View Full Version : Technical help Q & A
- Does my car have a WET BELT?
- Dry ICE to remove Dynamat
- just a quicky
- L6 msd chip
- Fiesta mk6 Recirculation light keeps coming on
- Fiesta MK3 - idle issue
- Escort cosworth + stack dash =🤷🏻*♂️
- Mondeo 1.8TDCI wont start
- Compression query
- 2006 transit connect trailer wiring
- Focus MK1 Misfire
- Stuttering help!
- Mondeo mk3 brake fault
- Fiesta RS turbo Co Pot resistance
- escort cosworth clock/temperature pin out
- Coil on plug question
- Focus 1.6 taco limp mode when cold
- DTC P0351
- Fuel pump sender unit
- Pectel Omega D1 Dash
- Auto electricians
- Escort cosworth fuel sender
- Fuel Gauge
- Ford xr2i 1.6 h reg
- Mondeo, 55 plTDCI starting problems, glow plug
- CVH 1.6 Turbo EFI intake
- Fuel pump relay
- Help me please lol
- Cosworth 2wd alternator help!!!
- Fiesta rwd build
- Which parts will reduce the torque on a YB engine?
- a few wrong things on my 2000 ka
- Help needed
- 2016 Connect non start HELP needed
- ST170 mk3 Mondeo front calliper differances.
- Cvh 2.0 Zetec conversion
- My new wheels tyre sizing 205 4x4 pug
- help with focus st steering issue
- Relpacing Ford Fiesta/Ka/Puma HCV with plumbing valve (?)
- Where does cossie ECU read rpm from?
- Cosworth 4x4 driveshaft or is it?
- Mk5 escort central locking drivers door
- N7A rs2000 16v engine
- Ford sierra strut tops
- newbie looking for help
- Individual throttle bodies design.
- Track day/race YB engine spec
- 2010 Focus Immobiliser/Alarm Light Going Nuts
- Can a Cosworth L6 ECU with wasted spark run coil on lead
- sierra cosworth bust! rear diff question
- Which Turbo
- ABS retrofitting help
- 03 focus 1.6 zetec se tappy noise
- Series 1 dash
- Oil around the turbocharger - Focus 1.6 TDCi
- Idle air leak?
- Zetec turbo exhaust
- Sierra brake pump into Capri.
- Focus St170
- Paint code or close match for mk6 zetec s alloy wheels
- Series 1 rs turbo 2.0 zetec turbo
- Temperature sender for dashboard
- Cosworth Gearbox Options
- How to adjust headlights
- Mondeo MK3 Tdci Turbo Cleaning
- 08 St no boost
- Fiesta rear wiper missing area of glass
- Mk6 zetec-s power steering whine and groan.
- Mondeo Mk1 lift up reverse selector change
- Zetec SE Tuning
- help do identify rear cosworth arm
- Cosworth rich under load.
- Manifold/cat question?! Focus
- 1.4 Tdci inlet manifold seals
- 8 valve 2.0. dohc induction manifold
- Ringt side lights not working
- Mondeoi 2008 2.0 TDCI under revving issue
- advice on intake for 800++hp
- Raven black paint code
- Please HELP 1.8 tdci
- 2000 ford ka water leak
- Fiesta mk 6 idling problem
- MK3 escort xr3 engine cvh
- Focus Auto keeps stalling! Help
- 2.0i DOHC
- strange sound coming from the engine, 2.0 TDCi (140Hp), Diesel, engine UFWA
- Gearknob removal
- Any help?
- Anyone know what oil I should use?
- escort upright
- Hi guys..first post.
- Rear diff ..
- Ford focus mk2 2008
- MK5/6 and Cosworth Fuel Sender Resistance Range
- Removing standard air box.
- St170 headlights????
- Focus 2.0 Duratec hesitates and cuts out *NOW FIXED*
- Non starting 2007 focus tdci
- Gsxr throttle bodies
- Thoughts on pistols and rods?
- Nylon Fuel Pipe Quick Connector
- parts swap?
- Roof lining trim sapphire
- new ford owner problems please help
- one piece prop 2wd saff
- ST170/zetec/blacktop fwd sump baffle
- St170 block
- focus st170 reversing light
- Loose gear knob
- Light weight flywheel worth it?
- Sapph Cosworth front caliper sticking
- VW SHARAN / GALAXY 03 plate Starting issue
- Sierra Cos 3door standard springs?
- Map sensor help
- flat spot when air con on?
- rs tubo ofab loom wanted please
- MK4 Fiesta 1.25 zetec ECU
- feels like prop vibration
- Banana engine in a p100
- sappire cosworth electrical issues help needed
- Advice on injectors please
- Duratec HE engine issues
- Engine ID Rrequired ;-)
- St170 problem power
- cosworth radiator advise
- Puma 1.7 engine work
- multiple codes.
