- Problem with fuelling
- Scorpio`s 2.3 16v turbo build question
- someone persuade me it's not the head gasket
- orion ghia oil from exhaust
- what do you do if you break/ have a seixed bleed nipple? *update, i have seizure*
- V6 Carb rebuild
- Body kit fitting
- 2.0 Zetec Blacktop Valve Stem Seals
- RS 2000/ XR3i help
- St170 Dash lights
- rs turbo cab help please
- where is the cheapest and the best place to buy emerald ecu from
- What exactly does a MAP sensor do? Running issues with EFi management! PLEASE HELP!!
- 1.8 Zetec - PROBLEMS!!!!!!! HELP!!!!!!
- Coolant System
- Focus heated windscreen not working on one side!?
- f ing rs turbo head
- Help with converting to mp4 for my iPod?
- oops
- FRST fuel pump question.
- Various cuestions about mk2 fiesta track car
- auto electrition
- CVH lifter problem?
- Orion MFi won't start
- MSD Closed Loop
- S2 brake problems
- what size tyres
- 1.8zvh into series 1
- 4x4 head on 205 block
- R&D Dogbox Ratios
- wiring loom plugs cosworth
- Is my charge temp too high??
- My 1989 escort rs wont start
- Lowering Mk 6 Escort Van
- Mk5 esco 1.6 zetec turbo
- fuel pump problems
- Zetec turbo
- fiesta turbo.
- high flowing beige injectors
- Vx Nova Head Gasket
- 52 focus steering
- Brass plugging ZVH oilways
- Ford escort front suspension arm rubber bush
- Fiesta ZVH engine mount help please
- l8 ecu stage 4 with baby board
- zetec turbo inlets
- Re-mapping Pectal...
- i havent a clue whats wrong with my s2
- gearbox oil for mt75 box
- saff running problem
- Funny zetec mis-fire
- 83lb seimens injectors
- Spoiler Caps Removal
- 3dr Sierra Front Seatbelt
- Zetec cam gears?
- 51 reg focus coolent temp gauge
- Engine rebuild, now fumes coming from engine bay???
- Focus gear lever
- Mk2 Fiesta Indicator Buzzing...???????
- 97 1700 Puma revving on its own?
- Master cylinder upgrade for mk6 escort.
- Mk II Granada LSD
- Cat C write off ?
- Electric mirrors not working
- Engine change help.
- Escort alloys on Escort Van?
- 2ltr or 1800 zetec convertion help needed for my 1ltr fiesta
- MOT on tuesday...bonnet wont open!
- please help!! focus diesel problem that is getting pricy
- Heater Blower , Blown Fuse
- DVLA INSPECTION OF NEW ENGINES and company in carlise IMPORTANT
- HELP Rev Counter turned the wrong way :cry:
- Suspension
- white smoke and missfire?
- Fiesta cutting out
- Clutch slipping on boost...
- Starting problem
- Rst- haynes manual
- 2.0 pinto turbo ..info..help..update 15/11/08
- s2 misfiring problem,any advice??
- MK 6 Fiesta Mirror Backs
- Help needed with rs engine into diesel van
- SMILES
- This noise is driving me crazy!!!
- focus st170 2004 manifold runner?
- Cars drivin me nuts!!
- Turbo shaft movement limits.
- 205 blocks
- mk5a RS2000 running problems
- focus rs into mk2 xr2?
- Quick Torx Size Question
- Locking Rear Wheel
- inlet manifold temp gauge
- totally confuffuled about offset!
- heater resistor question
- Fiesta 12V Power Outlet - Please Help :(
- Fiesta gearbox problem. Help!
- Cos management.
- afr gadge
- fiesta si tuning help me!!!
- Body to change sierra cosworth sapphire 4x4
- MK5 Running prob's :(
- Help with a piper 285t2 cam
- Q plate question
- running my turbo rich
- Help needed
- fitting s2 body kit (arches sideskirts)
- street ka clutch problem
- IB5 gearbox limits
- Who make these 4x4 mounts...
- rolling road graph analysis
- done my time!!!lol
- What is this bracket for?
- saph power steering help
- 97 Escort Electric Window Button Problem
- miss fire!
- oil pressure gauge wiring plz help
- need service info on a focus zetec tdci
- rear disc conversion, help???
- 1996 escort heated front screen relay help
- Fireing order
- why is my car running lumpy
- saph cossie spoiler on a mk4 escort cab how easy ?
