
- cold start problem
- gets hot in traffic
- cvh rocker gasket
- 1600 turbo conversion
- Where to send my T3 turbo
- sluggish fiesta zetec s
- injectors
- Heater blower fans ? Electrical problem
- mounting map Sensor
- Gauge replacement - Do I need to change sensors ?
- N/A Zetec Into Mk3 Escort
- Painting Textured plastic
- thinking of fitting plenum spacer
- what could i use to secure my showplates on my car?
- what will i need ...(S2)
- steering column bush 2wd
- cosworth Solid cam Followers
- ht leads for my girldriends ford ka
- cossie valve guides
- Cos plenum spacers?
- smoking when letting off the power
- t35
- Carbs....48DCO/SP Jet Settings on Pinto-Help!
- HELP WOULD BE AT MOST HAND PLZ brake line broken
- 2wd gearbox problem.....
- Shell Prep
- Brake compensator mk4 escort q
- New Turbo BUT Down On Power
- ford alloy wheel nuts
- escort 1.8 turbo diesel reving
- comp brake compression struts, knocking!
- help needed frst
- Koni Adjustable?
- Saph cos 2wd ABS
- wat diff for cossie
- Saph Cossie 4x4 water pump
- Fitting RS500 Style cooler in Escort
- Problem with steering, brakes etc....
- mfi erst wont run.....
- how much power on mfi
- curious boost behaviour
- how do i test a coil pack
- rs turbo brakes can ne1 help
- extra bhp wanted
- cossie breather system
- Saff Cosworth sideskirts
- Zakspeed Cosworth Capri
- Need blanking plug for EFI
- Saff Exhaust Manifold Leaking
- Zetec dipstick tube?
- Black top zetec alternator bracket help
- bigger exhaust bore diameter / advantages?
- shaking steering wheel
- Focus RS missfiring badly
- Mk 4 fiesta engine swap.
- problem with gearbox help
- mk 4 escort eclips
- 02 galaxy 1.9 dti loses turbo boost intermittantly
- series 2 head problem
- shocks,compatiblity
- fiesta xr2i bottom end...
- EFi CVH head - Distributor?
- Airtec intercoolers
- wheel bolts to studs
- mt75 gearbox wiring help
- cvh rev counter wiring
- Advice needed Fuel Filter
- oil cap blowing off
- Mk4 escort efi cab wiring diagram
- cat problem.need help!
- esc cos ST ABS - no sound from pump
- 2 stage boost
- 1.8 turbo diesel escort water pump
- Idle ok - Splutter/stall on any Throttle
- ka engine swap
- Help please...
- help please guys !!!!
- flat spot and fuel issue
- FRST OFAC Fault code 31 - What is the fault?
- fuel smell in oil in cossi
- oil pump pressure relief valve rst
- brake pads ST24/ST220
- Side exit exhausts
- what would cause a t2 on fiesta to over boost
- cosworth ISCV
- fuel pump 3dr
- Alternators and W terminal
- clutch
- S2 electric windows
- fiesta turbo engine problem HELP
- s2 smoking
- rev counter connection
- Jerking problem with boost - possible turbo death?
- ST170 Problems
- Cossy 2wd Gearbox Oil Change
- New intercooler, lower coolent temp?
- esc cos reverse lights....
- Connector type question
- Cosworth loose ends
- whats the best oil for escort rs turbo????
- Saph crank
- saf gettin me down now
- Oil Pumps
- suspension stiff as..!?
- escos banana pod gauges ilummination problem
- coilpack conversion
- cosworth performance
- fiesta mk4 rear sub frame/ axle bushes need help fast
- Who does yours??
- adjustable lower arms
- Horn problem 2wd saff
- drivetrain knock need help!!!
- ST170 Sparks
- is this correct
- cosworth 4x4 clutch cable replacement!!
- what car is this turbo of do u have same one?
- 4x4 vs 2WD cossie head
- mk 5 project help
- pectel t2 power up????????????????????
- 4x4 HELP!
- Body panels for mk5 esc' XR3i?
- 2.1zvh + OFAB
- some smoke thru the dv??
- Temprature guage not working
- sliver top zetec and black top zetec
- rwd conversion
- fiesta rs turbo trouble
- sounds rough and smoking RS Turbo
- wiring ?????? help????
- want to upgrade my series 2
- Focus 1.8 Zetec Cutting Out
- Clifford Alarm, Help!!
- cossie crank prices
- escort mk5 best value brake upgrade
- lumpy tick over
- 2wd cossie electric mirrors
- 3dr Mirrors
- erratic idling/misfire
- FORD FOCUS 1.6 Zetec 02 - hi idle problem
- rs turbo into my mk3....
- T3 rebuild question
- Problem with RST
- 2wd 4 pots onto 4x4
- wat fuel pump
- wat turbo for my cossie
- Squeal from the Front of the Vehicle
- steering wheel shakes when braking
- antilag system problems!!
- boost hose help!
- !!!!! Help Help Help Help Help Help !!!!!
- odd noise fom zetec engine
- Replacing Manifold Nuts
- gearoil-T5-
- fiesta turbo boost hose problem
- is it suposed to do that
- Alloys on to Ford P100
- turbo oil return hose
- series one cossie management help!?
- Fiesta Turbo Leak.... Please Help!
- Pug 306 Power Steering
- Escort MK6 Cabby CVH Turbo Conversion?
- fuel pump wiring si conversion to 1.8
- outside handle bust with child lock on B***ock's
- best 2wd cosworth spark plugs?
- xr3i efi relay
- 1992 ecsort P2 paint code help
- What is this sensor? (Escort GTI 1.8 16v zetec)
- plans
- turbo difference
- uprated fuel pump
- Can anyone help... Need to find a map for my MBE
- sierra cosworth front seats.
- Lowering My MK6 Cabby on Escos Rims Tyre Choice??
- Cosworth Engine Block Breather / Oil Return
- cossie cutting out?
- Is my transit pinto engine a load of scrap?
- Cracked turbo!!
- RST gearbox prob - no reverse
- air mass meter
- Wires going to coilpack
- turbo problem
- Fitting Stage 2 cams to N/A Zetec
- 3dr coil springs same as 2wd sapph ???
- charging problem
- ofab/ofac whats the diffrence
- Fuel Pressure
- zetec se 1600 head
- sierra cosworth leather colour
- bigger s1 prob now
- fitting an 1900 in a s2
- 3 door oil leak
- frst idle problem
- s1 prob :-)
- gearbox question
- Ford Mondeo 1.8 TD 1996
- ke relay
- cossie rods question :)
- still not boosting
- no fuel to injectors?
- RS Turbo Standard Oil Cooler?
- cosworth vacume pipes???
- Biodiesel in Focus TDCi
- Turbo advice needed... wot type shud i go for
- Rough Engine Running on my escort cabby
- Gear Linkage Advice On ERST
- coilover seteruperers
- forged internals now or not!!!!!!!!!!!!!!!
- cvh rocker cover ??????
- cossi still wont start
- Horn of not a lot!!!!!
- st170 engine warning light
- bottom end help please
- series 1 warm problem?????
- boost gauge not reading correctly
- FRST Fault code help
- need rs turbo diagnostics
- Boost controllers running over 90% duty cycle ?
