- Fiesta Losing Water????
- Can you fit power steering to capri?
- Flywheel lightening
- focus ST engine into fiesta ST
- Escort van tow bar
- bloody banjo, help!!
- Focus TDCI sport Flywheel problems
- escort gti mk6 wiring help
- ka wont start
- car cutting out after few yrds then needs jumpstart
- Where is the fuel pump located on a Fiesta RS?
- weight. zetec se VS zetec-e
- Which Uprated Clutch for 20psi?
- Lumpy Ford
- rear brake shoe auto adjusters
- 1997 ford fiesta wiring colors
- Escort van bulkhead
- radio keeps changing stations by itself
- fiesta 1.4 tdci smoking
- series 1 rs
- 1st time removing a cossie 4x4 engine help:)
- Maximum Size Battery
- spot the fault
- idle control valve
- timing belt help needed
- RS2000 4x4 rear brakes
- The big suspension problem
- boot light just wont work really annoyed
- mondeo mk3 2002 central locking problem
- How's the fuse box fixed on MK3 Escort?
- 1.8 Endura Diesel Injectors
- zetec into a ka
- what handbrake cable for a rear disc conversion on a frst??
- mondeo st
- escort 1.8td pump problem
- escort Mk4 Mk5 clutch??
- ofac on focus
- boost
- turning xr2i engine into a turbo
- Headlights
- Down To earth
- any one got a idea of bhp
- head gasket and boost
- escort loss of power
- Hi Spec Motorsport + 17" wheels...can they fit in?!
- Torque settings for head arp's
- Zvh how to?
- 2.0 Focus engine
- Speedometer drive gear sought
- Spare Wheel Jack
- 1.8/2.0 zetec into a mk4 cabby
- WANTED fiesta rs turbo engine with ofab loom and ecu
- wanted xr2 mk2 carbon door cars
- Rewire radiater fan ???????
- Fitting a 2.9 cosworth engine into an escort
- Invisible moneys
- Can I use 2WD engine loom?
- Escort RS2000 MK6
- breather system and volt meter
- 2.0 Zetec injector flow rates
- Fiesta t3 conversion question?
- Escort van heater probs.
- ECU id????????
- s2 cps
- will rs2000 mk6 springs fit on mk5???
- boost controller
- Recaro seats
- full service s2 erst
- oil leaking into sparkplugs
- breather fitting on a 4x4 saff???
- piston rings
- help!! need oil pump info
- Nos on zetec
- Intercooler
- 403 injector fitting with MD chip
- suspect faulty ecu! any ideas?
- Forge dump valve probs!
- Fitting a CD player to my MK4 Escort.
- escort van
- Ford StreetKa 'squeak'!
- iveco 2.3 16v 2003 won't start
- Air injectors
- 1.8 gti cams
- couple of little prob's with my saph.
- 1.6 zetec flat spot
- hi all
- Zetec ka conv.
- alloys?
- front bumper removal?
- 3dr cosworth ecu what chip
- turbo problem after oil change (boost)
- escort mk4 van rear hub WANTED!!!
- Focus Door Card Removal / Central Locking Issue
- ST170 Injector Flow Rate
- Line-lock?
- turbo removal how easy is it?
- Mk6 Escort Finesse 1.6 Zetec wont rev past 4000
- Not a problem but help needed
- 3dr clocks problem
- wasted spark wiring help!
- Mondeo Alloy Wheels
- fiesta mk1. How do i remove the tank
- Which coilovers
- mk5 to mk6 recaros
- Misfire on boost
- My fecking ecos again
- Help needed with Ford Escort RS 1800 rally car build
- Smoking 2wd Saph - Turbo or Valve Stem Seals?
- Ford fiesta mk4 air con?
- lethal xr3i. sliding all over shop
- TT t2
- bmw e46 removing exterior door handle
- Cologne (Pinto) 2.0 to Essex 3.0
- ford escort help
- Fiesta Possible Overboost Air filter fallen off
- Need a Fiesta RS Turbo Cone Filter ASAP!!! Blackpool
- bike carbs or bike tbs??
- MSD direct fire kit...
- Will H&R spring kit for mk3 xr3 and rs1600i be ok to use on rs turbo?
- Help p100 rear disc conversion
- how do i install a boost gauge ?
- What should my piper vernier pulleys be set at??? Help!!!
