PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. cossie managed zetec turbo???
  2. cosworth trying to start but wont?
  3. rs turbo tps help needed
  4. RS holding back between 2-3k
  5. Turbo vacum help
  6. Running problems
  7. help!frst blue smoke
  8. bad fuel
  9. oil filter HELP PLEASE
  10. cant get brakes working!
  11. exhaust gaskets
  12. mfi engine, rev gauge help.
  13. ST200 idle speed up/down
  14. focus st2
  15. Turbonetics E46: Does it need an oilfeed restrictor, and if so: What kind ?
  16. Ford Focus exhaust manifold/cat
  17. little escort won't start!!!????
  18. escort mk6 van lowering springs
  19. 1.6 zetec to 2.0 zetec whats involved
  20. rst van project, power to fusebox question (pic)
  21. gearbox ?
  22. knackered servo on s1??
  23. escort rs turbo
  24. 3rd time lucky
  25. Cosworth ABS ECU
  26. how much bhp from this spec?
  27. 2wd turbo heat shield needed??
  28. zetec turbo help
  29. Cosworth 4x4 Head Re-Torque
  30. ACT sensor causing misfire !! YB, 2wd
  31. focus tdi wont select 1st or 2nd gear
  32. orion rear brake lines same as escorts?
  33. Fiesta TDci air in fuel
  34. escort cosworth with liners what head gasket?
  35. oil catch can-to atmosphere or inlet?
  36. Sierra Propshaft
  37. Help. Please. Cosworth headache.
  38. Difference between 1.8 and 2.0 blacktop cams
  39. I don't have swine flu.
  40. mondeo zetec 20l poor pick up?
  41. what plugs small turbo escort
  42. Mondeo Fuel Cut Off Switch
  43. A plea for help from the Cosworth Uber Guru's on PassionFord...
  44. escort mk3 5 speed conversion
  45. dash light prob. 4x4 saph..
  46. my engine bay, anything diff?
  47. is this an ECU?? if so what type
  48. mondeo zetec central locking
  49. traction control arm bushes from 4x4 to 2wd???
  50. whats best supercharger or turbo?
  51. MFI XR3i to EFI RST conversion
  52. oil pick up question....
  53. Mk 5 Cabby Rear Speaker Replacement
  54. B+M fitting probs
  55. cossie alternator pulley removal
  56. How to convert all TOD, MOD, MKV, FLV, AVI, 3GP, etc formats of video/audio for Mac
  57. Mk 5 XR3i Cabby Clock Removal Problem
  58. gearbox fouling rollbar escort mk3 help
  59. Rs turbo series 2 headlights
  60. Fitting a 2.0 blacktop zetec engine??
  61. Cossie rep, few problems.
  62. engine mount problems
  63. 2LTR ZETEC ONTO bc/ib5 GEARBOX HELP NEEDED
  64. focus rs 2003
  65. lowering the rear of my connect
  66. 99 Escort LX SOHC fuel filter replacement
  67. rs2000 engine
  68. how do you fit 4x4 prop bush correctly
  69. Spec-ing cams?
  70. problem with kms ecu
  71. Escort mk5 xr3i rad fan wont kick in ?
  72. 2wd cossie dizzy drive timing ???
  73. my rs turbo feels hesitant when it begins boost...?
  74. help! main beam wont work on my on my mk2 orion
  75. Brake upgrades - 4 pots, Pedal Box's and Biasing
  76. exhaust clamps
  77. RS1800i ABS - How to disable
  78. oil getting into the water ?
  79. R&D 6 Speed Dogbox - broken 3rd time
  80. Cosworth 4x4 power
  81. Rich smell from 2wd saph cosworth
  82. 24v conversion into a cossie. help please
  83. urgent help please!! who has a ybp engine with a 2wd sump
  84. Sierra 2wd Ignition coil?
  85. Mk2 Orion/Mk4 Escort Knocking in Reverse!?
  86. electrics playing up
  87. Airtec single pass intercooler S2, question?
  88. my erst cab...not starting..
  89. Mondeo mk1 rear disc conversion
  90. oil cooler
  91. What do cvh worn shells look like?
  92. crank regrind cvh
  93. CVH Low Oil Pressure Help Please!!!
  94. rs turbo firing order ?
  95. zetec loom
  96. chip swop
  97. Mondeo st tdci
  98. xr3i mk5 wont start (help)
  99. Driveshaft leak ?
  100. rs2000 looms mk5/mk6 the same? PATS
  101. bypassing PATS on mk6 rs2000 engine
  102. FRST starting issue
  103. Front wheels out of center
  104. sierra 2wd cosworth wiper relay
  105. XR4i drive shafts?
  106. mfi fucked or not please help
  107. 3dr Sierra Front wheel bearings
  108. fitting a 2wd sump on a genuine gasket should i use sealer?
  109. Ka ECU problem?
  110. ST 225 power delivery has gone strange
  111. rs2000 turbo or rs2300 turbo? whats better?
  112. which adjustable cosworth fuel reg for frst
  113. mk 6 van exhaust problem
  114. 2wd propshaft....
