View Full Version : Technical help Q & A
- Alloy Wheel Refurb/Repair
- rolling roads nr the midlands
- zetec 2.0 year 97': Arp main stud 151-5406, baffle I remove?
- Central Locking - Mondeo zetec 99
- Mondeo Estate Speedo Not working
- fuel pump wiring help
- girlfriends ka won't start unless i jump start it!
- cosworth crankshaft cog
- Any TDCI experts around, i put petrol in it
- need help please
- 4x4 sapphire convertion to 2wd
- CVH 1.6 and 1.9 Crankshaft Thrust Bearing Mod
- focus misfire
- how do i make a fuel pump relay?
- escort van electrics, central locking and electric window loom problem
- RS2000 rear brakes
- 2.0 zetec crankshaft pulley removal?
- ford granada scorpio m reg 94
- Can a 4wd thermostat be used on a 2wd Head??
- xr21 1800 tuning?
- new shape focus 1.5 vct water ingress in spark plug holes
- can a standard ecu be remapped on a xr3i?
- heater fan
- Zetec turbo not boosting..help!!!
- focus
- Which clutch for my 4x4
- MFI to EFI help....
- Zetec Turbo build
- rst van conversion help needed
- mondeo 2.5 v6 ghia x missfire
- amber warning light on a ford ka
- cant start my car
- mpg gauge
- bleed valves
- Help with engine management please.
- fitting a mega squirt to blacktop
- Track Tyre Decision
- quick question - coil on rst
- XR3I Fuel Tank Sender Unit
- Is Freezing Cold and I got No Heating Help!!!
- 95 Fiesta 1.3 cold start problem
- Is this manifold anygood for zetec turbo?
- cosworth rev counter fault
- amal valve missing i think ? help
- Fiesta Mk5 AP Coilover help!
- 8.8 grade M12 bolts - caliper bolt
- Ford Focus Vibrating Steering Wheel
- ragtop wiring??
- Zetecse engine main and big end tourque figures. Ford dont want to know!!
- 56 focus tdci alternator
- Xr3i Mk5 engine into Xr2i mk3.
- 2.3 16v plastic inlet on 2.0 16v
- t reg (99) escort van what oil ?
- ford mondeo fault !!!!!!!
- focus 18tddi
- Mk4 Escort XR3I EFI Smelling Rich!!!
- Ka brake conversion help please
- 02 sensor & Lamda....same thing?
- Found a bit of cast missing on my rs turbo head
- wast spark
- baffled sump for 2.0 scorpio engine
- engine swap
- Mt75 Linkage bushes
- s2 rs not boosting properly
- rain and 26 psi = cry cry cry
- Speedo Not Working
- ST170 Batt Light
- Can I drive without an ICV?
- cossie saph4x4 high idle & co%
- ST170 Engine Management light on P1518
- fuel regulator been tampered with, anybody know fords basic setting?
- esc rst - alternator prob - help!! :(
- Help really needed for Fitting ST Oil & Boost Pressure Gauges to Diesel focus
- Which ET OFFSET on fiesta st150?
- rs turbo starting problem
- which wheels
- Ford focus 1.8 TDCI
- Focus RS turbo failures
- Fiesta with a Vaux engine?!!
- Collapsed Brake Pipe
- Urethane Exhaust Mount Fitting For Focus
- Losing Power On My ZVH heeelpp
- Fiesta 1.4 tdci strange electrics "help......"
- Kent supersports hyd cam specs required
- mfi cvh question
- ragtop noise..
- alternator wiring..... focus and mondeo
- Reversing lights
- cossie crank??
- problem with my lambda on xr2i 1.8
- how do you tell the difference between a t34 and t34 hybrid turbo
- xr3i fuel computer 90spec
- ST170 ABS Light
- cozzy juddering
- Cosworth fuel pump problem
- Escort s2 rs turbo fuel metering unit problems
- IRV for xr3i efi (mk4) - WHAT?
- 1800 zetec oil pump
- con rods
- guys what alternator shd i but 55/70a?
- Rear Brake Drum MASSIVLY overheating
- cosworth ABS sensors
- Quality Parts???
- ERST Alternator....im confused!!
- weird one
- injector giving out to much fuel
- Misfiring 2wd Cossie
- front end knocking
- water in both footwells escort van
- Zetec pullies
- passion vauxhall lol
- Reverse light fuse
- MK3 Escort Electric Aerial help required
- Escort van injector pump
- can a turbo be heat wrapped?
- Escort 1982 Timing Issue
- removing the imput shaft
- clutch??
- Found oil leak! MORE questions raised.
- anti freeze?
- heated rear window ariel amplifier mk4 xr3i
- No Inlet manifold gasket! Could this be the cause of my problems??
- backfireing cosworth
- ABS Light. MOT looming.
