View Full Version : Technical help Q & A
- Working out compression ratio????
- Mondeo ST200 brake help
- Rising power 1.6 16v zetec
- Bleed valves......any good or dangerous?
- Cossie smoke help
- 1.1 HCS White smoke
- ERST Idling High
- iacv delete
- brake calipers
- Fiesta rs turbo act sensor
- what management to run?
- Cologne 2.9i 12v still Help with wiring
- building a n/a ZVH, what cam belt?
- dump valves?????
- radio cd codes
- Diagnostic Plug Pin Assignments
- HELP.. im getting sick of this rs turbo
- 2.0 ZVH Bottom End
- Sierra 1.8 Cvh Crankshaft pulley
- wheel pcd and et
- Loud noise ERST
- XR2I Starting prob
- bit of a silly question regarding baterys
- Help required with fuel pump (see pics)
- Cossy Oil Pressure
- Rear Break Setup
- mounting blow off valve
- fiest engine swaps
- calipers/refurb
- sticking handbrake arm on my caliper
- ne 1 got ne ideas
- mk1 focus headlights
- Sapphire/3DR Suspension
- power steering pump cossy will it fit ?
- wipac immobiliser
- 3dr ST170 Passenger Window Not Working?
- Zetec Turbo management
- A bell jingling like sound from the engine on acceleration...
- Help needed on zvh and cvh
- Rs turbo engine management
- abs brakin problem
- Escort 1.6 Zetec to 1.8 Zetec
- clutch?
- fiesta rs turb
- arch rolling
- any good powder coaters in hertfordshire
- mk6 escort elec problems, help please!!!
- focus zetec 1.8 revs sticking,help
- zetec with an st170 gearbox...clutch choice
- xr3i efi to s2 turbo mfi
- series 2 starting problems
- Ahmed Bayjoo Chip Installed but not working?
- 1.6 Zetec not pulling
- help!! rs2 mk2 been stood for 15 years
- XR4x4 owners.....
- MK4 Escort XR3I EFI Problems!!!!!
- Mondeo TDCi
- Secs monitor fitting to l8 ecu
- fiat punto cooling system question
- balancing a Centreless rim, how?
- focus rs engine into mk6 fiesta
- Escort TD Van
- Why would you choose a GT35R over a T61?
- rs2k i4 or 2.0 zetec engine... any differences..??
- fitting a 4x4 cossie oil pump to 2wd
- water getting in to boot of escort
- New to the site
- zetec turbo idea
- vectra gsi foglamp problem
- Escort Cosworth Front Calipers
- Replacing housing t3 > t34 on 4x4 saph
- Replacement Key For Turbo
- 42mm Inlet valves Vs 43mm Inlet Valves
- frst box in escort mk5
- removing screw covers without damage
- Timing belts from woodford - Anyone had any problems ?
- 4wd saff horn
- zetec 1.8 wont start when hot...
- escort cosworth battery
- door lock not closing properly
- External wastegate locaiton and mounting place
- Wheels wont fit because of big calipers!
- any one know if my escort is obd-2
- mondeo tdci fault code
- Electronic Heater Controls
- Need some help pls
- Oil Housing sensor broken - commom fault or not???
- engine miss fireing then serging
- Newbie needs help!
- CVH Bike carbs ???
- P100 4x4 Diesel.....???
- zetec turbo, which swirl pot?
- Snap off steering wheel
- s2 rs turbo oil leak from head cambelt side, HELP!
- fuel line size
- mk3 16i TD conversion
- XR2 Hub Centres
- identification question???
- Cossie 4x4 boost problem
- Mondeo 51 TD Problems
- electrical connecters for loom
- mk4 zetec
- timing up a 1.8 or 2.0ltr zetec
- Zetec under piston oil spray jets *pic added*
- catter with dumpvalve
- cosworth 4x4 oil pump
- Zetec misfire
- Weber Twin 40 Carb Help
- 1998 Escort 1.8Si Zetec - no start after HG change
- FSE Fuel pressure Zetec
- Ford Focus 1.8 TDDI Injection Pump
- Query from South Africa
- what oil to use in my fiesta rs turbo
- petrol guage
- efi turbo
- Changing loom in a Escort Cosworth
- Mk4 zetec conversion
- Hydraulic Rear Disc Setup using Mitsubishi Brembo's
- Fitting a kent engine into a cvh mk3 escort.