  115. mondeo engine in a tiger cat e1
  116. What turbo have i got
  117. need help with st170
  118. Radio problem after jump starting
  119. How does an external wastgate work?
  120. Starting problems
  121. fuel flap release
  122. zetec conversion in mk4
  123. bluefin chip
  124. Misfire
  125. Cam Bearings
  126. 4 to 5 stud conversion adapters
  127. How to put 5th gear back on?
  128. ZVH Problem!!
  129. st170 dual mass flywheel probs
  130. Turbo Splutter
  131. RS Turbo problem starting when cold
  132. Mk4 escort starter motor problem
  133. Cosworth loom experts. Cosworth managed RST.
  134. s2 rs turbo starts fine and boost well but as it gets up to temp it struggles to idle
  135. rs turbo no fuel from metering unit to the injectors ?? please help
  136. S2 Missing rather badly....
  137. 3door brakes stopped working!!
  138. NOISE
  139. exhaust manifold
  140. Hot ecu and coil?
  141. help needed rs turbo s2
  142. has anyone
  143. Urgent help needed KE Metering head
  144. 4X4 dash
  145. Power steering rack?
  146. rwd cvh turbo
  147. Juddering Fiesta
  148. escort s1 problems
  149. MK1/MK2??
  150. St170 hubs
  151. RWD rear mounted engine advice
  152. Pulleys for a 4x4 Cosworth
  153. how many volts should i be getting?
  154. zetec sierra help
  155. ignition system with Haltech E8 ecu for YB
  156. cam belt
  157. Help! Sheared off locking nut key!
  158. steering problem
  159. Car Security companys
  160. mondeo shocks
  161. Cosworth 044 fuel pump loom
  162. Fuel pump relay bridged
  163. Information needed
  164. clock shorted wire causing grounding problems
  165. XR2i 16v clutch pedal problem
  166. 98 escort 1.4 cvh idoling problem????
  167. Coil on plug conversion
  168. help with zetecing my mk2orion SEV
  169. cat 1 alarm
  170. comps, 15" 8j grp A
  171. Question about lower arms
  172. Possible rebore?
  173. Ford radio code needed pretty please!
  174. zetech to turbo
  175. Erst fuel line size??
  176. Duratec 2.0 HE - Ignition MAP
  177. what else could it be?
  178. Cannot Remove 5th Gear with Puller
  179. tuning rs2000 to a budget. what/how? carbs?
  180. Cosworth ABS
  181. how hot is hot
  182. mistifying KA overpressure cylinder problem
  183. Ford Focus Zetec 2001 X Reg Broken Cigarette Lighter Problem Help Please
  184. rs turbo electrical wiring problem
  185. tuning people help
  186. 2wd/4wd sapph inlet diffrence
  187. xr3i to rs turbo conversion
  188. air con focus
  189. Converting Mk6 etate to rear discs
  190. Centre bush in propshaft
  191. aeroquip fitting size... need help quick!
  192. starting problem plz help
  193. interior change
  194. 2wd cossie problems...
  195. Drum to rear disc conversion - mk1 focus 1.8
  196. saph cossie 4x4 to 2wd, gearbox mount??
  197. temp sensor
  198. body pannels
  199. diff question?
  200. Educated me!! Sierra shell differences??
  201. please help!
  202. Gearboxman big tooth kit - Noicy
  203. possible pinging/pinking/pre-ignition
  204. green stuff brake pads for escort rs turbo any good?
  205. st170 head on a 2002 focus zetec
  206. What group??
  207. removing the thermostat - Focus RS
  208. Mk5 RS2000 sump. Is it the same bolt pattern as....
  209. rs turbo fuel pump relay
  210. Escort 6 Problem
  211. st170 juddering probems
  212. CFM cams and pulleys
  213. gear ratio's
  214. Intermittant ABS issue
  215. rs turbo engine
  216. galaxy tdi loosing power
  217. p1520 intake manifold runner control circuit malfunction
  218. Focus 2.0 oil pressure
  219. mk5 zetec s 2ltr conversion help
  220. 2L fiesta si hesitation
  221. Alternator Noise Through Speakers
  222. What sort of power
  223. 4x4 Cos Revs counter jumping
  224. Harmonic damper on Cossie engine
  225. turbo is not well
  226. brake help-st170
  227. zetec engine ques
  228. Painting stainless steel?
  229. mk4 escort efi and mfi heads and cams....
  230. Escort Mk6 brake bleeding question
  231. escort rs wont fire up!?!?!?!
  232. Motorsport Developments
  233. Ported and polished 1.8 zetec head
  234. 2wd saph into 4wd
  235. finis code
  236. HELP ABOUT Sapphire cozzy 2WD rear diff ..
  237. 200 block
  238. Mk4 xr3i efi - "stable" idle with dismounted IRV!?!?
  239. my xr2i wont start
  240. gearbox will it fit ?
  241. 2001 Ka Ticking, Clicking Noise Which Increases with speed!
  242. 600bhp clutch
  243. mk4 fiesta si rear brake problem
  244. Zetec engine quest - can you fit??
  245. granada parts question
  246. pinto swap for cvh
  247. Ford radio codes
  248. Rod advise for 2.1 ZVH and CR calculations.
  249. Rs2000 4x4 as a track car???
  250. CVH Engine Removal Advise Please
