PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110
  1. Siemens injectors
  2. transit connect rs
  3. BOA or BOB?
  4. Cosworth valve guide problem
  5. 1990 XR3i Cabriolet
  6. Matching ecu to engine no.
  7. mk4 escort xr3i rs turbo sunroof
  8. clifford concept 50 HELP!
  9. Sierra cosworth seat covers onto Rs turbo seats
  10. top end rattle
  11. Temperature gauge query
  12. fuel pump relay.
  13. MTX 75 gearbox trouble
  14. PE 1.9 systems 2 inlet valves
  15. Fuel line help
  16. 5 wires o2 sensor
  17. Cossie tickover
  18. Boot lock problem
  19. Anyone no cozzy L8 tuner around heathrow ?
  20. strange cutting out problem
  21. air conditioner
  22. Wiring diagrams
  23. Best 2wd suspension set up ?
  24. Cosworth Front Anti Roll Bar
  25. caliper i.d please
  26. st170 flywheel problem when cranking
  27. 2013 for focus passenger door mirror
  28. Zetec Turbo donor car - what can/should I take?
  29. dash board running water?????
  30. Ford focus warning lights keep flashing
  31. S Max Problem
  32. Alternator light .....help
  33. cosworth engine rattle/noise when cold
  34. Re-light
  35. ARP Head nut & studs
  36. 2011 Fiesta 1.3 performance issue when cold
  37. 3 door Cossie steering rack play..
  38. Replacement engine
  39. gearbox
  40. cossy 24v tow starts but not via starter
  41. Ford Focus - Safing Sensor?
  42. strange rattle
  43. bonus rev counter?
  44. rs 2000
  45. Cvh tuning help
  46. shock absorber rally setting
  47. Which oil for 4x4 gearbox
  48. Fiesta mk5 ZT OFAB?
  49. Oil pressure gauge
  50. AP Racing Master Cylinder Help
  51. Changing rear centre brake light
  52. Zetec rear crank seal
  53. Sierra saph 2.0 dohc to cosworth yb questions
  54. has anyone swapped a crossflow for a Zetec e?
  55. Please Please Urgent Information
  56. Oil separator problems
  57. cosworth oil temp
  58. Ford Focus Limp mode
  59. EML on intermittent - S Max
  60. coilovers
  61. Turbo surge ? What is it and a it bad ??
  62. Quick clear windscreen wiring
  63. Please Help - Rs series 1 problem
  64. 2004 c-max with the 1.8 duratec he engine - will a mondeo engine fit with a few mods?
  65. HELP! Where can I get throttle position sensor ??
  66. More Urgent Information Please
  67. 2001 TDCi low power and will not rev over 3K
  68. frsmk1
  69. Wasted spark problem!!!Heelp!!!
  70. Cosworth exhaust valves
  71. efi rst holding back
  72. Urgent Advice Please
  73. Electronic boost controller
  74. 2wd engine using late spec pulleys
  75. help !!
  76. Fiesta mk4/5 std pedal box
  77. core plugs
  78. 52' 1.6 Zetec focus starting fault
  79. Boost gauge
  80. sapph cos abs problem again
  81. Spring doesn't compress enough?
  82. 3dr Cosworth
  83. ABS system
  84. Ball ache #2
  85. silver top or black top
  86. ABS system
  87. series 2 over fuelling
  88. Mk1 escort cosworth not starting
  89. 2008 twin tuner radio code
  90. 3dr main beam problems
  91. What throttle cable?Mk2 fiesta and efi inlet.
  92. Cossie T34 turbo
  93. T34 turbo help
  94. mk4 power steering pipes
  95. Recommend me a mini blow torch
  96. What partno / part name
  97. Small Turbo Cambelt TDC
  98. High Idle Cosworth L8 4x4
  99. Megasqirt/efi tps wires.
  100. Mk7 escort GTi brake conversion
  101. Focus ST 225 lamda sensor
  102. KONI adjustable shocks issue with rear pring holders
  103. Cosworth ABS
  104. Pinto 1.6 to EFI
  105. 2.0 pinto performance tuning
  106. Max disc weight for a saph
  107. Electric servo wiring
  108. zetec swap
  109. 2012 Focus Problem
  110. Lexus RX300 Coolant Level
  111. Melnei engineering
  112. Focus TDCI Water Returning to Reservior on Startup
  113. mk2 escort yb help!!!!!!!
  114. Will a mondeo mk1 DEEP ecu...
  115. radio code needed for a 6000cd
  116. Car Jack
  117. Escort cossy lambda sensor
  118. Supra diff
  119. 2.2 pinto build help.
  120. Cossie head who you use 137.8 .
  121. mk4 xr3i aerial route
  122. L8 flat shift and launch control Ecu pins for msd chip
  123. Few problems. Air con, Brakes, Speedo...
  124. Thread size
  125. Help - 2010 Manual C-Max Gearbox
  126. Yb oil temp gauge
  127. Help wiring in the mk4 fiesta boot switch
  128. Cosworth L8 ECU
  129. How to change washer bottle?
  130. Mk3 Escort cvh engine wiring
  131. Heatshield material
  132. 2wd Cossie ABS
  133. Ford escort mk3 xr3i gear selection problem
  134. Coil pack testing
  135. Dump Valves
  136. no 4th gear
  137. What colours my car L3 gold or platinum metalic
  138. Baileyperformance.
  139. Fitting fuel swirl pot on Yb cosworth tank size?
  140. Ignition amplifiers
  141. egr removal ??