- s2 turbo brake pedal solid an harldy any brakes
- 4x4 cossie Fuel Rail plz help
- Looms
- 4 wheel alignment
- Steering wheel removal 4x4 Saff Cos
- Handbrake Problems
- Only totally free hosting service.
- help...
- What spark plugs
- SECS ERROR message M.A.P sensor input failed
- Joining here
- 1996 scorpio 2.3 heater stuck on cold!
- S1 front sus on a s2
- Fiesta Rs Turbo Engine Into A Mk4 Escort
- IB5 Gearbox LSD HELP??!!
- CAN A WRC STEAL GASKET BE USED AGAIN if it was only use for 30 mins on idle?
- Megasquirt basemap needed for ZVH Turbo...
- Coolant hose run on xr4x4 v6
- Focus RS gearbox ratios
- having running problems on a fresh rebuild :(
- having running probs with a fresh rebuild :(
- escort dtm mirrors
- ST170 Brake conversion
- Cheap Cosworth Green Injectors...
- Punto Gearbox rebuild
- Sapphire Cosworth brakes
- Losing spark when warm 3dr level6 ecu
- mk5 fiesta horn & hazards not working
- poor runing focus help needed
- Fiesta 2L Zetec upgrade?
- Fitting P.a.s In My Smiley 1.8d Escort Van
- What fuel pump and where from?
- ABS sensors
- mk3 and mk4 wiring
- Orion Ghia damp running problem
- Sapph Tracking settings ?
- brake discs
- RS1600i Turbo Technics Problems!
- Duratec 2.3 upgrade
- which engine oil??????????????
- Weber FPR's...
- GT2860RS Turbine housing.
- wiring a switch
- Mk3 Escort ARB basic settings
- Fiesta Mk6 Airbag replacment
- st170 diagnostic light
- pectel t2 injectors
- BMW 3 Series question???
- rst box and ib5 question
- E30 - 1 wheel sits differently to the rest?
- escos running on two cylinders
- Injectors
- Cosworth plant into a Ford Popular 103e
- Zetec building crank wont turn
- escort cab all white
- Problems with heater, Ford Fiesta 2002 1.3 Finesse
- turbo running lumpy please help
- pinto engine problem?
- escort rs turbo running fault
- Rev counter....
- gutless v6
- quick gearboxes question
- Suspension
- Running a wire from battery to interior?
- timing belt change problem
- 4x4 bell housing
- spoiler for my mk4 fiesta
- Fiesta turbo edis probs
- looking into bushes!
- escort rs turbo
- Ford Sierra 2.0clx,Lsd ?
- Any cologne v6 experts around ?
- engine revs not droping
- trying to diagnose if my turbo is on its way out help!!
- spoiler on my escort
- mk4 efi escort dash clocks not working
- Block difference?
- focus RS main bearing settings
- orion injection ghia efi running probs
- tappy xr2i
- atlas axle
- Spacer for cossie brake fitment ~ where from??
- Silver Top Zetec engine into a Fiesta MK6.5
- cvh turbo into mk5 escort
- Water temp problem
- Escort RS2000 engine conversion into a KA
- YB Temp sender resistance cold
- air bag help
- MK6 clutch cover
- cozi wrc steel head gaset
- Zetec Engine Removal
- WANTED: Teves Mark II 32-pin ABS wiring diagram
- cosworth knocking noise
- car problems focus help
- how can i sell my car on here?? any helps cheers
- Longer Rear Wheel Studs - Fiesta MK4
- engine oil running temp frst
- were can i get sump bolts TODAY!!!
- HELP overheating cossy
- Escos Heated Windscreen
- 3 door no spark
- uprated head gasket help needed
- Cam timing? seting up verniors?plz help
- Need Flywheel and clutch
- brake conversion
- pectel question
- Cossi Brake bleeding problems
- Sierra 4x4 floorpan welded to ERST shell
- strange smell
- mk4 and 5 fiesta to 1.7
- changing from 1.8 to 2 litre zetec
- Will 1800 zetec gearbox fit 1600 CVH?
- cvh head
- 51 reg ford focus water temp gauge
- how easy
- auto electrician?
- Fiesta Door Mirrors
- cosworth top end knocking noise
- Plenum
- HELP!! cant power up my ecu on saph 4x4
- cosworth head
- connect lowering
- what boost
- side indicators
- zetec injector upgrade?
- Focus RS Engine Build Parts Choice Help
