View Full Version : Technical help Q & A
- cossie fuel saga continues! pump and map sensor today..
- someone please help
- mk3 frst wheel spacers???
- series 2 escort turbo ecu fault??
- 1.8D and TD wiring??
- how do i identify what ecu + chip my 2wd saffy is running ?????
- 3dr cosworth solid brake pedal
- turbo management
- xr4x4 head bolts
- Xe Pistons in silver top Zetec turbo..
- wiring ppl good with relays - please advise.
- FRST Fuelling Problem. Help Needed Quick
- mk 3 escort rev counter help
- heater resistors and rev counter
- black top zetec bottom end issue's...
- i want lsd on my escort gti help anyone
- wiring help please!
- 2litre zetec bottom end on to cvh head?
- escort dashboard problem
- mk3 escort rev counter help
- Small end conrod bearings?
- atf
- Focus RS blue smoke
- cossie 4wd oil pump cracking??
- Can someone answer a fer questions please??
- escort mk3 altenator bracket.
- what throttle cable? xr2 in to mk3
- Help someone please-broke my Mk4 XR3i!!!!!
- ECU weak voltage on L8 with lights and fans ON
- Help to identify a diff please
- Escos Rev Counter
- Escos vs sierra brake hoses. Interchangeable ?
- wires to fiesta rs turbo fuel pump relay
- Pistons and rods for Zetec Turbo
- mk3.5 fez brake upgrade?
- fez xr2 or scort xr3 not i questions **more added**
- Standard Coorporate Protocol (SCP) and EEC V
- Idle problem
- 54reg ford focus C-max TDI air con fault
- Help Needed no spark cosworth 2wd
- clocks reading wrong!
- Faulty Cat
- St170 full conversion inc. standard ecu
- really need forged pistons?
- Where do these hoses go??
- low comp rst engine
- half moon seals leaking
- Mondeo 1.8td noisy tappets
- track car help
- Alternator charging question:)
- Radiator Fan Problem!
- What is the way out of this trap?
- B&m quickshift on a mk2 xr2?
- 2.3 YB
- Pf01 and Pf09 Throttle Position Sensors
- Mondeo TDCi 2004 turbo help please
- Distributor timing on cossie
- Escort si loom and ecu to megajolt ?
- ST170 Sump Gasket Replacement?
- rattling actuator/worn linkages????
- Low oil pressure
- !!HELP 1.8 N/A ZVH --> 1.6 carb conversion HELP!!
- strange hissing on tickover on v6 mondeo
- Mondeo 1.8TD normal temp?
- Escort gti water pump
- a whole shit loads of problems came up tonight
- RST2 Engine cut out help pls
- is changing a front pinion oilseal on a 7.5"diff hard?
- xr 4x4 2.9 miss fire???
- Sierra fuel guage problem
- is a cossie t3 on a frst laggy
- Route of auxiliary drivebelt Fiesta 1242cc
- Head Gasket Mondeo ST200
- Turbo Query
- HELP, Fiesta Zetec 03, 1.4
- mk5 escort lighting and fuel pump problems
- cleaning idel control valve
- What is this for please?
- 2wd sapphire
- volvo rear discs
- Zetec turbo holding boost problem
- What gearbox fluid ?????????????
- arp rod bolts..re-use????
- Focus 1.6 breather probs
- What turbo is this....m27 garrett.
- help needed! engine wants to die when braking
- zetec turbo advice
- Coilover conversion kits
- YB rebuild questions
- MIL eliminator FRS.
- help urgent diff ratio needed...
- which engine oil?
- 2.0ltr Zetec-E head bolt torque settings?
- focus pillar pod
- 2wd clutch problem
- 2.0 Zetec Dyno / RRoad Graph
- zetec (sefi) firing order please!!!
- Can you help??
- 2wd cos fuel pump low voltage
- 4x4 saph to 2wd... steering rack
- Zetec Head Gasket Question
- 2wd oil dip stick tube?
- Wich brakes ? Need opinions
- 2wd saff questions
- Second opinions needed please
- Zetec + pistons
- aeroquip adapters dimensions for 200 YB block
- ton of oil round spark plug 1
- Electric Choke
- Cosworth 2wd keeps pressurising after 3 rebuilds help urgently needed
- temp sensor problem
- zetec loom help?
- differance in st and standard mk1 focus brakes?
- Help needed for rough 1.6 xr2 cvh
- how to set up EBOOST 1
- Complete DIY's on starting, charging, engines, trannys, etc.
- J&S Safeguard
- Rs turbo S2 fuse box
- what size nut is the centre hub bolt on a 4x4 cossie?