  142. Eecv wiring guru's please look
  143. Quick question
  144. problem starting rs after rebuild help plz
  145. Dry Sump kit zetec
  146. Wide Band O2 sensors.
  147. heater problems ??
  148. Focus 02 1.6 petrol starting problems
  149. New problem or just this crazy weather
  150. Escort RS Turbo series 2 Radiator
  151. Differential pressure sensor voltages (blocked DPF)
  152. Rear axle spacers...
  153. Indicators malfunctioning. Mk1 Sierra
  154. Is it an easy job?
  155. focus mk1 intercooler kit
  156. intercooler options
  157. Would it be safe?
  158. ford focus c max flash code 16
  159. Spacers
  160. Bell Housing Bolts
  161. What injectors for a 2.0 blacktop with fez efi mani
  162. Ford P100 V6 Conversion
  163. mk1 focus electronic headlight height adjustment (standard bulbs)
  164. Cosworth ABS
  165. full set of weather strips needed for my 93 cab
  166. fiesta rs blue injectors,,need info on them for megasquirt
  167. Ford Fiesta LX(B Pillar Trim)
  168. Matching a engine to a vin
  169. unknown fault - help
  170. How to remove CAT on a ford fiesta MK6
  171. Anyone near Manc/
  172. 2.5 V6 Duratec
  173. Bellhousing wont come off
  174. 04 mondeo tdci ghia x
  175. help!!!
  176. Sierra v6 twin turbo
  177. Erst fuel pump outlet size
  178. Ignition module
  179. Blacktop Alternator
  180. Braided Fuel Hose Help.
  181. pectel style loom for cossie management
  182. escort engine issues
  183. What starter motor
  184. cosworth rev counter wiring
  185. mk1/2 focus engine change
  186. Cossie 3dr. Starter relay, how to identify?
  187. Mk1 Focus 1.8 zetec newbie needs help
  188. sterio code help
  189. mk1 frs turbo compressor housing spin ?
  190. Escort rs turbo s2 cuts out when hot
  191. advice needed for a DiY engine rebuild.
  192. 3 Issues - One problem?
  193. Toyota supra diff info!!
  194. Any one fitted a full zetec turbo using a escort rs mani to a mk2 fez
  195. Smax 07 1.8 tdci engine code location????
  196. Fiesta mk3.5 seat runner question
  197. need advice on rs engine rebuild help plz
  198. fitting coilovers
  199. Mk1 Mondeo citrine 'Hendy' RSi restoration - help needed!
  200. Can anyone help please fiesta st 185 mk6.5
  201. mk5 hazards not working
  202. Weird noise form crankshaft pulley
  203. 200 block long stud it? your opinion plz
  204. Ford P100 Paint code
  205. Plastic welding
  206. Air leaking into cabin problem. Help :(
  207. which bailey oil separator
  208. 3 door map sensor
  209. new
  210. will a 2001 focus 1.8 exhaust fit a 2.0l
  211. Fiesta coolant problem.
  212. Misfire under boost
  213. And finally
  214. Suggestions plz: another RS2000 misfiring
  215. Ford P100 Headlights
  216. mk2 RS2000 custom door cards fitting
  217. Fiesta interior lock issue.
  218. Won't stop reving
  219. transit connect issues.
  220. CVH Camshaft Id ( believe Newman )
  221. Focus exh manifold in Mk4 Escort?
  222. getting mk3 escort fuel gauge to read correct with a mk4 efi tank
  223. 2009 Zetec S 2.0 136 (160) TDCi turbo trouble???
  224. rs turbo s2 gearbox
  225. injector coding
  226. help needed mondeo injectors
  227. Cosworth boa v6
  228. Zetec turbo throttle cable???
  229. cosworth rev counter and top end rev issues
  230. Where to recondition diamond cut RS7's?
  231. 2WD L6 Cosworth electrical fault :(
  232. Efi head
  233. brand new mk3 focus zetec s 1.6 182 fan query
  234. 53 Mondeo 130 TDCi handbrake adjustment
  235. cosworth asb/brakes
  236. Ignition Live Help (Omex)!
  237. Focus mk1 wheel bearing, worth changing hub too?
  238. Mk6 Escort master cylinder upgrade
  239. T5 clutch release bearing
  240. trying to id some part nums
  241. brakes :(
  242. Cosworth Camshaft sprocket bolts
  243. 2.0 zetec decompression plate
  244. 1.8 Silvertop 2.0 cams
  245. 3000rpm tickover
  246. Help: Best way to fit new window & seals mk1 escort?
  247. Grey injectors
  248. Ford Focus RS Fuel Consumption
  249. no/low oil pressure on fresh build
  250. Escort brake upgrade
