View Full Version : Technical help Q & A
- Lowering my MK1 Fiesta
- Help me my car still wont go!!
- injector
- Sport cat or normal cat for my RS1800
- Where is MK4 XR3I EFI ECT Sensor?
- Focus mk1 td key remote not working
- ford focus dtci/ cold starting probs
- help! mk3 fiesta driving me mad
- overdrive light flashing, changing gear erratically
- Abs warning light????
- saph cossie turbo surge/stall
- 1.6cvh
- escort 7/8 turbo diesel problem
- escort mark 7/8 dash clock
- xr3i fuel problem
- Ford Focus light steering all of a sudden.
- duratec starting problem
- Is Fiesta RS Turbo Gearbox Any Good In XR3i?
- Courier Van belt change (diesel)
- Line lock for 2wd Cossie - Installation
- cossie cold starting
- focus 1.8 tdci boost gauge fitting anyone done one ?
- CD PLAYER
- Mk3 Fiesta Brake Servo
- amal valve
- KA central locking
- Track day problem
- Another EMISSIONS question.. :\
- another fuel pipe Q
- 1.25 Zetec Fiesta - Tons Of Problems!
- Replacing Electric Window Switch
- Immobiliser Fault ???
- xr4x4 24v cosworth conversion help needed
- Ford Fiesta 1.4 Zetec Climate 55 plate
- escort 1.8 gti high beam sticks
- AF to AE generic map on focus rs
- Clutch not fully disengaging
- ohv tappets
- Focus Alarm
- gearbox for 2.9 cosworth
- Sierra Cosworth violent steering judder
- Mondeo ST24 Help
- Megasquirt
- Basemap for 2.0 Silvertop ZT
- Taking off a fascia adaptor for stereo
- Power Loss Ford Fusion TDCI 1399
- 2wd pistons
- intecooler issue
- Focus: delay accelerating when changing gear
- Map sensor issues
- Mondeo tdci loss of power
- rad fan switch thread size and pitch
- 2003 Focus 1.6 engine light
- 2001 focus losing power
- cosworth internals into pinto block??????
- Smoking Saphire
- saph rev counter
- efi frst plz read guys
- Focus Pre facelift clear front indicators
- cosworth cooling system
- Power problems 2.0L Focus Zetec
- mk3 mondeo 2.0 duratec prolem
- help needed 2wd cosworth engine
- help needed asap. part of engine loom
- Adice needed about the turbo on a Focus RS MK1
- 06 focus 1.8tdci temp gauge
- focus and mondeo conrods PLEASE HELP
- Mondeo tdci v belt
- turbo boost gauge, is it working or is the turbo fooked?
- rev clock acting as a boost gauge, why?
- Mk3 Fiesta Clutch Problem
- Help mondeo tdci fault
- 1.4 to 1.6 Conversion.
- Fiesta MK3 Problem...
- mp3 problem
- zetec help
- C20LET gartrac RWD
- rs turbo oil pressure
- escort van mk5. rear hub
- forged pistons and steel rods
- USB ODB kits - any reccomendations or opinions?
- Gartrac escort mk3 red top turbo
- s2 rs turbo starter motor, which one?
- main studs
- P100 Cosworth
- Explorer 4.0
- fiesta rs turbo vin code
- MK1 Fiesta locks
- 3 Door Heater Matrix - Anyone done one ?
- bumped for brakes??
- MOT Emissions Test FAIL! :(
- What Cams??
- Zetec Turbo, no spark..
- Spark plugs
- Zetec throttle bodies???? ideas please
- Cosworth 2wd Cam Seal Leak,.
- cold start in morning? car wont turn over ?
- 1.6 cvh carb dizzy and coil wiring
- Question about ford 2 litre DOHC pre Zetec
- what engine should i put in my fiesta?
- spark problem.on a cossie 2wd
- Duratec/ Zetec head stud kit....
- XR3i MFi unhealthy noise
- escort half shafts
- Wont start
- cam bits?? do i need
- mk3 mondeo injectors
- clutch for 350bhp zetec turbo?
- help broken transit diesel
- Hesitation or no firing cylinders!
- idle speed control valve connections ?
- saph cossie rear door catch differences from old type to newer type
- help with zvh build
- seatbelts
- would a weak spark cause cossie not to fire up?
- Gearbox Whine
- Confussion, ZETEC or DURATEC engine
- Wiring diagram for saf cossie needed?
- cd plasyer please help
- s2 lsd gear box
- fiesta starting problems like it wont ;-)
- 2.0ltr zvh turbo choice?
