PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. advice on removing a snapped off temp sensor
  2. piggyback, no hazards
  3. Mondeo MK3 2.0l TDCI 130PS Chuffs worse than a steam train
  4. lambda sensor wiring
  5. ahmed bayjoo
  6. ford focus 1.6 clutch "advice needed"
  7. fiesta 1.25
  8. Escort diesel pump
  9. HELP!!! escort rs2000 axle
  10. clutch slip
  11. size of escort mk4 XR3i springs?
  12. fiesta turbo spluttering when rev'd over 4k?
  13. Sierra help
  14. only firing on 2 cylinders
  15. CHANGING TYPE 9 BOX FOR MT75 IN XR4i
  16. Focus ST Bluefin help
  17. de-catted ST220 help
  18. Fitting external wastegate??
  19. st170 inlet dont fit in escort! with pics
  20. roll cage
  21. zvh oil pump which one do i use
  22. Janspeed turbo
  23. Mark 4 Escort Spring Info Needed DESPERATE
  24. Turbo sizing/options/question
  25. punto gt ecu pin 52
  26. 24v cossy what manual box to use?
  27. mondeo gearbox mounts
  28. Focus ST 225, Rear Seatbelts
  29. Sierra measurements..
  30. Escort Zoo Arms - Should I?
  31. ofab management or L8 cossie management
  32. ka pinchbolt
  33. focus battery light
  34. telling the difference
  35. What Hoses Where ?
  36. Brembo 4 pots on a Mk6
  37. can a pectel bord in a l8 ecu be set up for closed loop?
  38. RST brake set up under 14'' wheels
  39. Will a 2 Door rollcage fit a 4 door?
  40. best way to weld gear box case?
  41. juddery drive inbetween 30-50mph
  42. 2wd front brakes on erst help needed!!!!
  43. Engine dilemma's.
  44. mk4 escort wiring diagrams
  45. sierra cosworth engine managment failure
  46. Ford Focus MK1 central locking fault? NEED HELP ASAP
  47. steering wheel removal
  48. Yb mapping
  49. MK6 rs turbo project, help needed!!!
  50. info needed on 195 ofac superchip
  51. efi sender unit problem
  52. 2i cam timing question
  53. saph cossie coolant hose
  54. Zetec Burning Oil?
  55. help with 2003 ford focus please
  56. ECU Testing/Repair
  57. Escort cab electrics. HELP!!!!
  58. thermostat switch mk6 escort
  59. Power Steering Pump
  60. leaded vs unleaded
  61. Zetec-SE 1.6 Head on 1.4 Block?
  62. Focus TDCI - no boost following turbo change
  63. mondeo 20 tdci 130bhp
  64. gear box advice
  65. saph cossie respray
  66. digital fuel guage
  67. rev counter and autronic management
  68. what secures ya cars then
  69. Wiring diagram
  70. How do u loose the bellhouse on mt75 anyone with pictures?
  71. Xr3i 1990 EFI cabby running probs
  72. Boost Control
  73. newbie poss buying a series 2 erst need advice on engine noise
  74. New turbo, easy as bolt it on?
  75. removing a mk5 fiesta door
  76. xr2i 16v alternator choices??
  77. Xr3i,cut out,poor idle,? Melting relay with pics
  78. fiesta tdci
  79. focus rs flywheel position?????? cambelt change????
  80. Noise at the back
  81. ford focus engine mangement light
  82. engine management light
  83. starting problems HELP ASAP
  84. 1.3 fiesta missfire!!!
  85. ST 150 Dials
  86. Mondeo V6 Brakes on MK5 Ford Fiesta
  87. ST 150 Stutter
  88. What oil in cosworth
  89. What oil in cosworth
  90. Wiring diagram
  91. Wiring diagram
  92. Wiring diagram
  93. ST170 Timing belt change
  94. overheating
  95. 1.6tdci non start
  96. Sierra cossie (BOOST) issue
  97. Escort 1.8 Gti with standard filter sounds like an induction kit
  98. Running in cams
  99. hydr clutch conv + twin plate clutch
  100. Pectel Monitor, what RS232-to-USB converter actually works?
  101. will a 4x4 cam fit in a 2wd head?!
  102. ford focus 1.4 zetec
  103. Help please with 1.8td head?
  104. 3 Door Cosworth Door Locks
  105. diesal probs HELP
  106. s2 rs wont start HELP
  107. Escort RST rear wheel bearings...
  108. Heater motor noise - Ford Focus TDi
  109. help and advice needed please
  110. St170 inlet in a mk6 escort
  111. St170 inlet in a mk6 escort
  112. fusebox
  113. mk4 escort, steering wheel removal
  114. Timing belt snapped 1.25 zetec
  115. what size injectors?
  116. Starter motor info
  117. cossie alternator upto charging a 70AH 760 amps battery?!
  118. peugeot 306 gearlink problem??
  119. ford ka battery lt on
  120. Which RTV sealent to use on CVH sump?
  121. How to.......
  122. boost on a 2wd cossie
  123. can you put new acid/water in an old battery?
