PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. 2.0 16v blacktop ka
  2. Turbo Rad in cossie
  3. ka non starter
  4. 1987 Saphire front bleed nipples -need to replace
  5. S1 Turbo - Big Misfire & Loud Tappet Noise
  6. roofs rotten
  7. Factory CO setting 2wd saff cossie
  8. rebuilding 4x4 rear diff
  9. 94 escort 1.8d van is slow help !!!!
  10. altering wheel offset question
  11. Fan Prob on Saff Cossie
  12. towing help?
  13. Mk3 Fiesta creaky steering.
  14. Fiesta 1.3 Endura E aux belt issues
  15. 52 reg focus 1.6 engine swap
  16. new starter solanoid????
  17. Help please - new bonnet catch/latch
  18. oil leak on saph cos
  19. Ford Part No. for Cam Sensor......
  20. rear parking sensors
  21. escort rs turbo fuel pump wiring
  22. gt30 on 4x4 manifold???
  23. Turbo combinations. Ford + Non-Ford.
  24. 2 wd sapphire brakes
  25. 1600 pinto gbox
  26. mondeo offset alloys
  27. 1.8 Endura Drain back, fitting valve.
  28. ZVH Breather Return
  29. escort van wont start, the chipped red key pos?
  30. focus, no drive
  31. whats up with my frst.....
  32. 4x4 saph cosworth running prob
  33. Charge cooler question
  34. cosworth 4x4 fuse number 19
  35. Escort XR3i MFI cutting out when hot
  36. mndeo 2003 alarm keep going off???????
  37. 2001 Focus 1.6 not starting
  38. 1.6 efi help needed
  39. M-Tech V4 management opinions
  40. 2003 03 Mondeo Zetec Auto playing up!
  41. Engine rattle Focus MKII
  42. Rover zr indicator fuse blowing
  43. 2.9 xr4x4 electrics
  44. mk4 escort xr3i rear camber adjustment?????
  45. Fiesta 1.4 TDCi smoking
  46. P100 power steering
  47. juddering!!!
  48. Metering unit
  49. HELP!!! xr3i efi running rough
  50. zetec carb and ignition question
  51. brake bleed nipples
  52. xr3i help needed novice at work!!
  53. mk4 fez 1.3 lock problems
  54. 1.25 zetec Aux belt tensioner help
  55. Escort Tdi Clutch cable adjustment
  56. power steering
  57. champion eon 2 spark plugs
  58. Some questions about adjustable suspension arms (for camber)
  59. Why o why won't it start
  60. mk4 fez black top alternator/rad/waterpump options
  61. 1.8 tdci foucs tunning
  62. heLLO
  63. Zetec Turbo help
  64. ST170 throttle cable
  65. Ignition leads
  66. ST170 error code P1518
  67. 2wd drive shafts
  68. Samco blue
  69. Do these plugs look like im burning oil?!
  70. Ford Focus TDDi starting prob...
  71. ford courier diesel
  72. Air injectors making a noise>
  73. please help
  74. lambda sensor connection missing
  75. 2001 transit 350
  76. Escort 1.8D Van - Fuel tank not venting
  77. Diagnostic Connector
  78. how do i fix a drivshaft like this
  79. Open airfilter?
  80. help!!!!! my s1 wont start
  81. Focus Rs mk 1 Conrods. Where can i buy them???
  82. Rear disc trouble
  83. smoking esco rs only downhill?
  84. knocking or clicking on full lock
  85. idle problems escort s2 zvh
  86. transit 350 05 reg clock fault
  87. ford focus front and rear axcel conversion
  88. Fuel pressure reg upgrade
  89. rev counter problem (HELP)
  90. Motor for electric hood
  91. Swapping 1.8 for 2.0 in zetec fiesta whats involved?
  92. Mondeo ST A/C not working??
  93. saff cossie front anti roll bar
  94. cosworth big end size
  95. hart plenum
  96. Cosworth Long Stud Torque setting?
  97. old diesel van
  98. main shaft bearing removal ?
  99. zetec custom inlets on ebay
  100. Ignition relay
  101. setting 4x4 idle speed
  102. Saff cossie takes ages to tick over right
  103. focus 2l zetec clutch upgrade help
  104. s1 not getting power to fuel pump
  105. 2001 Mk5 Fiesta Endura 1.8 TD Squealing belt problem? Maybe cambelt tensioner? Urgent
  106. best management for black top fezzy
  107. My mondeo has died :(
  108. Engine Management Light
  109. Cosworth engine grinding noise (with video)
  110. Mk4 XR3I EFI ECT SENSOR PART NUMBER?
  111. group 4 inserts....
  112. MK5 Fiesta Zetec S Missfire
  113. Mk4 XR3I EFI Running Lean?
  114. cosworth idle control valve
  115. 700-800 bhp
  116. Converting lifters
  117. Which Gear Knob? (Sierra XR 4x4)
  118. bosch 044 fuel pump
  119. Rear, right side brake not working - ST170
  120. Too Much Retard cause Misfire?
  121. help. what ecu???
  122. Fiesta 1.25 Emissions Problem
  123. Any diesel experts out there? 1.8 fiesta
  124. 90 spec xr3i efi to carbs use return line for pump ?
  125. anyone that use's L8!
  126. Ford or Pattern Parts?
  127. Ka 2.0 ecu wiring info.
  128. Ka 2.0 zetec rad trouble.
  129. please GOD help me before i torch 12 years of hard work...