- st 150 stereo
- Fiesta zetec s fault code U0121 ABS
- rs2000 ecu
- ISCV
- misfire in my 4x4 sapp
- AP551 or AP600 or Ford Super Dot4
- Help! Small turbo inlet and throttle body on to 2wd saff
- ka valve prob,head removed
- 2001 Focus 1.6 idle,aircon,almost stalling
- xenon lights on high beam
- fitting ghia one touch window buttons?
- bike carbs on zetec
- yb engine
- Running in a fast road cam on a fresh build engine yes/no
- How many miles is good???
- Side repeaters
- Missfire after changing turbo (Escort RS Turbo)
- map sensor
- Propshaft bolt removal....help
- efi manifold ???
- escort starting problems
- Managementsystem for 4x4 cosworth
- Zetec Idle Screw?
- Mk3 fiesta 2l help
- Sapphire ABS blink codes
- Help!!
- anti roll bar query.
- 3.62 or 3.92 LSD Which is better?
- zetec help
- st170 gear change problems
- steering rack question
- Clutch
- Brake upgrade for mk5 fiesta 1.25 zetec
- alternator loom question
- Focus problem - electrics / lights
- No speedo or abs06 1.6 zetec s
- Bigger injectors 2.9 v6
- mk4 xr3i efi wiring gremlin
- Ford Focus w reg TDDI zetec
- 1999 ford transit ......
- 1.6 to 2.0 zetec
- will a escort s2 lsd box drop straight into a mk3 fiesta?
- Evo VII-Indictors help
- clio 1.5dci annoying starting problem HELP!!!! this is getting to be a pain in the !
- mk2 ST asbo can it fit into a MK1 RS shell?
- map sensor or throtle response sensor
- ZVH Compression Ratio
- info on building a zetec N/A
- mk6 fuel pump relay and fuel filter location needed
- mk6 2k jitters
- 1999 w reg Ford Focus 1.8 zetec petrol won't start
- low reading fuel gauge and then now power
- Turbocharged and Supercharged Engines - Is it the future?
- s2 air box seal
- mk5 fiesta thermo switch location
- amal valve help!!!
- help needed
- Unleaded conversion
- escort xr3
- cosworth water pump.
- steering arm / tie rod bent how dangerous ?
- t5 engine into rs2k?
- sorry guys advice needed for a subaru....
- Car keeps cutting out.
- newbie with escort gti electrical running problem
- Escort Turbo S1 Fuel Metering Unit
- engine smoke or turbo smoke ?
- what cable to starter motor
- What turbo?
- Zetec Cammed Idle Problem
- biege 701 fitment
- escort mk6 1.4 problems
- TCA/Balljoint rubber dust covers
- rs turbo clutch?????????help
- crap 6000e rds cd player says error E3!!!!!!!!!!
- HELP looking for specail rally paper B-286 at a Sierra RS Cosworth 3-door 1986
- Air fuel ratio on a CVH
- td immobilser problem after pump change
- Sony dab radio
- Saloon & Caonverible are they the same!!
- low mpg on 2001 mondeo
- st 170 sticking accelerator
- building a IB5 casing with new internals help
- 2 litre Zetec blacktop Tb Injector size etc??
- Cosworth Turbo Engine Managment
- AIR/CON Problem
- Wiper Issue
- Cosworth 4x4 starting problem
- hit the verge! now doesnt go properly!!!
- what sort of power will i have?
- clarion radio code please help
- battery
- RS Turbo HT Lead Question
- Help Needed: MK 5 fiesta zetec s throttle body vacuum pipes
- fuel pump relay
- couple escort van answers need wipers n tyre pressures
- st24 mooseing
- Handbrake Stuck on a few clicks
- Zetec Twin 40 Conversion/ Rollcage Problems
- escort clutch question
- radio suppresion
- any1 help settle a lil argument???
- 1995 escort 1.4
- Factory fitted alarm
- mondeo st200 brakes
- Fiat 132 axles into English diff?
- Charge Carrier modifcation
- exhaust issues
- ERST wont start when engine is warm
- cosworth YP, top end rattle!
- Battery draining / doesn't like starting
- cossie hesistation when touching throttle
- V8 sierra help!!!!!!!
- mk5 fiesta 1.25 misfire
- Vacuum pump on 2.3d ford sierra
- what torque ?
- 2wd cossie no boost
- mondeo sci ecu repair
- Fiesta seat back assembley
- Loom
- mk5 fiesta central locking
- Zetec oil pump
- Is it ok if,
- 1.8d escort van (Y Reg)
- Focus TDDi losing water....help please
- mk3 Escort Brake Pipe HELP????
- 180bhp Zetec Gearbox?
- Steering Wheel Juddering, Fiesta 1996
