- clutch problems
- wheres the best place to buy paint for a gravity air gun???
- need help on my 1999 focus 1.8 tddi
- Forged rods or not?
- water pump on xr2i 16v
- fiesta mk4 zetec reverse sensor location?
- cosworth 2wd&4wd track control arms . .
- solid flywheel conv
- 1994 ford explorer fan problems
- cvh engine
- cosworth ecu help needed
- Escort GTI Throttle Cable
- Which mount??
- fan heater motor
- mk6 fiesta zetec s tdci engine mounts
- bosch fuel injection adjustment
- coilpack plug/connector
- Heater Matrix
- why does this happen????
- dizzy
- Remote servo?
- AEM ECU or L8 ECU which is better?
- engine not fireing
- what could be the cause of oil loss
- Rattle at 2k revs on 2002 mondeo tddi
- Replacing handbrake cover on Focus 2005 MK3
- Rs turbo clutch
- ka p/steering&alt mounting help.2.0 silvertop
- Xr2 Tie Bar and Distributor help
- Reyland Billet Fuel Rail + Siemens 55lb
- MAP Sensor problem
- fiesta mk6 facelift heated screen
- more power
- How to convert a mondeo 2.0 tdci 115 bhp to a 130bhp
- Mk6 Fiesta ZS TDCi rattling / vibration
- Focus tdci sport 2006 plate - Cold 'Missfire'
- Dump Valve - Signs of leaking?
- please help. xr2i with 2l zetec
- Focus 2008 tdci accident damaged
- 2L ZVH Spark plugs
- Standard Ford Stereo Wiring in a 3 Door
- disable imobiliser
- what head gasket? cosworth
- st24
- How to do a burnout with a 4 disc brake car ?
- power loss from transmision
- fiesta mk3 engine not starting
- Help help help !!!!
- obd socket on a mk3 mondeo where is it?
- Knackered turbo? (with pic)
- 3Door Fuse Locations
- escort RST turbo help needed
- HELP- How do i adjust Idle Speed on FRS
- saph wont start :(
- mk5 rs2000 running problem
- What cams to use
- What cams to use
- fiesta imobliser
- 98 f15o with a bad miss
- what head gasket COSWORTH
- diesel injectors?
- ABS and traction light permenently on?
- replaced engine having trouble starting car
- Shims and followers Focus RS???
- push fit vac hoses
- janspeed sports cat
- Flat Battery
- Bbs rc042 split rims
- fiesta zs mk6 tdci wheel wobble
- fuel pump stoped working in my sapp 4x4
- zetec turbo not injecting???
- fiesta mk3 rear disks
- Damaged saph cossy 4x4 wiring
- escort self ajusting clutch
- Zetec turbo oil feed T piece?
- Focus 2008 td accident damaged
- st170 track set-up
- mk3 mondeo body warrenty
- silvertop a/c swap
- Petrol, in particular V Power
- pros and cons of lightend flywheel??
- escos strange wiring problem please help.
- Gearbox
- Cossie 4x4 fuel reg fitting
- Stack Dash into escort cosworth
- 1995 mk3 fiesta indicators wont work
- ERST stud and nut conversion WHEELS
- Zetec Ecu
- cosworth over-run smoke!..
- starter motor wiring confusion :S
- Some advise please!
- 2000e gearbox
- Newbie needs help with a silvertop
- Airbag Light Flashing With Code 4 ... Read On
- Sapphire TCA nylock nuts
- Zetec Running Throttle Bodies? Yes or No?
- Focus ST Key programming?
- mk1 fiesta running like a bag o sh*t
- wheel bearing
- erst s2 need measurements please help!!!!
- fuel pipe
- saph 4x4 cossy
- mondeo 2002 tddi clutch assembly
- mk2 xr2 adjustable bottom arms
- Fuel rail question
- Mk2 focus steering wheel in a mk1 focus?
- Silvertop and Blacktop differences for a zetec turbo
- Escort GTi badges, where buy?
- How do you fit TURBO TIMER?
- Cooling fans
- oil temp gauge
- 36-1 trigger wheel
- Cooling System Capacity on 1.6 cvh
- No Spark on a MkII XR2
- 1.8 zetec holds back
- hard to start......
