- cant get idle below 1100 revs on s1RST with megasquirt
- blue smoke and rattles
- Sierra doch 2.0 8v low comp pistons
- Escort Turbo IB5 Gearbox
- cosworth turbo adaptor
- misfire mondeo mk3 1.8 03 plate
- Strange starting problems
- efi?
- Ford escort 1.8 lx 16v 1998 missfire help
- Removing the alarm/immobiliser part of a zetec loom?
- Play in valve guides and where to buy tuned heads - please help!!
- De compression plate
- another zetec turbo question
- anyone fiitted a single wiper conversion
- Turbo on Endura DE lump
- Zetec E Tuning?
- Garrett T25 on 4x2 Exhaust Manifold
- Ford Fiesta Problem
- urgent advice plz( cossie idle )
- t4 on 4x4 sapph
- What would a 50/50 torque split drive like?
- L8 pectel
- Few zetec Q's
- clutch problem
- MK6 Escort RATTLE ON BELT SIDE
- Oil pressure/temperature sensors in my block
- Magnex exhaust system
- turbo restrictors
- speedo help!!
- ecu mapping
- Sump Plug Threads - Cosworth Sump
- Ford Ka 4x4
- HELP!
- Mondeo suspensoin knock ??
- Cossy on-boost misfire :(
- help with focus diesel
- Fiesta RS / XR gearbox & Gear ratios?
- 2.0 Zetec in 99 Mk6 Escort hunting at idle
- mongoose exhaust
- 2.0 zetec bottom end conversion
- escort mk5 rs2000 caliper help
- C20LET pistons....
- new galaxy what make tyres do they have
- My Ford Probe sounds like a tractor! HELP!
- cosworth saphirre 2wd for 450bhp?
- Focus Rs wheels Fits Sierra Cosworth 4x4
- Cosworth swedish plenum
- Compression struts
- broken valve springs on YB
- manifolds
- Guide for replacing heater matrix on an Mk 5 Escort
- OFAB MAP Sensor-2.5/3bar
- Possible turbo failure?
- zetec turbo
- Modified Zetec power....
- ignition timing on a s2rs turbo???
- zetec turbo valve springs
- Please help!!!!
- Brake wobble ???
- zvh frst not sparkin
- zetec breather
- brake warning lights on intermittent
- think i have met my match with the toad ai606
- In need of some info
- Fiesta TPS And Emerald ECU
- T3 Turbo Oil Feed Hole Size
- 3 bolt T3 flange
- s2 turbo unit seized??help
- wow help
- MT75 4x4 Transfer box chain
- fiesta gear problem
- Kill Switch?
- Rear Panels
- Comments/advice on my engine spec please
- PEC or Farndon Rods???
- Idle oil pressure for a Saph
- Fiesta st gearbox
- Strange Issue on Full Boost
- Mondeo Heater Not Working ????
- Zetec Sump plug adaptor size
- 51 reg ford focus 1.6 16v water temp sender
- Groove depths in uprated discs
- some help on what to run in mk4 rwd
- heated front screen
- Zetec Turbo Idle Speed Control Valve
- omex 710 management problems
- color code help
- Focus RS Quaife ATB Problems...
- 89 reg mfi xr3i stalling
- wheel on my focus
- any ideas on how to take a fiesta st mirror apart?
- Can you still get Crankcase Breather Filter?
- Mk4 Escort XR3i EFI Crankcase breather problem
- RS1600i suspension???
- Blue Focus RS, no drive
- escort 1600i choke problem
- cozzy 4x4 tappet problem...DAM THING
- plml
- Running (very) lean...
- Base Idle
- st170 dash lights flickering
- Standard plastic header tank for Sapphire cosworth.
- Focus 1.6 zetec s missfire
- Idle speed control valve
- toad ai606 alarm problems
- Tension strut kit into a mk1 escort
- gearbox issue
- fiting a knock sensor into the block...
- located a spray booth to rent
- Cosworth Timing Belt
- RST S2 Brakes on a Mk1 Fiesta?
- T31 turbine housing to cossie 3" downpipe
- mk5 rs 2000 rear brake setup on a s1
- noisey tappets
- turbo advice
- st170 battery to boot conversion help
- Escort 1.8 16v starting probs
- Escort popular 1.3 1988 VIN tag info...
