View Full Version : Technical help Q & A
- Cosworth LSD rear diffs, lame and need tightening
- Need a bit of help with a focus ST170
- Mondeo Titanium X Rear wheel alignment
- yb rocker covers
- 2005 transit 2.0 125 bhp tdci problems
- cosworth power steering
- hesitating zetec please help
- erst fuel regulator (upgrade)
- strutbrace problem on cvh sapphire
- Mondeo Mk3 TDDI Underpowered/Injectors?
- Mondeo drive shaft
- Ford Mondeo 2.0 TDCI 130ps fault code p0251
- Which fiestas use tripods on gearbox side
- RST Head Gasket
- cossie 4x4 pissing oil through the head
- Ford Focus Estate engine fail
- mk6 escort td waterpump
- Escort front windscreen
- No Dipped Beam on Escort
- Yb 2wd breather system.
- Oil & Cold Starts - Good Advice from Opie Oils
- Rear Lighting Fault
- focus tdci ecu
- help required, dangerous steering problem!!!
- Any one with a rst powered mk5 fiesta
- ABS Light 2wd Cossie
- SAAB key fob not working.
- 4x4 boost fault
- focus 1.6 mk1 zetec se running fault! help!
- Mondeo front fogs not working
- C1155 code ABS and traction control lights on
- i need some torque settings
- Ford Ka 1.3 revving probs
- accelerator pedal ford mondeo
- Cam timing
- Mk1 Focus Ghia TDCi heater & blower
- ford 6000 cd rds code help
- Cosworth Running Problems
- Clunking/Griding from real axle
- Cossie t5 burton's hydraulic clutch conversion
- zvh help can u help?
- electrical power loss
- Gearbox and axle ratios.
- cosworth managment wiring...
- alternator charging theory
- I changed the engine but she wont start when hot
- Coolant Pipework ?
- where to get supercharger kit for blacktop?
- 2.0 twin cam serria wont idle properly?
- Bearings/hubs.
- to the bike throttle body lads
- Mk5 Fiesta 2.0 Zetec Conversion
- OIL LEAK
- focus tdci won't start/run
- mk1 frs power steering now with pic
- 02 mondeo cd player trouble
- mondeo tdci recurring fault
- alternator belt noise
- Mk3 xr2i rear bumper
- Xr3i EFI Fuel pump problems
- Mk4 Fiesta Central Locking Fix
- fiesta loom conversion help
- Focus problems
- 1999 Ford Focus TDDI EGR BLANKING & tuning HELP PLEASE
- fiesta xr2i to rst conversion help needed please
- 1.8 Zetec Stalling!
- More problems!!!!
- Idle trouble.
- FOCUS Engine Systems Light HELP !!
- Cosworth VIN plate with color - how to read it?
- t34 specifications
- YB Coil on Plug / Direct Fire Coils
- erst metering unit no fuel help !!
- Mk3 escort gear linkage help
- Rs Turbo Kent Cam Timing With vernier
- fiesta charging fault
- 2004 focus tdci sport starting issues
- st170/normal focus mount question
- galaxy auto rev counter problem
- Focus ST Start button
- mot questions and answers
- tuning in the midlands
- O/S/R indicator not working focus RS mk1
- Pinto Turbo
- focus tdci smokey and glow plug light flashing
- My Mk4 Fezza..
- Failed MOT - Technical gurus required
- steering issue, urgent help needed!!
- running prblems
- Focus mk2 1.8 Tdci air leak under load??
- 2.0 litre escort mk6?
- ecu help
- ecu help
- RS Cosworth Steering column
- Ford Focus Front Electric window
- focus heated seats problem
- heating in my car does not work
- zetec s thermostat.
- What size of Torx?
- Can someone help please.
- Wich diagnostic tool can I use on my mondeo st200
- Head Gasket
- Ford Escort Van R reg 1.8D normal aspiration problem
- Sierra DOHC 8v Turbo Selection Help
- 1.8 zetec rattle
- Focus ST170 2002 traction control light
- Focus 03 ST170 engine management light on
- Bad idle
- peugeot 106 warning lights
- 2002 Ford OBDII questions
- Zetec Turbo - Info required.
- MK3 Escort Panels
- CVH Cam Pulley Problems
- Steering slack Mondeo Mk2
- HELP - Focus 2008
- ford escort mk4 1600 oil Engine
- Zetec cam cover
- Stack Boost Gauge..........
- A note on injectors and bhp
- zetec s / rs turbo
- swirl pot
- 205 block
- Mondeo MK2 fuel gauge is going in reverse??
- M12 x 1.5 alloy sensor boss needed (To go with Omex ECU)
- July 2003 Mk 3 Mondeo, Water leak in boot.