  130. cossie resting
  131. zetec in a mk4 van
  132. Noisy Mondeo ST TDCi
  133. What diameter are springs cups on avo coilovers as i need to order a spanner!!!
  134. Air con rad/condenser
  135. Escort 1.6 zetec running problem
  136. how to change gearbox bellhousing???
  137. 3 door escort glass fixing?
  138. MK3-4 Questions
  139. escort 1.8 gti missfire problem
  140. escort td 99 v reg no turbo
  141. fiesta mk1 zetec
  142. Fiesta 1.4 TDCI ABS problem
  143. 3dr front grill
  144. Mk4 Escort Popular, to rst bumpers/skirts/arch extensions
  145. series 1 wont start
  146. Escort S2 Reverse issues
  147. Is My XR3I HC Level To High?
  148. s2rs turbo
  149. Mk 4 escort popular to rst axles/suspension?
  150. 17 Diamond cuts on 3dr, what brakes will fit.
  151. xr2 calipers 4 pots
  152. airtech rad on fez
  153. swapping 1.6 to 1.8 130 spec
  154. 1999 1.8 55 Van crunchy gear change from 2-3
  155. Removing Weight From Rotating Mass
  156. Vernier Cam Tourqe Setting
  157. 1.4 cvh efi running pats
  158. turbo technics turbo help
  159. radiator fan
  160. pulling my hair out
  161. zetec ecu wiring
  162. Gearbox oil
  163. 4x4 rear shocks
  164. fitting focus front fog lights
  165. st170 vvt prooving
  166. Focus 1.6 115 Coil Pack 05 Plate
  167. what to do...?
  168. air con problem can you help
  169. paint colour help
  170. Fiesta 1.4 Zetec low rev misfire
  171. Escort Mk6 Fuse Box Problem??
  172. 1.8 xr2i clutch
  173. RS 2000 fuel pressure
  174. newbie needs help
  175. Dodgy brakes
  176. Escort Van 1,8D immob problem
  177. MK6 Escort lundging forward
  178. mondeo 20 ltr petrol
  179. focus
  180. IB5 question
  181. xr2i 16v front seats
  182. 2.0 Zetec Focus problem, please help
  183. focus st with fault code C1288 (esp fault) need help
  184. How hand tight do you do up a oil filter?
  185. kev
  186. Silver Ford Paint.... Machine & Moondust
  187. How hard to change cossie cam pulleys to Verniers?
  188. Low idle, no power, cylinders 1 & 4 not working
  189. Brake fluid in drivers footwell? :(
  190. rs turbo main beam not working
  191. 2005 Focus 1.8 TDCi engine cut out
  192. ford focus 1.6 zetec 2003 cooling fans running from cold /is this a cht sensor fault?
  193. Focus Newbie - Hesitation ????!!!!
  194. FRST master cylinder problems
  195. I have a supply for you all !
  196. spamming wanker
  197. Cossie 4x4 vibration round corners
  198. Bloody fuel relay
  199. what bigger wheels can i fit to my XR3I
  200. mondeo mk3
  201. 4x4 cosworth temp sender Location
  202. Alcon 6 paddle + cambelt change question AND WHAT TORQUE for the v-belt pulley bolt
  203. Oil temp sensor
  204. help fitting a fez turbo engine in a mk4 efi cabriolet
  205. Camshafts
  206. Mk3 Fiesta XR2i Engine Conversion - Help Needed.
  207. Help Please. Zetec Woes!
  208. cosworth missfire under load only in hard excelleration in 1st gear
  209. please look!
  210. ford focus tddi 2001 sundden loss of power but still runs ok
  211. Hesitation/holding back problem still
  212. Fiesta MK6 central locking
  213. L8 ECU fault finding help
  214. Xr2i idling problems
  215. ap brake kit fitting
  216. Heat Wrap
  217. diamond cut 17inch brake size
  218. 5000 RDS - CD Changer Error code
  219. Sump Gaskets, Should i use a sealant?
  220. fuse box terminals
  221. 3 door cosworth LOST power to the fuel pump??
  222. single, powerful boot lid struts?
  223. looking for a photo of the cvh efi drivebelt set up
  224. Saff Cossie 2WD Brake Issue
  225. RST manifold damaged - can they be fixed?
  226. p1666,p0149& p1564
  227. help req with brakes/wheels on my cossie
  228. Brembo brake questions...4 pots
  229. Help please god! Rs mk1
  230. best place to get new anti rattle shims for ap brakes?
  231. Saph's draining
  232. Escort van starting problems
  233. fezza brake lines
  234. FRST brakes?
  235. Mk6 Van Steering Wheel Options
  236. Boost problem
  237. Wax Oil.
  238. TD dump valves
  239. Bleeding ABS unit
  240. Clifford Concept 50
  241. Timing belt for p100 td
  242. Sump gasket on a fiesta 1.25
  243. Changing Ford KA (2003) Brake Discs
  244. Misfire - bet you've no idea...
  245. Nitrous and ex.turbine housings..
  246. Rst not starting
  247. Duratec Conversion Zetec S Immobiliser HELP!!!!
  248. Urgent Help please !!! Can i use an XR3i master cylinder.....
  249. advice on removing a snapped off temp sensor
  250. piggyback, no hazards
