View Full Version : Technical help Q & A
- mk4 carb
- 3 bar map sensor
- Ignition - Conflicting Info - What Works?
- cosworth chip numbers
- xr3i fuel pump part number help
- Battery Cable
- Split turbo/downpipe gasket?
- zetec conversion
- Steering wheel refurb
- nissan 280z
- mk6 Escort rear drum jam
- 2wd cosworth diff mount
- YB valves worn how can i tell
- mk4 xr3i mfi info pleeeeezz...
- Misfire when hard on boost help!!
- electric problem
- 3door anti roll bar links specs
- help needed wireing diagrams
- exhaust
- plz help before i put a hammer to it
- 2wd BD14 cams, setting up timing??
- 1.8 diesel engine
- mk4 cab electric roof q's
- St170 head overheating
- Misfire above 4k
- ofab map sensor superssor
- Bike carb queries...
- 2.8 Cologne problem
- zetec ecu
- Sierra LX Grey stuff on doors. What its it.
- tldm carburator 28/32
- xr2i 16v overheating
- st 170 clocks lights not working
- starting y s2 rst after 14 months
- Zetec turbo questions...
- 2000 2.0 petrol focus traction control fault
- Auto Sierra not cranking??
- Escort mk 5-6 front coil springs
- St Wheel removal Escort Pop?
- Whats this?
- Focus TD DI - Fuel leaking from somewhere!!
- Injector Question...
- major need of help
- Running in oil
- New Cambelt noisy 1.8 Zetec
- Sapphire 2WD shaking @ 3000 rpms
- Coolant flush
- efi 1.6 rs turbo sensor help, rough running issue
- saph cos 4x4 trans probs
- Ecu help
- Serious/Hefty leak from switch on newly fitted gearbox?
- Cossie rebuild advice
- 2002 focus tdci injector coding
- 3dr cossie drop links
- The engine warning light is on, on my Ka Dashboard?
- flashing hazard warning
- mk4 xr3i to zetec 18 or 2.0 ?
- I have no brakes?
- private plate question B3EWY
- 130bhp upgrade
- focus wont start
- 2 bar of boost on standard injectors?!?!?!
- spec me a turbo
- ford focus footwell lights
- Hub Nuts ?
- i.c.e help reqd please
- How to adjust boost
- AT Power throttle bodies
- Wiring stereo to parking brake.
- RS metering unit
- Grease on a gasket?
- zx9r b1 carb jets on 2ltr zetec?
- 2.0 Pinto rebuild
- Oil Pressure Switch - What Thread?
- reverse sensor help?
- mondeo cutting out
- brakes
- Xr3i cab boot popper
- best place to buy
- help needed hand brake xr4x4
- mondeo st155 tdci engine noise help!!!
- s2 rs turbo flywheel
- Running warm
- Aux input not working
- New driver, New to cars, choose Ford KA, but no manu' manual. Help?!
- Chip help
- radiator leaking!!!
- tddi fuel leak..
- 1.9 mercury turbo engine
- Ford Focus TDCI 2004 Glow Plugs
- Unknown New Old Ford Brake Servo. Ideas? Escort Mk1/2?
- focus cooling fan problem..?
- escort mk4 engine conversion
- sierra decals
- Gear change
- Mk2 Escort floor pan
- Pedal box
- mondeo st tdci
- 02 reg 1.8 16v duratec engine misfire.
- Focus Traction Control
- 2004 Ford Focus Overheating
- Ring gap help
- Year 2000 Focus - Noise and Vibration when turning left
- Front passenger side vibration over 50mph
- 2009 Focus ST Crusie control
- Zetec Turbo help
- what speedo for focus rs box?
- Wiring and plug question - XR3i mfi
- Help with wiring diagram escos lambda
- Sunroof help please
- cosworth t5 gear oil
- B&W T-5 shift ... ???
- anyone else clued up on 5v
- anyone know of this strange problem?
- Is this a mk6 gearbox, and will it go in a mk5?
- focus rs gearbox, what shafts can i use?
- Escort GTI Magnex backbox
- turbo Identification ???
- focus mk1 maf sensor
- Changing mk2 mondeo wheel studs
- Boost Gauge......
- 18s on 3 door cossie
- cracked rocker cover
- EFI Turbo. No spark
- Cambelt snapped on 1.8D Endurance DE
- Crank angle sensor
- Weber Carb differences
- sapphire 4x4 engine mounts??