- rev counter (escort cosworth)
- another turbo question
- silvertop to blacktop conversion in mk4
- non staring mk6 escort gti
- Refitting Escos suspension tips wanted
- XR4i cosworth conversion not starting
- t2 help needed
- mk3 mondeo heater problem
- ST170 Fuel and temperature Gauges
- Clutch noise on over run
- Engine warning light (EVO 4)
- obd socket mondeo mk3
- mk4 Speedo
- saff 4x4 rear inner cv boot
- 2002 Ford Focus 1.8 TDCi Zetec (115ps) - lack of acceleration power
- Whats needed to go stage 2 (frst)??
- xr4x4 warm starting probs
- How to test abs sensors
- Coilover noise
- why cant i find a pinout chart anywhere for my mondeo???
- efi turbo problem
- mfi or vacum problem?
- fiesta xrv van tuning.
- Rear windscreen washer problem?
- HELP !!!! Cosworth..Heavy Smoker
- Edited - turns out i am losing coolant
- Match & A Field? Zetec Problems
- Focus Wobble / Vibration
- need simple help
- Ignition fault?
- fuel regulater rs turbo
- Mondeo HC woes
- fitting a front nsw window on mondeo km3 saloon
- escort rs turbo help
- couple of questions about my escort rs turbo
- Removing seat cover - 03 Focus Ghia
- cosworth clutch..help
- Erst heat sheild do they work?
- what rating pressure cap? FRS
- escort 1.8 16v 105hp
- Tuning a 1.3 mk4 fez
- mondeo 2006 sony stereo
- injectors
- Cvh crank front oil seal how to anyone?
- focus 1.8tddi gemini chain casing bolt type??
- problem with ford galaxy 2.3 1997 auto
- problem with cossie 2wd
- help
- What clutch do i need ???
- Request: STEP BY STEP GUIDE ICV REMOVAL (99 ESCORT)
- car keeps cutting out
- 2 ltr zetec in a mk6 escort
- Heated front window
- Zetec turbo inlet manifold???
- which oil?
- Sierra Alloys Fitting Escort
- 2wd TPS readings
- cosworth smoke! PLZ HELP
- Egr removal.
- Flickering oil light on fiesta tddi,please help!!
- Rough Boosting Saph...
- ka engine problems
- water in oil tank
- escort van stals
- Gearbox fitment
- Paul Mee
- Zetec Problems!
- Is my boost gauge broken
- Frs heater resistor pack fails again
- fiesta 1.4 16v r reg non starter
- fuse box???
- cosworth engine noise
- s reg van 55 weight
- x reg escort deisel van advice
- what the blinking flip is a tps?
- KA Engine Management Light
- gartrac re-build. finally
- no ignition power...........................
- rs turbo s2 injection problem
- consequences of water pump failure. FRS?
- Mondeo MK4 Fault Codes/Electrical Problems
- Saph Ecu
- mk6 wishbone problem update
- problen with gearbox
- full engine replacement
- series 2 brake pipes no abs
- t4 turbo- exhaust housings
- HELP
- Efi speed sensor ?
- Seat Runners/ Subframes
- boost question
- dipsticks
- throttle bodied rs 1800
- koni rear shockers
- ford mondeo 02 plate dual mass flywheel
- escort van pats module location
- exhaust- where to buy?
- Zetec Throttle Body with idle screw info needed.
- Bailey oil breather fitting??? rwd saph.
- electrics series 2 mfi
- saph fuse box
- Efi and mfi
- ISCV connector plug
- 1998 Escort van fuel problem
- BC 5 gearboxes, differences between pre and post '86
- slight loss of oil pressure
- Escort Zetec Runnning problems- saga
- Zetec Loom Compatabilities
- MK1 XR2 Carb problem
- Want bolts on to the block beneath the distributor??
- anyone got an oil breather diagram??
- few escort 1.8 gti problems
- CV joint/ clutch
- venom1 1.8.si estate 1998
- rs2000 cutout no spark or fuel
- Car engine loom
- power steering
- Cool Runnings
- fitting a saph beam/arb to a 3dr
- focus rs engine in a escort,which mtx75?
- Ford Fiesta MK6 (Blower Problem)
- A few problems, Help needed!
- Focus tdci AST system failure?
- new round post battery in cossie
- escort zetec 1.6 alternator removal
- Fan loom for cosworth
- Zetec Missing (Fuel Smell Horrendous)
- 95 escort cabriolet stalling
- how many miles you get to a tank of fuel in your cossies?
- Escort van lumpy idle
- Bosch or siemens ?
- unleaded heads or maybe not
- Converting from RS Turbo to CVH carb LOOM question
- rs will not start
