PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. cosworth plenum pipes
  2. Zetec Turbo Manifold
  3. Focus st170 vac pipe question
  4. 2.0 Blacktop Turbo Questions
  5. rs1800 rear brake to rear brake rs2000 questions
  6. Rst conversion help?
  7. Rocker cover bolts....Any order?
  8. focus conversion
  9. Shogun sport window scoosher problem!
  10. Need a quick reply on something please.
  11. 1999 focus running prob
  12. Compressed headgasket measurment?
  13. Camshaft oil seal....Help!
  14. Earth Problem?
  15. smokey escort van
  16. 4x4 clutch pivot pin
  17. Jumpy Speedo needle on mk4 Escort
  18. 2WD saph boost loss and running rich
  19. 2wd and 4x4
  20. Wiring Help
  21. Time to swap
  22. running rich cozzie
  23. 2001 focus lighter socket probs
  24. Converting to Rear Discs
  25. remote oil filter with oil cooler and thermostat
  26. sierra headlights (mk1)
  27. Gartrac RWD oil cooling issue
  28. Lost all keys (PATS)
  29. festa 1250 r reg wont start ARRGGGHH
  30. Getting a bluefin unit recoded
  31. not running
  32. Injectors with number 3522/10
  33. Will not run above 5500 rpm?
  34. hi all new member
  35. cosworth wont start
  36. aftermarket speed, vss wiring help needed.
  37. cosworth amal valve piping
  38. Has my alternator gone?
  39. 2wd cosworth head lining
  40. Throttle bodies
  41. Help needed Escort RS Turbo - Idle problem
  42. ka gearbox
  43. lots of oil in breather
  44. ECU
  45. mondeo tdci sluggish, lack of power
  46. zetec block
  47. Pinto motor build
  48. Focus ST dump valve help
  49. Fault codes Mondeo mk2 1.8 zetec.
  50. what needs to be done to a cosworth engine to take a T4?
  51. springs on my 3 door please help
  52. unlock pectel T6 ecu
  53. Oil leak.....Please help!
  54. turbo seal or rings??
  55. Zvh gasket
  56. ST170 brake fittings size
  57. Actuator tuning
  58. Mk4 Escort XR3I Brake Bleeding
  59. The fuel mixture screw doesnt work on my metering unit
  60. mk3 mondeo bonnet wont open
  61. Ford 6006E CD player Keycode required......
  62. Been away for a while now back with probs
  63. Heatshield fixing
  64. traction control 2004 ztec focus
  65. Ka engine swaps, 1.3 endura to N reg 1.6 16v Escort Engine?
  66. rst s2 pulling back popping exhaust louder ectect
  67. Focus Help with leak
  68. revs
  69. focus loss of power
  70. St170 fault code Advice
  71. 2wd or 4wd
  72. Rs1800 Zetec sensor locations
  73. Orion rs turbo conversion
  74. 2wd gear box
  75. Clutch problem
  76. Crank Bearing tightening sequence
  77. Does anyone know what size the thread is on the air temp sensor on a 2wd cosworth
  78. ford mondeo hard to put in to gear????? help please
  79. Which fuel tank for zetec turbo?
  80. mondeo st24 poorco at idle
  81. ADVICE mk2 escort bonnet release
  82. Clutch Problems
  83. ERST mk3 S1
  84. fuel additive
  85. mk6 escort driving me mad
  86. Mondeo TDDi Solid Flywheel conversions?
  87. Focus ST170 wiper problem
  88. Advice on braided lines/aeroquip - Fuel and brake
  89. Head Depths??
  90. 53 Mondeo 130 TDCi and black smoke
  91. clearing ford codes
  92. Cosworth alloy pulleys
  93. help mk4 escort lower steering column bush
  94. xr3i failed its mot today, wiring trouble, heeeeeeeeeelp please!
  95. Focus TDCi engine rattels
  96. 2wd bulb check display
  97. whats the part number
  98. 1.8 zetec running issues
  99. Can you help me fix my brakes?!
  100. Focus tddi egr blanking
  101. Which 15's fit st170?
  102. oil choice for zetec turbo engine
  103. Turbo Boost Problem
  104. Non Starter Help needed S2
  105. hi series 1 problems
  106. transit power boost help
  107. Why is coolant coming out of here?
  108. focus anti-roll bar link rod
  109. over fueling cossie
  110. ECU Info- 2 Litre Blacktop
  111. just a efi quiestion
  112. RS2000 conversion
  113. escort s1 clear indicators
  114. ECU gurus...
  115. what poundage springs????
  116. Car heating up too quickly
  117. LED Flasher Code Reader
  118. replacing the aux jack shaft bearing
  119. 2.0 mondeo coolant leak
  120. Bell housing bolt patterns / gearbox choice
  121. Mk1 Mondeo 1.8 (Zetec Engine) Problem
  122. turbo choice ?
  123. Removing stud exhaust manifold cossie 4x4
  124. 2wd koni suspension
  125. Ford ka duratec engine
  126. Ford Focus looses power when driving
  127. Focus 2005 / MK2 Door lock install
  128. 00 focus indicator problems
  129. Cosworth loom help please./ think its fucked.?
  130. can the wrong oil make a turbo leak/smoke???