- urgent help now with pictures
- Starting issue with Mk3 Focus 1.8 TDCI
- Toad Ai606 wiring diagram
- good spec cosworth engin or not ?
- Tuning A 1.8 TDDi 90PS Engine - Intercooler??
- Cosworth cam question
- Driveshaft rubber boot change(front) on escort cosworth
- Turbo pic. Is this oil weeping and is it normal?
- Gearbox off
- Focus ECU and loom
- How much work, from mk4 to mk3??
- Zetec turbo, cos management
- sierra cosworth back firing problem
- saph steering rack 2wd and 4wd the same?
- Mot question
- Trouble putting vibra-technic mounts on.
- 1994 16v xr2i power steering
- Ford Focus Problem with Dash Dials.
- escort 1998 idle speed control valve
- 4x4 breather fitting help!!!
- please help
- 1.6 Zetec where does this pipe go?
- 7 1/2 diff
- efi turbo into rs turbo
- Is 1.3 rad sufficient
- tuner/aftermarket wheel nut suppliers
- nickel liners ???????
- Coolant Route YB..........
- golf tdi
- newbie help with st170
- Please can someone talk me through my ECU options?
- seatbelt harness eye bolts
- engine quiery
- Focus Mk1 Headlight leveller
- ST170 DIY Head Work
- Focus ST 170 cutting @2500 RPM?
- 2 bar map sensor??
- new owner question and photos
- wheel bolts to wheel studs
- Suspension and wheels for xr3i 86 ??
- low bitting point on 4 paddle
- RS Focus Mk1 - Engine Cuts Outs
- 2 different injectors on 130 bhp tdci mondeo??
- Quick Zetec Conversion Question - Inlet
- focus RS MK1 Electrical Fault
- Siemens 55lb Fuel Inj. "O-Rings"
- bike carbs on fly by wire throttle
- YB cam cap studs
- PLEASE HELP! serious braking problems
- Problems with speedo and door warning light...
- How do you adjust scorpio idle?
- 1.8 zvh conversion n/a
- berlingo
- megajolt management on a zetec
- boot spoiler caps 3 door
- power plot
- dohc 8v forged conrods
- Help Needed!!! Snapped speed sensor
- rear brakes on a xr3i 1986 cabriolet mk4
- Ford Focus - Rear / Side / Dash lights not working
- Aftermarket ignition...
- central locking!
- please help me lads!!!!!!AHHHHHH.........
- Gaskets
- tail gate opens by itself
- ST170 Aftermarket Cams+VVT worth the risk?
- Focus rough running after fuel filter change
- Upgrading Focus 1.8 Cams
- Zetec Engine Wiring
- What does these relays do ?
- sierra tacho to zetec loom
- cosworth rear wishbone
- ARP Con Rod Bolts
- time clock swap
- Help witc bc gearbox
- Focus ST gauges in mk1 Focus?
- Canister purge valve???
- sierra sapphire 1.8 cvh cutting out
- Ka Charging problem
- what could this be?
- cvh efi frst vac and icv piping help!!!
- advice needed s1 swirl pot and turbo water feeds
- new owner questions.???
- mk2 mondeo 2.0 fuel consumption
- powder coating coilovers
- Engine change - 1.8 to 2.0 Zetec
- (2000) Ford FX 3000 CD Player
- Petrol tank
- Oil breathing problem on Zetec Turbo
- Gaz gold coilovers on rear of sierra.
- ka central locking ?? remote key work or not?
- Cossie Battery Voltage Woes
- Blue Alternator Wire...
- Mk2 Mondeo 1.8 Fuel Consumption
- Focus St3 sensor problem
- Zetec throttle bodies
- blacktop rocker cover problem
- escort gti on tb's
- xr3i efi to rs turbo
- cvh efi
- Need My T5 rebuilt ASAP
- mk2 escort brakes
- escort cosworth propshaft
- One for the electrical/electronic gurus
- 1994 mondeo 1.8 mistral
- bodywork conundrums ...
- Warped block??
- Bailey oil separator
- oil pressure
- Zetec Trigger Offset...?
- smokeyyy
- Wont start after rebuild
- Front mount alternator
- overheating focus
- Dash Light Bulbs RS Turbo S2 1989
- RS Turbo Remote Central Locking
- Help! From IB5 to MTX75.
- anyone able to help
- Mk3 xr2i 16v zetec fuel problem???
- CV Joint Sealant - Sierra
- 136k Zetec donor engine
- 205 gti, 1.9 1.6 fit the same??
