- Crossflow wont rev out
- Crossflow cam set up and advice.
- setting the timing and fuel
- Ford ka 2010 indicator bulb replacement
- does oil filter size make a difference
- Has anyone fitted the oil filter housing from a 4x4 cosworth to 2wd
- Cosworth WRC header tank question......
- gear box problem
- puma 1.7 throttle bodies
- granada cosworth?????
- low boost
- YB core plugs head and block
- Think I'm gonna keep the cossie now :-) but I can't find a decent welder
- Help help help ahhhhhhh...... :(
- Free rev problem , HELP needed
- v6 bob
- mk2 xr2 gearbox oil seal help...
- Free rev problem !
- radiator problems
- l8 ecu
- no fuel to the engine
- torque setting
- Sapphire Door won't open
- mk4 rs turbo clocks into 1.3 ???
- Zetec GSXR TB's - ST170 Injectors?
- 1977 Ford 302 5.0 V8 Engine.......bhp?????
- esc cos timing
- Noise comming from cam tensioner/water pump s2rst
- focus rs and escort cosworth brake measurements?
- No MAF?
- few quick efi easy questions
- p100 stainless exhaust
- Fiesta CVH to Zetec
- tyre shoes
- s2 internal fuel pump
- Best place to get car set up
- Urgent help!
- Misfireing on full boost and dodgy idle
- zvh efi cross over pipe
- oil warning light on
- does standard p8 ecu have anit lag and water injection
- Orion 1600 cutting out problem
- 2.3 Duratec build
- 1999 mk4 fiesta nearside wing replacement
- removing wastegate arm from housing??
- Mondeo passenger door won't open
- 7.5" Diff Cover plate Bolts
- no power to the coil
- Ford Fiesta Wheel Trims
- Windscreen wiper fault on Focus ST
- Ford Escort Van light problem
- L6 ECU
- Rs Turbo head gasket
- Speaker help
- Ford focus mk1
- 2.5 Duratec L5 five-cilinder in a MK4 Escort?
- Random Fiesta PAS problem!!
- mounting my swirl pot help
- Constant Vibration
- p100 fuel tank
- Escort 55 van laden valve/brake question
- fiesta fuses
- o2 Sensor question - Focus ST
- What's connected to pin 25 of L8 ecu?
- Thinking of replacing fuel pump
- Nil
- IB5 help !!!!
- What Oil is in 4x4 Saph Cossie front diff
- Escort Mk4 Rs2000 Wiring - Anyone Help?
- Sierra Saph/Cosworth spring help
- Front springs
- 2wd CV joint ??????????????
- Too Low??!!
- front exit exhausts????
- ST220 starting problems
- dellorto 48,s leaking fuel
- focus rs brakes on mk3.5 fez
- Central locking problem ... most annoying!
- fiesta headlight bulbs blowing
- Mk4 clutch issues
- Greye
- 5000rds
- Tightening top strut bolt
- 1.8 or 2.0 conversion on escort auto
- Surging
- Single line Non-return fuel injection system?
- Fiesta ST Gear Box
- 5000CDR
- How to pipe a hydraulic handbrake on a sapp cosworth after binning abs
- Why does my car only missfire under gradual acceleration???
- Can you get protection codes for kenwood stereo
- escort van rear shocks
- hub help
- 500CDR code
- 195 chip beige injectors
- good old glow plug light flashing
- 2.1 Zetec Oil Surge
- wait 30 mins message
- cutting out problem xr3i mkiv
- Esc module on i4
- help converting non rev counter to rev counter?
- What Engine is this from
- Gearbox options
- Where do cossie ISCV inputs come from?
- Metering units!
- Please Help? connecting the plugs in on the back of the inlet?
- Oil pressure switch/sender for silvertop zetec?
- Fiesta Mk6 Engine managment problems?
- Startup problem with 2003 Diesel Focus 1.8 TDCI 115
- Cossie Thermostat
- mondeo starting problem. please help
- QUICK ANSWER NEEDED: Amal valve operation with ignition off?
- Bent valves ????
- Steering Wheel Change
- cosworth std intercooler onto a s2 rs
- Nikasil Liners Silvertop Zetec
- fiesta st
- brake master cylinder..
- zvh tuning...
- Fitting Hi Spec Calipers to 4x4 strut....wrong brackets?
- strange smoke from escort coss
- transit sport 5 speed to 6 speed converstion ?
- 2wd rear brake problem
- Starting/Immob Problem - Is it an easy fix?
- Building ZT on standard comp. can someone spec turbo?
- need help please
- Help Please. Sierra 2WD Coil Wiring
- EEC-IV, wiring, and Mk4 zetec conversion?