  131. Cossie oil change
  132. Saph roof lining
  133. Romraider, anyone on here used it? Chip?
  134. Focus break help
  135. Cosworth underseal
  136. boot release not working?
  137. NOS Controller
  138. Does anyone have an esc module they can sell me?
  139. whos's fitted a b&m shifter to their cosworth
  140. brake upgrade sierra
  141. Focus Overheating
  142. Focus ST170 Smell of Fuel Fuel In Water
  143. Alloy Camshaft Cover for Sierra DOHC?
  144. saph koni new rubber gaitor can you buy them?
  145. has anyone got any steering column diagrams?
  146. saphire cosworth clutch noises.
  147. vibration
  148. ST170 Focus Alarm!
  149. injectors
  150. 2wd Sapphire Cosworth fuel pressure
  151. Pinto Cylinderhead std height???
  152. Mk4 Escort Brake Bleeding Procedure
  153. Ignition amplifiers
  154. P100 looking for new engine?
  155. Escort 1.8 diesel cold idle probs mk6
  156. Escort mk4 suspension on mk3 ?
  157. Wiring problems No fuel or spark???
  158. ofab efi what pressure regulator will xr3i efi work ok?
  159. OFAB QUERY,do i need a vehicle speed sensor?
  160. Castrol GTX 15w 40 High Mileage
  161. 7.5" ZF plated diff and T5 Glebe dogbox
  162. Galaxy abs !!! Neeeeeeeeeeed help !
  163. Ford KA 2004 Misfire on Cyl 2
  164. what do i need to cool my oil
  165. Ford Ka 53 reg, changing alternator
  166. Few questions....Focus 2.0 Zetec
  167. Anyone With IDS near Bedfordshire
  168. 2wd clutch slip
  169. what different ways are there to deal with rocker breathers
  170. instrument cluster
  171. V Noisy Tappets
  172. mondeo radio swap
  173. new built cvh didnt fire... now does... sort of ?!
  174. Zetec help
  175. Anybody familiar with assembling the MTX75
  176. Fuel pump help
  177. a quick sierra cosworth id question
  178. Where can i find a replica ford focus mk1 wrc full decal kit 2000
  179. cosworth coil rewire
  180. cosworth engine strip and rebuild
  181. coilover rebuild help
  182. Can it be got ?
  183. Zetec Lowered Compression Help
  184. focus miss fire... coil pack?
  185. Installing Sub and amp.
  186. Escort series 2 lsd
  187. blue smoke !!!
  188. seats and seatbelts
  189. not starting with key after a d-td conversion
  190. zetec se
  191. Does anyone know were i can get.....
  192. ARP conrod bolts
  193. Welding...
  194. Cosworth fuel line ends
  195. 74c thermostat on rst
  196. 83lb seimens black injectors part number?
  197. at what revs will my turbo kick in roughly?
  198. 4x4 CTS location and Fault codes
  199. escort s2 fuel actuator
  200. rs2000 recaros
  201. Saph cos fog lights
  202. cvh 1640 tuned = 64 bhp? help please
  203. 4WD Cooling
  204. Bodywork and Restoration Help!!
  205. New RS Turbo Owner - 1.6 CVH In XR3i - Some help req please!
  206. ST 170 clicking steering?
  207. Escort G3 code 10 error code
  208. pinto injection wont idle
  209. Are there any quality aftermarket pumps for Foc RS mk1?
  210. Smokey Mondeo
  211. Mondeo start motor removel
  212. Clutch pedal
  213. 1998 Focus 2.0 Ghia - Timing Belt failure ??
  214. focus traction control retrofit/kit
  215. fitting new new wheel studs.
  216. Fog light bolts fooked
  217. Problems fitting 2wd Saph poly diff mount?!
  218. Code missing
  219. Those little bulbs
  220. Power steerin pump/ pulley cosworth 4wd
  221. help needed engine stuttering/jerking when accelerating
  222. ford sierra computer
  223. Which turbine housing is better for my 2.0 turbo
  224. MK4 escort zetec question
  225. Knackered Mk6 Gearbox?
  226. missing
  227. Help needed for Zvh CR....?
  228. what car would they fit
  229. escort mk3 door hinge pins
  230. Mk4 XR3I EFI Cabriolet Rear Barke Cylinders?
  231. 2007 Galaxy 1.8 TDCi
  232. Courier 2.5 Turbo Diesel smokes
  233. Escort cos leather
  234. 3 door engine loom into a saff, quick question
  235. Cosworth brakes
  236. Focus 1.8tdci, non start
  237. rear discs on van
  238. what conrods for 500hp sierra cosworth engine
  239. changing spark plugs
  240. not starting
  241. juddering in 2nd
  242. warning light display problem
  243. Cosworth oil pressure ?
  244. help on zetec timing
  245. Shrader/shreader valve on ford mondeo 2003
  246. need help with my car
  247. Cosworth Throttle Cable Adjustment ?
  248. Cossy headgasket best place to get one
  249. 2 liter z tec,xr31,rs turbo lumps
  250. s2 escort not running right help!!!!!
