- EEC Problem
- zetec head swap??? HELP
- RS1600i rocker cover fitted to XR3i engine
- mounting a damper upside down. problems?
- Mk6 Escort Steering Wheel
- cosworth fueling
- I must be going crazy..
- Smoking on boost...
- mk1 escort
- Cosworth 4x4 downpipe onto 2wd exhaust manifold
- New Mondeo Diesel Filter
- Focus timing belt issue....
- sapphire cosworth hubs
- Name that boss!
- Focus start up problem
- Focus electric window problem
- zetec turbo timing
- zetec cam followers
- can u fit a mk4 5 or ka endura engine to mk3 fez
- info needed please help
- Zetec FPR
- Ford TIS Download
- Zetec Engine Gurus: Piston/Head Contact
- Spline Count for Me Please
- granada immobiliser
- Creating an hybrid BC/IB5 gearbox
- Help 3 door boot wiring
- oil
- YB 3DR Head problems - Advice Needed PLZ
- focus rs brake pad query
- 1.6 cvh running hot
- zetec wiring loom into a mk3 escort
- 2.0 zetec and st170 rings
- mfi + efi + management = headaches (Help!)
- RS Turbo ACT sensor fitment
- rs turbo head gasket or piston rings
- CVH EFI powered Westfield
- ARP BOLTS
- smoking cosworth
- Sierra module???????
- 2wd rear diff ....problems...!!!
- Saph 4x4 Fuel Pump Re-Wire
- 3dr Sierra mirror glass removal?
- zetec turbo problem
- Ka running poo please help!!
- help with bike carbs on 21cc pinto
- Air Injectors
- help
- turbo
- brake problem
- st170 vvt question
- Wheel Offsets
- s2 escort rs turbo - no spark at coil
- Rear seats removal on xr3i cab - problem
- can anyone help
- Suspension?
- Is anyone on here any good with omex
- XR2i 16v.... fan switch....keeps blowing
- mfi - efi conversion
- Any difference between 2wd and 4wd hydraulic lifters???
- yb question
- CVH Pistons
- locking wheel nuts?
- Injector Cleaning Aberdeen/Edinburgh- Where?
- Help with mondeo
- escort efi jolting while driving
- 4x4 conversion
- 2wd and 4x4 cossie jack shaft assembly.....
- cvh poor starter when hot
- turbo & injector help??? please
- looking at a new car
- S1 LSD on MK4 gearbox??
- Running Problems
- Fitting MTX75 Gearbox to mk6 escort van
- Cosworth 2wd oils
- fuel pump wireing, what amp cable to use??
- Starter Motor switched live feed.
- oil outlet (in block) fiesta rs turbo
- RST Powered Westfield
- esc cos front drive shafts
- FRST Gearbox?????
- Any mondeo diesel experts on here
- sierra xr4i
- Cam/crank sensor
- brake pressure problem on mk3 escort
- rs tubo rear disc conversion of rs 2000
- zetec turbo compression
- have i wrecked my turbo
- Ford puma headgasket
- Injectors
- rs 4 spoke steering wheel
- fuelling
- Fiesta Mk4 Cambelt change?
- electronics/relay experts help needed!!!
- loose baffles.
- FRST Missing
- cosworth head on 2.1pinto block
- What this thingie for? (airbox 1.6 xr3i EFI)
- ZT Lots of oil coming out of breather pipe
- 3 door fuel pump wiring
- STILL got a strange noise on the puma
- HELP Power steering not working i think?
- Cosworth Fuel pipes
- weird noise focus st
- RS Turbo metering unit air flow sensor
- Sierra Coolant level sensor
- v6 cosworth conversion xr4i
- Oil temp sender for a CVH - Where to install?
- 300bhp Cosworth advice
- Escos running probs small turbo
- Spark plug problem for a Zetec E-based engine!
- escort rst problem
- Cooling Fan dead on Mk6 Escort 2.0? HELP!
- MTX75 FWD Gearbox CWP Ratio's ???
- crank position sensor location problem
- sierra 2wd abs pipes
- repiping mk4 cab brakes after abs removal
- Cam timing with VVT/VCT
- OIL PRESS
- Sensor thingy ?
- Which brake pads?
- black smoke with a puff of white??
- escort turbo into xr3i cab conversion
- rs turbo s1 engine stalling
- Zetec Turbo How Much Boost?