- 2wd saff cossie chip advice.
- Battery/Alternator/Electrical fault?? 08Focus ST
- Sierra 2.0 GT 2wd brakes to 4x4 calipers ?
- Wanted fiesta Rs turbo base map for dta s60
- St200 ecu pin out diagram
- Oil spitting from side of engine
- Need help
- t p s readings
- Engine problem Head ???
- mk2 fiesta turbo help please
- Black top zetec/mk1 frs torque settings
- Fiesta coolant system issues!!
- 2008 1.8 Zetec Focus - functions delay
- St200 ecu issues
- ranger egr delete
- focus st mk2 new alternator broken after 50 miles
- Cosworth P8 amal/ lektron/ ecu fault
- 1600 pinto waterpump
- 2005 fiesta flame 1.4 coolant/ rad issues
- 05 fiesta flame 1.4 petrol coolant/ radiator issues
- Ford Fiesta/Puma swap
- One for the LandRover peeps...
- Brake pedal goes hard at low revs
- Smax 2.0tdci windscreen washers not working
- Ford Focus 2.0 tdci Auxillary Fan Belt 2010
- solid lifters + newman cam
- Ford focus 2.0tdc 2010i auxillary belt
- sierra zetec silvertop converted
- 2.0 silvertop rods.....
- zetec turbo tappy top end
- Mk 6 zetec s tdci
- Hub compatibility on mk1 focus plz help !!
- Ford Fiesta Mk4 Roll Cage
- St170 forge rebuild..
- sierra cosworth strut brace help!
- Escort Mk4 drivers door lock 86/90
- Focus 1.8 tdci problems starting after fuel filter change
- focus airbag light reset ?
- rs turbo van running not well
- 2.1 Zvh running a Tdci hydro MTX75
- Focus 2008 brake fluid
- Fiesta Idling problem
- Convers+ & entertainment system gremlins please help
- 2L zetec turbo build
- What fuel pressure reg for Billet fuel rail
- Escort Cosworth ST cutout
- ecu location?
- Cometic water pump gasket
- Changing the engine of a fiesta
- 3.0 V6 AJ Engine mystery...
- Please I need help
- Rattle noise from engine. Focus 02 1.6 auto
- Focus air intake hose and ABS light
- 1.6 ecoboost in mk6 fiesta
- Fault code sheet EEC IV T25 escort cosworth
- 2wd saff stg 1 not reving past 5000rpm
- Camshaft question
- Focus RS alloy on Sapp...?
- Diagnsotic plug t25 cosworth.
- Help back smoke ford focus 2.0 turbo diesel
- Transit connect won't start
- Wipers not working at all?
- Misfiring for first 20 seconds?!
- Fuel tank strap part number sapphire 4x4 needed
- Green steel brake pipe
- Zetec Microsquirt disaster
- 90 Spec EFi Fuel tank sender
- 2wd rear brake pads different to 4x4 pads
- Sierra saphire glsi boa conversion
- Speed Cameras on Ford Sat Nav
- Focus Quarterlight fitting
- mk1 focus temp gauge erratic overheat HELP PLZ
- Mk4 escort headlight lower ball clip
- St170 turbo
- transit diesel randomly cuts out.
- 05 fiesta st rev hang when cold/ rough idle when warm
- Turbo radiator cooler are they worth while?
- Engine oil leak on my Dax Rush Cosworth
- Mondeo mk4 1.8 con rod torque settings
- focus cly head temp sensor? help please
- Mk4 escort cabriolet electric windows not working gggrrr
- Help for tuning a focus 1.6 tdci
- Temputure coolant sensor
- Cosworth std conrod length
- Turbo Damper Bracket For 4x4 Head
- mondeo st200 help needed
- Coolant plumbing help please
- Mondeo mk4 tyre pressure system
- Emerald K6 ST170
- blanking egr
- Ford Fiesta 2004 1.4 to 1.6 engine swap
- Driveshaft
- Staggered wheel sizes on Cossie 4x4
- Please help
- Wits end. Streetka battery light.
- My Ford Fiesta using loads of fuel
- Knocking
- Tial dump valve spring
- ARP head Bolts
- floppy clutch
- Cmax battery light comes on
- 2wd cossie gear knob thread size?
- Door card speaker holes
- brakes applied saff turns right update of the update of the update
- master cylinder/abs problems bleeding
- How to lower the compression on a st170
- saff 2wd brake master cylinder
- transit connect drivers seat
- Rs Turbo AMAL piping problem!!
- Ford finesse 1.3
- Propshaft donut
- Mk6 Fiesta wheel fitment
- Focus 1.6 2009
- Cosworth Starting Problem
- Help Ib5 rebuild problems
- Ford Focus MK2 Titanium - Right driver side vent not blowing any air