- st escos
- 51 reg focus temp gauge and idle fault
- What does coilpacks require ?
- fiesta turbo probs
- somthings grinding
- Cosworth BD8 Camshaft
- wheels
- Escort Cosworth. New engine - No Oil Pressure !
- Heater Problem
- Won't start
- Brake Conversion.
- Brembo calipers on a mondeo mk2
- manifold help!!!
- Mondeo ST220 Recaros - Stcuk on FULL heat!
- Cossy injectors
- Slight miss on low revs
- Collins Performance?????
- Just wondering...
- low boost
- 400cc Injectors
- engine bore
- FRS Brembos on a mk3 escort
- engine problem
- Mk4 Escort - ST170 Front Brakes?
- fiesta rs turbo fitting T3
- what to paint the underside of my car with?
- runing standard CR whit a t38???
- 4wd conversion
- sierra v8 clutch
- 4x4 cossie vibrating over 3k!
- Ford Mondeo Y Reg
- sierra mirrors
- Cossie T3 Turbo Question
- Sierra 2.0i 8v DOHC - No Spark??
- sapphire cosworth,cold heaters !!
- MK3 XR3i RS2000 COVERSION!!!
- cvh turbo efi......
- 1.6cvh zetec bottom end conversion
- Actuator question..
- 1.8 zvh turbo fuel management
- zetec turbo
- t34 turbo advice
- mk1 mondeo rear disc conversion
- VDO fuel gauge ?
- 2008 Focus Titanium Info panel question
- Clifford Concept 600
- cossie head measurements
- Reputable garage midlands area
- Anyone know about big power FWD Vauxhall clutches?
- Red-Ex?
- Biggest Breaks I Can Fit?
- St170 rwd gearbox?
- MKI Mondeo auto trans problems
- Diesel Smoke
- where to bou the loom cosworth conectors?
- Zetec engine and rear wheel drive.
- Fitting car glass
- any ideas y my indecator fuses keep blowing
- Turbo...
- Have a problem with a6 turbo :(
- advice please?
- 3rd Cosworth Boost Problems
- focus locks
- Roll cage spec's
- Escort van 55 diesel rear knocking
- tld carb vacum hose valves
- 3dr Cooling fans fuse melted ?????
- Standard ford sapphire cosworth springs
- Escort mk4 Fuel Questions.
- turbo problem
- trouble starting my rs festa
- zvh crank sensor
- Cossie L1 OR L6
- who can map a fiesta rs turbo zvh
- O2 Cheat for decat.
- 90' Spec XR3i, front speaker sizes?
- Low oil pressure!! HELP
- can anybody help please.
- cant get oversize bearings
- Cosworth engine transverse ??
- 1600i springs
- Having a few problems with carbs...
- Focus electrical gremlins
- Car runs on by its self!
- mk4 fiesta 1.25 no spark?
- 3 door cozi fuse and relay layout
- Does the L8 ecu...
- mk4 trouble
- 2008 New Shape Mondeo Alloy wheels on a 08 Focus?
- turbo box / slippa???
- how easy is it
- Which cam would you recommend for my setup?
- help me please!
- how to adjust boost?
- thermostat temperature escort turbo
- fiesta mk4 heater valve fitting
- injectrs
- bottomarms... mk6 esc
- rs turbo into a mk5 escort
- is this a forged piston ro a standard zetec one??
- after market tacho in gti.....HELP.
- cossie developed strange problem
- urgent help plz on torque head bolts yb
- a/c dash switch
- front screen switch????
- Fan and Horn wiring
- cosworth brake pads and diff info
- esc cos throttle position sensor
- efi vs mfi
- Wanting more power
- yb exhaust gaskets urgent help plz
- FRP Box Into Escort MK6 cab
- help rst no spark
- What Parts to Use?
- someone must know dead car
- oil light flickering?
- escort cabriolet rs boost gauge
- heater problem
- Cossie Breaks seized
- Which radiator? MK6 escort
- s1 rs turbo running problem..HELP!!
- Dash spots
- problems fitting stem seals
- more brake fluid questions...
- sierra mt75 gearbox
- level four chip ???
- roll cage material
- zvh???
- My Zetec rods little ends look iffy.
- silvertop = blacktop
- fiesta turbo low compression