- fiesta turbo idle/running problem
- cossie 8000rpm standard rods
- Radiator clearance for T3, FRST
- Zetec Cylinder Head issue help please.
- fuel pump supply hepl!
- Zetec Turbo
- Scorpio cosworth 2.9 ECU
- frst efi fuel pressure regulator
- rs turbo prob
- SHEER INSANITY! Please post leniantly :)
- Fiesta Rs Turbo Engine
- Car loom help
- Fixit 4x4 gearkit
- Fuel pressure reg. o-ring, same as injectors?
- 24v cosworth to carb?
- Weres the feul pump on mk6 gti plz help
- 2.0 zvh spark plugs?
- uprated fiesta turbo intank fuel pump which 1
- rs turbo valve problem running crap help!
- ffs turbo this time
- temp gauge faulty ?
- Fiesta Tachometer
- mk6 rs2000 starting problems
- water rising in header tank!
- escort cossie fuel pump
- identifying cossie 2wd ecu????
- rs turbo running crap HELP !!!
- Cossie 4x4 front driveshaft oil leakage
- cosworth fuel pressure...saga continues
- help please anyone mk4 escort fuel pump zetec/efi
- VEMS wideband AFR
- MFI XR3i Fuel Pump Will Not Run!!!
- efi reverse charge pipe
- cossie throwing a rod!!!! ford fare victim
- saff 2wd engine spec suggestions.
- Engine not running properly
- what clutch for s2 turbo engine on mk2 xr2
- Help!! Mondeo ST220
- Petrol Smell all the Time !!
- 91 RS2000 Handbrake Pads?
- mk1 fiesta 5speed
- sierra coilovers or not?
- plz plz plz HELP
- temp problem
- whats this ???
- series rs turbo
- help 2 stage boost
- Cosworth 2WD abs light stays on
- best way to change fuel pump on mk6 escort
- Modify P8 ECU
- Mondeo air-conditioning woes
- fiesta zetec-s to st conversion, urgent info needed
- Escort Cab Conversions & Modifications
- 1991 MK5 Escort Van Sideskirts??
- Duratec V6
- FRST - Failed its MOT, please help :(
- problem starting xr3i efi convertable
- My rad fan wont work
- very confused
- Cosworth yb hydraulic lifter problems
- green 24v capri, looking for owner
- Cosworth 24v head gasket
- Help! pls Escos
- help!! cosworth seats in mk6 escort van
- help needed pls
- escort t3 smokey
- 1.8 0 st170 conversion help needed
- 2wd saff wont start grr
- so what else would stop it from sparking?
- endura diesel
- what else could it be!
- im a twat
- st170 gauges
- please help its driving me mad
- alternator difference 4x4 / 2wd
- What Head Gasket and Head bolts should I use?
- Smoking cossie
- fuel regulator
- turbo or stem seals? escort s2 rs turbo
- 2wd t5 5th gear
- s1 wont restart!!
- zetec turbo keeps springing water leaks, breathers issue?
- What adhesive to re-fit roof lining?
- top class sierra
- Water proof ECU cover?
- ARP head bolts
- Which ECU??
- Clutch Cable removal
- Battery Light Issues
- samco
- Oil Pump - which one? EsCos 4x4
- BIG REQUEST - Pinouts for a 1.8 zetec ecu (SLUG)
- Checking for air leaks?
- Injectors have no power Help please
- cosworth 2wd t35?
- rev counter coilpack !!
- escort rs turbo help
- revs issue when changing up the box
- Saph 4x4 fuse box diagram
- Removing Swirl Pot...
- 1.3 CVH Cam/timing belt problem.
- cosworth high rpm misfire
- Zetec conversion help..
- RS Turbo Mayonaisse
- excessive fuel useage...
- mondeo mk1 aftermarket stereo help!!
- cossie problems
- Focus RS Mk1 Cat (flexi join) issues!! Help!!
- orion owners.do saff cosworth front and rear seats fit in easily?
- Focus 1.8 Zetec really slow,
- Ka
- Fiesta Heater Circuit Component
- tyres on my escos wheels
- YB Exploded Diagram...
- rst engine ito a mk5 cab
- What stage is my ecu--with pics
- st200 gearbox
- air temp sensors
- ford ford 1.8 TDDI wont start
- Rs turbo oil
- fitting pro alloy intercooler
- New turbo
- S2 rs turbo stage one
- transit connect air con ???
- wheel fitment
- escort mk5 hubs onto mk4?
- focus headlight conversion... sorted found a simpler way.
- 2wd Cosworth not firing
- Cosworth Exhaust valves
- Water injection system Escos