- Stereo Wiring Help Required Mk5a Cab
- handbrake cable not releasing once handbrakes off
- replace steering wheel
- 1.8 zetec problem
- oil smell
- rs turbo HELP
- rs s2 turbo
- rover radio code
- Essential Mods/Upgrades for Fiesta RS Turbo
- 1.8 16v zetec
- fuel pressure test kit 1-7 bar
- ford mondeo auto gearbox
- better performance out of a 1.25 zetec fiesta
- random wire
- Uprating my fuel pump what is best?
- 2wd cosworth pinion gears - scorpio ??help
- mondeo tdci wont start on cranking
- Can't get a set of bilstein dampers for my rs turbo so what other model can i use?
- alarm
- mk4 escort steering column/judder under braking
- 2005 1.3 SOHC Ka Heater Problem
- cosworth oil pressure
- how do i turn the diesel pump up on my escort van???
- Heeeelp fuel pump won't prime :-(
- efi idle problem
- How do you identify the difference between a 2wd and 4x4 dip stick.
- Refitting Fiesta Turbo Flywheel.
- Have i been sent the wrong thermostat? *update*
- RST KA
- tps sensor
- Oil in my water ! !
- light problems????
- Random Wire
- Fuel Pump Difference
- Setup / Adjust VNT
- Escort rs turbo engine rebuild
- Mondeo TDCi estate making unpleasant noise
- rs
- CVH EFI Cam
- replacing fiesta air filter, simple "i dont think so"
- EGR Valve Location (Focus TDCi)
- zetec tubro help
- Wiring diagram needed!!!
- set up TPS
- starter motor
- cosworth 2wd brake clips
- electrical problem
- 1.8 Endura Turbo problem...
- Quick release, and i need QUICK answer:)
- no pressure at cailpers ect?
- Heater control knob Rheostat cicuit broken Mk4 Fiesta
- mk1 fiesta, xr4 brakes?? help plz.
- CVH water pumps
- zetec turbo help!!! please
- Sigma SG40 immobiliser and Toad C5T2 Alarm...problems
- How to wire up a turbo engine in.......
- brake master cylinder
- Mk 5 Cabby Aerial Wires
- Pull to the right - Play in something
- xr3i cab losing power
- testing the fuel pump
- Fuel Pump
- Reusing head bolts
- Lowering Issue
- fuel light flashing
- 2 bar boost... how do i get it?
- ST170 Inlet
- Help Escort S2
- Wiring Issues
- RST S2 Door barrells
- Fault Codes What Now
- frst fuel down
- what are biggest brakes you can fit to rs7 spokes??
- rs 1600i cutting out
- Fiesta RS turbo Unhealthy running issue
- mk 5 rs turbo
- Fuel pump feed mystery
- 2040 CD player help
- draining coolant MK6 escort cab
- How to fix broken bumper bracket??
- Head Gaskets
- Focus ST225 ECU location
- Colour Help
- Mk 5 headlight de-tango
- mk2 mondeo lost key
- OZ Magnesium
- Buying an xr3i
- Small turbo escort cosworth rocker cover on old type head..
- fiesta rs turbo not running right
- RWD Escort Cosworth Prop
- Radio Interference
- Ka fuel gauge problem
- 044 pump fittings
- Escort RS Convertible hot start problem plz help
- 6000cd code - help please
- Focus 1.8 Mrk1 Sump Pan Removal ??
- Pectel Software - SQ6 Query
- Side Skirt Fitment mk 5 pre face lift
- Fiesta dashboard wipeouts
- turbo /water cooled can i use it without
- Thermostat Fitting
- st170 pipercross viper or k and n typhoon???
- MK5 zetec s Gear linkage - ????
- Brake help.
- cosworth idle
- 1.6 zetec valve stem oil seals
- Escort Van Springs
- problems with my escort 1.8 gti
- Tial wastegate...
- Timing chain Fiesta...Haynes manual be damned
- how do I remove a fuel line from a 99 escort?
- what is this problem cant get no revs at all
- power steering
- Uprated clutch for Saph Cós.
- Fuel Pump issues
- ECU HELP
- no battery or oil warning light
- st170 head
- co adjustin srew fooked
- Recondtioned Escort Turbo LSD
- xr2-xr3 suspension????????
- Removing Dump Valve
- Ford Folding Key - converting to Tibbe with PATS
- rev counter problem, help plz
- mondeo 2liter engine
- Air injector bracket