- Old Foreign Goon needs urgent help with escort cossy!
- need new discs n pads on my 1.8cvh sapphire
- Blacktop Camshafts
- saph heater resistor..
- 2.1 ZVH head gasket
- Possible pulley/bearing/transmission problem
- solid mounting engine
- help please :(
- ECU Gurus Question
- Focus jumping out of gear
- where can i get an oil pressure regulator??
- Changing my TPS, how do i set it up? (4x4)
- peak and held boost pressures
- How do you mapp ignition timing?
- Converting Cosworth 4x4 MT75 to RWD
- 24v boa engine trouble
- Cosworth Intercooler... Summary of Connectons
- door moundings for mk4 escort
- different grades of billet steel?
- ford ka juddering
- Sapphire chassis codes
- Will a 3 bar work on a standard chip?!
- 2.0 zetec silvertop turbo oil/water feed+return help
- MIL eliminator (DIY)
- anyone got a pic of a escort mk3 fuse box please
- v serial number codes for radio
- Mk1 Focus Zetec lean issue
- 1.8 zetec problem
- Zetec cambelt tensioner query
- Cossie Headlight problems - Escort mk6 van
- tips on cleaning throttle body
- zetec into mk4 escort
- 05 Focus engine mgt light when tank is 1/2 full to full
- Anti roll bar on cosworth 4x4
- focus 1.6 diesel 2005 not starting
- T34 turbos??
- Adjustable lower arms?
- S2 RS Turbo over boost problem
- Rear brake line burst/cracked???
- 2wd/4x4 Spring Question Answer Needed ASAP
- Irregular speedo spikes - jumping speedometer
- Blackeye help...
- Cosworth clutch pedal question 2wd
- fiesta idle speed and fuel consumption
- Sierra sapphire gearbox problem
- would 2.0DOHC lowering springs fit my 1.8cvh sapphire
- NEED HELP !!! 2wd brake problem
- Sierra 2wd engine mount dimensions
- how to clean multi plug
- 4x4 Cossie PCD
- sorry not a ford but my audi problem
- Cosworth auto electrical specialist needed
- 1.8 td w reg focus slow acceleration??
- Battery light comes on
- mot fail! please help
- Back to 4WD
- 2011 New Focus 1600 Diesel Titanium
- Idle issues....again!
- handbrake probs after calliper change :-(
- turbos
- st170 set cams vvt delete
- Hesitation at low revs
- Clutch Ratchet
- Power steering res tank, which hoses are OK
- mk7 fiesta alarm problem
- A/C high pressure switch removal
- i need help with escort gti running fualt
- Crank trigger wheel for dta
- Focus gearbox selector shaft seal
- cosworth fuel pump
- Please help, car idles very high
- cosworth
- os side light not working mk2 mondeo??
- focus rs mk1
- atlas 4.6 cwp
- DCOES 40S tuning?????
- wont start from hot
- ST170 Front Suspension issues...
- Intermittent fans with A/C on
- Rs turbo cam
- any tips on changing focus wheel bearings
- fiesta mk1 zvh on r1 carbs prob ??
- transit sport 130 to 140 6 speed conversion
- is it easy to fit a puma engine ina mk5 fiesta zs?
- complete wiring diagrams needed
- Focus air vent problem
- help! fiesta mk6 gear box leak!!
- ? galaxy 2.8 gearbox ?
- compression
- diff & hubs
- Will it fit?
- super sensitive brake light switch
- Spec r breather
- sapphire cosworth front bumper
- faulty ABS sensor light on ford focus
- cosworth 200blocks
- powersteering cap vent fezza st
- 1.8 zetec fuel pump wiring?
- Yb cosworth misfire at 14+psi
- focus noisey rear wheel bearing
- clutch judder
- Different ride hights
- wobble on steering wheel
- MK4 Central locking (NOW WITH PIC)
- maniifolddddd
- Oil Change Time
- Cold idle issue
- ford focus 04 plate fan runs constantly
- Engine Conversion - Puma 1.7 into Fiesta Mk5 1.25
- Fitting coilovers
- Sierra Cosworth 2wd Ignition Module Number on Front
- Dcoes 40s throttle cable??????
- Zetec Cam Followers
- ford ka stalling
- are replacing the injectors on an 05 mondeo expensive?
- Focus CVT box HELP!!!!!
- starting problem HELP!!!!!!!!!!!!
- help with radio 3000 traffic
- ford 6000 cd player code
- won't run!
- Best Plugs?
- PARROT CK3100 Hands Free - Anyone fitted? Help!