- blinking door light
- resistor
- cossie suddenly it started to jerk?!
- cvh gearbox help
- MK1 ( 1998 ) Focus - Coil Overs
- zetec turbo, what clutch for 240bhp ?
- passion ford window stickers
- help
- zetec on carbs
- ford galaxy wont start
- Help! My van won't start!
- wiering loom cosworth 90 vs 92 4x4
- Water leaking into foot wells!!!!!!!!!!!!!!! Escort van 02 plate
- RS1800i - Poor Starting
- cosworth 4x4 front prop bolts help needed
- Mk 4 RS cab engine probs
- difference between an cossie 2wd & 4x4 head
- cooling fan wont work.make of vehiclke ford fiesta mark 4 1992 model
- msd L8 stg3 chip
- will mk2 mondeo td brakes fit a mk6 escort van
- S2 rst gearbox
- 2wd diff on a 4x4
- t5 and type 9 compatabilty
- FRST High idle, no boost and rev limit at 3k rpm. What is wrong?
- Abs light courier van
- Mercur sierra tank???
- Universal bias box help
- mondeo 2.5 ghia x
- fiesta battery drain problems
- Powerflex Suspension Top Bushes...
- cossie water/oil mixing?!
- CVH Oil Pressure Switch Oil Leak
- Car Wont Start When Heated Up - RS TURBO
- lumpy idle and battery light glowing?!!
- tuning sites
- adaptingGSXR throttle linkage, it to take the Zetec one..
- 1.8td cams
- acceleration prob in 3rd gear
- ST170 Con rods
- Ford Explorer 4.0 1997 Help
- pistons BOWL VOLUME?
- Fiesta ST Manifold and Downpipe...?
- site for parts
- 1.8 and 2.0 duratec
- Lowering springs.
- series 1 rs
- pectel monitor help??
- pinto block
- Second Hand Diesel Pump
- Ford Escort 1.6 L Zetec
- Brake problem on my 2wd cosworth
- Will a 200bhp rs turbo be reliable??
- ZVH oil return.
- 4wd fuel pump relay wiring fault!!!!
- amal valve
- IS it a Fiesta RST fuel pump Or an Escort Cosworth?
- sapph stage 3 problem boost/fuel?
- 2WD diff
- 2 questions
- ecu
- Escort Mk4 engine swap XR3i to Diesel
- zvh starter motor
- Mk4 Escort not turning over
- GTIR inlet manifold on ZT, how hard to fit?
- Escos wiring faults.+ boost/ misfire prob
- mk4 xr3i efi misfire/hesitation low revs on high load
- Transferbox - what oil or fluid?
- Do late escort cossie pulleys fit on 2wd cossie
- No boost and wont rev past 3K rpm? Limp Mode?
- 1.3 cvh cam cover fit a 1.6 rst engine??
- Mondeo TDCI - Flashing Glow light?
- Advice on spring rates
- speedo not working
- Crankshaft & Pistons?
- morette headlights - bumper indicators
- Driveshafts on ZVH engine.
- xr3i mfi 89 quick shift be a good buy?
- Stainless Steel Exhaust Assembly Advice
- please help with my rs turbo
- Focus rs pistons in silver top.
- cossie ford pilot
- replacement engine, will my chipped ECU be ok to run it??
- Vacuum leak between throttle body and servo one way valve
- old skool wheels not on old skool
- Fiesta TDCi EML Problems
- mndeo mk2 td parts/breaking to use for escort mk6 van
- Mk5 Fiesta Brake issue
- Front strut removal.
- Cosworth compression strut questions....
- ZVH sump capacity.
- Focus ST170 and fitting Brembo's
- cossie exhaust
- ofac or ofab?
- 36-1 trigger wheel on a yb .
- p100
- No pipe on actuator.
- Help me, think I just bought a dog!!
- Power Hood Not Working
- escort s1 rs turbo roll bar
- adjustable tca's-ball joint
- Rust repair advice, wanted
- Ignition Problems
- mk5 erst s2 conversion overfueling
- Timing on mk5 Escort van 1.8d
- High/Low compression pistons in FRST
- Escort RS Turbo Jerky.....
- Overheating problem- Fiat
- erst s2 rev counter not right
- Heater on 1997 escort van
- Afr gauge fitting
- no heater in mk4 astra van please help!!!!!!!!!!!!!!!!!
- xr3i alternator
- Escort Mk3 Rear Chassis/Boot floor
- rs2000 no spark
- escort van 1.8d start
- ford transit gear selector
- Fiesta mk6 bumper and brakes help!
- gearbox
- Mk2 Escort Rack
- alternator's..
- st170 gearbox conversion
- Is there a connector to lubricate the prop shaft somehow?
- rs turbo no spark
- **Wiring help/ direction on the s1 escort**