- Removing crank bolt without special holding tool?
- Gearbox quiz....
- Fuel Return Pipe Mondeo TDCI help
- Maserati Marelli
- focus electrical problem
- Bike throttle bodies
- Petrol leak
- Rad and Interior Fan Fault?
- wheel bolts?
- Sierra Electrics Help
- help!!
- Escort RS2000
- Fan/Aircon
- whining noise
- Overheating problem help !!!!
- 1.6 and 1.8 cvh sump differences ?
- Tuning - Where To Start
- Mondeo mk2 Heater problem
- Fuel pump mk3 fiesta
- mondeo tdci remap
- Whats the best oil for an FRS mk1?
- Cast iron welding???
- Can't open XR2i bonnet!!!
- MK3 Fiesta, 2.0ltr Zetec
- cosworth timing marks ?
- help with ecu mapping on cosworth bob
- escort van 55d 2000 charging problem
- zetec will not rev above 4k rpm
- RS Turbo got a hump
- Focus diesel
- Car is now off the road and what to do?
- RS Turbo Valve Spring Caps
- XE,ing MK3
- whats involved to swap a cossie t3 onto a s2??
- s1 rst cold idle problems
- Mondeo 130 bhpTDCI zetec-s
- 95 Escort Steering Wheel removal/Hazard Problem
- How many miles from new turbo?
- Escort MK5a Indicator/wiper Stalks
- RS Turbo Oil Pressure Gauge Fitment
- engine/gearbox mounts
- Erst ecu help
- xflow cam question
- alloy wheel?
- GT28
- saph cosworth rear brake dust shields
- Parts information please
- Fiesta RS1800 ignition
- speedo problem
- Anyone with experience of engine building....
- t5 reverse lite switch, push to make?????
- Focus ST 06 :-(
- Rs2000 turbo
- MegaSquirt for my Cossie?
- A Stab In The Dark - Toyota Hilux Surf 3.0TD KZN130 Engine Oil
- 2.0ltr Mondeo ghia auto
- Intercooler options zetec turbo
- 89 erst erratic fuel gauge
- reverse light working opposite way round cossie???
- Mfi to efi
- XR3i 1.6 mfi to RS turbo mfi HELP!
- Focus 1.8 Tddi glow plugs problem
- picture request- Rouse sport cosworths
- sierra1.8 cvh cutting out after running for a while
- 1.8 TD fuel problems
- Upgraded fuel pump??
- radio help
- Ford Focus 1.6 Zetec SE - More problems..
- Scorpion exhaust
- valve seat grinding?
- T3 Boosting Issues!
- lights on dash perm on!
- saff cosworth wiring loom
- 51 mk5 fiesta only blowing out hot air
- cosworth oil leak
- Help Fiesta cut out mark3 1995
- xr3i mfi help, cabriolet
- Which fuel pump for stage 3 ?
- 2.0ltr Redtop in mk2/mk4 fiesta..
- Cvh oil pressure
- 4x4 power steering rack seals
- Cossie Dizzy Removal
- URGENT INFO NEEDED...Water Injection.
- cvh head
- megajolt map for 2l blacktop zetec on bike carbs
- cos 4x4 exhaust
- Changing Mk3 escort roof?
- XR2 carb - 32 DMTR v 32DFT
- supercharged Cossie YB
- 4x4 lambda location
- Cosworth YB and Turbo query
- 1.25 Fiesta Zetec..
- Default "Sloppy" gearbox - '98 1.3 Fiesta
- Heater fan wont work, help please!
- Few RS Turbo Head Questions?
- 2wd sapphire clunking noise
- Pressure in the head
- 3 bar map sensor , please read
- focus speado change
- St170 head gasket
- 3dr missfire help
- Blowers only blow cold & warm air, not hot!!!!!
- Escort cosworth clutch ratchet
- Please help.
- 2001 old shape focus starting issues
- Fitting parking sensors and extra light to new transit
- cossie very sluggish in low revs
- Fitting powerflex front top shock mount - sierra
- Omex rev limiter Escort zetec mk6
- poorly xr2i
- MIS intake plenum weight ?
- mk6 04plate fiesta - what engine conversion?
- Distributor plug Cosworth
- 2006 Fiesta- Brake light on instrument panel on constantly
- 2004 mondeo tdci ghia 130 engine cover?
- help needed with manifold
- Track mk3 Fiesta suspension alignment.
- Transit Connect engine bay layout
- Heat proofing bulk head...
- XR3i Help
- Focus TDCI Slow starting in cold weather
- Incontinent Cosworth
- urgent help needed 1.8 sierra
- Engine Not quite right in Girlfriends escort cab
- Fiesta RST Compression Results