- Ford Focus Titanium
- st170 engine mount bracket
- Tuning my Xr3i efi (mk4) ?
- Cossie solid lifters
- Attn Weber sidedraught experts!
- Fiesta.....puma
- Nissan primera head gasket ?
- zvh turbo smoking?? video
- st170 mounts
- Flashing Light on dash bored :(
- New Disks & Pads = Brake Squeel
- 1.8 zvh turbo fiesta wont spark
- juddering from engine bay
- cossie management on zetec turbo?
- focus 2ltr running prob's..
- 2wd or 4wd pistons cosworth
- How to remove snapped wheel studs from the wheel hub
- morette quad headlights needed escort mk6
- Zetec help needed PLZ
- fiesta zetec s ZT
- How to Identify Car part numbers (Ford)
- Sierra Cosworth 4x4 Rear Wheel Bearings
- needing your help please :(
- fuel starvation around corners
- Focus RS Engine into Mk6 Escort??
- do i need different rear braided hoses on my escort?
- escort van 99 on a t
- eec iv versus 4x4 plenum
- Escort mk4 rev counter installation prbs
- atlas axle strip down HELP
- sierra shims?
- escort rs turbo dodgy eletrics
- rs turbo tuners in or around manchester
- fly wheel
- escort s2
- need help:wilwood kit+rs2k rear disc FRST
- zvh head bolt torque settings
- High Idle - Fiesta Si
- escort van t plate 99 not sure if mk 5 or 6
- no spark on efi
- Misfire On 2.1zvh
- 3i fuelling
- turboing a 3i
- im in need of a cvh guru
- Hello passion ford, help!
- head gaskets and head bolts????
- escort gti steering rack
- mk2 Escort Mexico Wiring problems
- rods + pistons for st170
- coil pack on rst !!!!
- servo hose
- Removing a Focus RS Driveshaft
- timing help
- 2.1 ZVH Head gasket and bolt options???
- Saph Cosworth 2wd Diff fluid & gearbox fluid ???
- 1.8 duratec he
- Sport ka issues
- head querys
- Rear panel for Sapphire
- FAO engine tuners - spark map advice needed.
- 4x4 wheel offset
- cozzy 4x4 to 2wd
- Escort RS Turbo Starting Problem And Oil in the Intercooler
- xr3i mpg?
- water cooled turbo plumbing??
- Sapphire Cosworth Rear Shock Question
- Series 2 RST clutch and flywheel on mk2 XR2?
- escort back box
- Sierra Cosworth T3 Turbo Housing (cracking)
- secs s8
- mk4 escort rear inner arm bush
- stage chip graham Goode "l2v2red.mot" ?
- swirl pot lift pump......
- escort mk4 bolt on wing conversion
- t3/t4 turbo on a 1.8 zvh?
- Final drive ratio
- co2 adjustment
- My Gearbox in my mk3 escort rs turbo cabriolet has gone.......
- Escort MK6 Convertible Relay? Fault Finding
- I need info for The gear ratios for Front wheel drive
- Help identifying loom connection
- cossie brakes on escort mk4
- t3 refurb
- 3dr or 5oo head
- cossie oil
- 5bar map sensor for omex 600
- escort stuttering spark plug gap??? help???
- torque settings needed
- Coswoth smoking .......
- stupid question
- Focus ST brakes on a 1.6 Focus
- help with fiesta mk3 xr2i 1800
- st170 head?
- Cosworth conversion
- whining sound
- rover injectors 220 420 820 800
- help needed s1 ecu colour codes
- abs problems
- cab suspension
- Sierra mirrors....
- Midlands garage to set up my series 1
- Escort Mk5 Cab problems
- Series 1 RST Turbo advice
- mondeo v6 ghia radio
- HELP - XR2i 16v rear brakes
- Slicks on 18s
- ignition timing erst
- quick brake question need urgent answer
- how can i ???
- fiesta coswrth brakes
- mechanical tempeature senders
- this may sound dum
- 6 Pot or 4 Pot..?
- Airbag Contol Module Replacement
- HELP.. Adjusting Torsion Bar
- s2 rst probs
- zetech clutch
- IDS when did it come into play?
- throttle position sensor voltage
- Type 9 box - replacing gaskets
- zetec revvvvving
- st170 problems
- porting / polishing
- N/A tuning zetec
- escort mk 4 van project