- ARP rod bolt markings
- ERST S2 Backfiring and possible Overboost? NEED HELP ASAP :D
- Kevlar guards
- can directly replace dash board sapphire Cosworth 4x4 x display st8100?
- Focus rs brembo under 16" wheel's
- ECU pinouts and IGN retards
- 1.4 Zetec - Cambelt loose, worst case scenario???
- How to measure piston pocketing???
- rounded bolt removal
- ka
- zetec turbo
- Hot starting G reg Xr3i
- Just a small Q!!!!
- Help with Clifford Concept 50
- 2.8 v6 sierra
- simple swap?
- frst starter/flywheel?
- mk4 zetec
- ST170 valve float
- ST170 engine manual
- strange thing happened
- T34 Turbo removal
- focus zetec turbo conversion
- **indicater issue with audi tt help**
- Cossie wheels on fiesta turbo ???????
- Xr3i Van conversion - HELP NEEDED!
- 2.3 16v I4 Engine.
- Urgent help needed, Fuel tank/swirl pot
- xr3i edis module will it work on ofab?
- Plzzzzz help
- bonnet popper
- mk 6 fiesta
- lost red key
- 1.8 zetec carbs
- breaks
- cvh efi engine.
- ST200 remaps
- running problem mondeo tdci 52 plate
- stupid clifford alarm help please???
- some advice please
- cvh dizzy
- cvh efi compatability :) help please!!
- RST EFI Questions
- Anyone Know Anything About Audi 1.8?
- T5 gear knob - 10mm or 12mm ????
- Engine breather & PCV trouble
- Focus TDCi Idle problem - too fast
- 2001 Fiesta 1.8 Endura Td - Fuel Pump Failure
- cometic head gasket any good for sieera cosworth?
- mk4 efi escort sounding like a v8
- emerald ecu maps ?
- Fiesta RST Inlet manifold question
- Symptoms of blocked/damaged/no breathers??
- mk4 fiesta pedal box into mk2
- st170 box on a zetec
- st escort cos sparkplug cover
- Gear box
- ZVH RST Running Problems
- supercharging a focus
- wiring diagram needed help!
- Pistons
- Thermostat
- I dropped a hub today and broke a lug mount
- removing an alarm & imobiliser
- 1.6cvh + 6 speed st170 gearbox...
- clifford concept 450 g5 mk1 i think
- help, advice, opinions il accept all
- RS Turbo Single Wiper Conversion
- Cosworth auxilary pulley bolt size
- Crannking voltage
- another radio code thread
- Smoke ring's on idle
- Plz hellp my car is doing my head in
- power steering on fiesta mk3
- problems yet agen!
- head gasket???
- ofab not working
- Which head
- Saph dash
- Anyone know how to time rs turbo correct and firing order, won't start
- s2 rst boost problems
- Turbo to Airbox Pipe help needed for 2wd saph!!??
- hesitating
- Wrinkle paint
- turbo boffs
- Mk5 escort engine transplant
- Focus MK1 Head Unit Issue
- rs rear beam
- escort rs turbo starting problem
- Escos tb onto sapph
- Pectel P8 engine loom
- focus rs over boost problem...
- efi curious
- 1.3 fiesta running poblem
- mk6 Escort van heater matrix
- Stage 2 on a t2
- Best plugs and leads for a ST170?
- Refurbing wheels?
- Mondeo misfire
- Cossie valve heights
- Convert escort van to td
- fiesta (zetec) clutch problem
- smoking turbo diesel
- ecu problem
- smoking 2wd cossie help
- cvh oil pump ?????
- zetec head question...?
- XR2 door poppers
- head unit / cd player wiring
- RS Turbo ECU Help
- Escort, What carbs to go for??
- Removing Rear Piston From Caliper
- 4x4 saff misfiring
- Can any one help
- 1.6 cvh into a 1.6 cvh turbo
- Help with exhaust fitting
- Are these 4x4 or 2wd cossie brakes?
- 2.0 conversion, PATS help
- mfi converting 2 efi .. core plug??
- Heater probs
- please help..xr2i 8v fuel pump on any other ford?
- Carb CVH Compression ratio
- xr2i horn relay????
- Same Fuel Pump As A Xr2i?????
- is there such thing
- Couple of questions about running gear...
- problem on 99 fiesta
- gearbox ratios
- fuel pressure
- Horn relay?????
- fitting a window