  124. Oil filter Thread size,
  125. STEEL SEAL headgasket & block repair
  126. Cosworth ignition amp help
  127. Can anybody tell me what this does???
  128. 95 escort alarm keeps going off
  129. 1.6 Zetec running problems after head gasket
  130. 3 cylinders firing and no turbo
  131. advice please - escort van related
  132. Focus RS Bleed Nipple Size & Thread Pitch
  133. radio code pls peugeot?
  134. Zetec R1 Carb Setup Help Needed!
  135. wasted spark question
  136. Driveshaft / CV joint ID
  137. fiesta st with piper cams
  138. Pectel super 8 ecu.
  139. cossie electronic boost control..???
  140. 1990 mk4 escort EFI
  141. fiesta head lights problem
  142. how do i read fault codes
  143. Escort issues!! :(
  144. 2WD Cossie, vague steering?
  145. XR4x4i Turbo Technics - UPDATED
  146. zvh oil worries
  147. problem solved
  148. 2wd cos internal worm drive bit (inside box)
  149. Stiff steering XR2i???
  150. Mk4 engine mount options...
  151. sierra 2.0
  152. cosworth running problems
  153. help someone please
  154. Alternator help please.
  155. 6 deg. rear beam.
  156. cosworth intercooler
  157. Dreamscience problem
  158. best conversion mk4 escort??
  159. Mk3 Mondeo rear wheel tracking???????
  160. help me please.
  161. gap sizes in mm for phase and crank sensor....
  162. Cosworth tick over ok soon as throttle is revved pops and bangs.
  163. Escort rs turbo s2 knocking & missing
  164. idle on a rs turbo
  165. transit connect white smoke
  166. mk5 fiesta new engine options...
  167. How to tell the size?
  168. xr3i
  169. Help with cosworth t5
  170. cosworth over-run smoke, STILL !!!
  171. quick suspension query (Mk3 Cabriolet)
  172. Cam Pulley Coating
  173. compression strut kit installation advice
  174. 4x4 cossie no spark
  175. W Reg Ford Focus Ghia HELP! - Electrical Problems???
  176. Fiesta RS Turbo Overfuelling
  177. mondeo mk3 tdci tempreture guage reading 0 and bad mpg
  178. blacktop zetec turbo pistons
  179. Small turbo inlet with throttle body onto 2wd yb
  180. Don't know if any one can help but here goes
  181. Pectel T2 Configuration
  182. Manual Boost controller
  183. Mt75 on cosworth
  184. 1.6 cvh sump
  185. engine problem bought new mondeo what engine size
  186. 52 Plate Focus 1.8 TDI Overheating
  187. escort hesitation at speed
  188. Changing coilpack Focus for an Escort one?
  189. tps readings
  190. series one sunroof
  191. Body Panels
  192. Help ! Escort turbo not boosting
  193. A problem with wasted spark kit.
  194. Best TPS for Autronic
  195. Mk4 Escort suspension all interchangeable ?
  196. st170 power problem
  197. Bush Sleeves Too Small!!
  198. how easy to swap dash in escort van so have rev counter ?
  199. 2wd diff
  200. verdict on duratec crank (pics)
  201. Tapping noise
  202. Clutch Ratchet
  203. 2wd and 4wd cosy heads ?
  204. escort brake problem
  205. bypass belt v6
  206. xr3i on 3 cilenders
  207. shaking steering
  208. focus blower
  209. Engine/Gearbox combination problem
  210. cossie header tank
  211. Power steering fluid
  212. Stage 3 Cosworth upgrades
  213. Feedback wanted on zetec turbo spec
  214. air con compresser bearing
  215. anyone here run with MoTeC M4 with Zetec engine??
  216. not a cosworth but still carrys one, transit diff help please??
  217. V6 Cosworth BOA or BOB?
  218. Cvh headgaskets
  219. mondeo stud pattern
  220. galaxy stuck in reverse
  221. RS1800 Problem
  222. External Wastegate
  223. cosworth idol problems
  224. Cosworth boost problem,
  225. Fitting Oil Pressure Gauge to Zetec SE
  226. engine compartment to passenger bay wiring?
  227. closed loop..
  228. Turbo Gaskets
  229. One for the Mondeo Tech guys
  230. Flushing the water through a 1.6 cvh turbo engine?
  231. fiesta rs turbo problem - please help
  232. fiesta rs turbo problem - please help
  233. Whats in this kit ?
  234. Transit connect front speakers ??
  235. fiesta st cossie wheels
  236. AFR gauge complete kit...
  237. max boost from a greddy boost controller????
  238. need help asap! rear brake drum mk4 escort! please help
  239. coolings fans run all the time
  240. alternator not charging correctly
  241. Sump off, anything else at same time?
  242. rs turbo cam help
  243. zetec pistons
  244. mondeo tdci knocking noise
  245. cosworth slipping
  246. Holset on zetec turbo..
  247. New Headlights for 2009+ ??
  248. Engine paint
  249. rs 2000 seats
  250. Keep alive memory (KAM)
