View Full Version : Technical help Q & A
- Tuning in Yorkshire
- swapped Zetec to D2.3, now electrical problem
- GEM replacement
- misfire/compression??
- Focus st 2006 bonnet won't open??
- Can they be got
- Focus Mk1 TDDI - Hose from EGR to ?... splitted.
- 1.8 zvh torque settings
- mystery smoke
- 1.8 zetec conversion running problems
- DTC code p0133 & P2303 on Focus mk2 2005
- w reg focus 1.8 HIGH REVS 3500
- stuck! black top or silver top?
- efi con help
- Tacho output wire from Ecu, how many pulses per rev anyone know...
- rs turbo running rough
- Ford Escort 1.8i Ghia X Mk6 Saloon Rear Bearing Nut Torque
- Focus 2.0 zetec 16v (04 plate) - adding a turbo kit?
- mk2 escort automatic 1978
- Racetech AFR Meter
- help needed small turbo escort cosworth idle problems????
- tappets are pure noisy on my escort rs turbo how do i solve this
- need some help!!
- Spot Light wiring Help
- Sierra numb and vague steering
- Crankshaft pulley bolt torque
- Escort rs wont idol
- Mk4 Escort Electric Window Problems
- Tubular Manifold for Mk1 RS Focus
- Pinto engine 2000E gearbox into MK1 Escort - bellhousing and clutch?
- Cosworth Master Cylinder Problems
- wiring escort mk3 radio
- Getting HOT!
- how tight do the rs turbo escort tappet arms need to be need help
- any one know the firing order for a escort rs turbo
- 2.0 Zetec Conversion HELP
- c20xe pistons on zetec rod query?
- cant get my rs turbo started its turning over but not starting its sparking
- smoking zetec turbo
- need help to connect my rs turbo battery
- rear caliper hand brake lever
- fuel hose size for 2.0 zetec
- Fuel reg hose 2wd sapph.....
- 2wd drive shaft/CV issue - pics
- MK2 Escort
- Escos misfire on boost. Update 8/06/12, it's still there!
- connect van rear speaker wiring
- engine will not rev mk3 mondeo
- Cosworth breather help!
- oil return
- How much oil
- Need keycode
- hand brake stuck on
- Ford Focus 1.8l Diesel 2000 LX TDDI (90) 1753cc - Glow Plug Light
- my ford focus st170 not revving past 5000 rpm
- Hi Newbie here,need your help
- ka rst help.
- MK6 escort 1.8 zetec wont go over 45mph.
- Gearbox ratios rs v's xr ??
- MAF sensor on ZT?
- 2000 Focus 1.6 flatspot problem
- Will Mk1 FRS turbo bits fit Silvertop Zetec?
- Cam help!!
- Please delete
- idling on a 3dr cosworth
- Zetec missfire.
- sapp cos non starter
- 92 Sierra Dohc not starting need help please
- Zetec Engine Conversion Kit for a MK1 Escort
- Engine borer/rebuilder needed?
- no fuel or spark
- Fault codes
- Sierra 2.0i Dohc rattling lifters
- Zetec 1800 stalls
- Zetec timing pin location and crankshaft pulley bolt
- Intercooler part number
- Focus rs dials in an rs turbo
- 56 plate fiesta duratec
- OFAB Wiring Into Mk5 Escort Help
- Gear oils
- 2009 Kuga Diesel Particulate Filter ( all experts)
- 1.9 CVH tall block conversion, How to do?
- mechanic baffled
- distributor advance curves
- Air bag light
- mercedes diesel brake issues, any mechanics out there???
- saphire 4x4 cosworth erratic rev counter
- Electrical problems AHHHHH!!!
- Supercharging a Zetec
- Cosworth breather splash plate
- HT leads to distributor cap
- RS Turbo won't fire
- Bob cosworth conversion
- Zetec Turbo - how much oil?
- Advice/Help on water pump fitting Sierra, please
- Frs mk1 wiring diagram
- Escort RS Turbo series 2 over boosting please read!
- Help with Fiesta MK5 Zetec S
- Anyone made a sequential shift light before?
- MAP sensor (9F479-AA) 4-pin connection question
- Alcon clutch
- Small turbo escos wiring diagram needed!
- more cosworth probs ? odd one please look
- Ford radio code HELP?
- Cossie YB - Rolling Road with Graphs
- TDCI Mondeo 2.0L rough idle and noisey
- My Focus hates hills - help......
- ST170 keeps unlocking itself
- Escort 1.8 -94 MK5 PATS immobilizer Question
- ford cant fix
- need help on where to find best match for flint grey paint
- Ford Focus 2.0 Fuel Sender problem?
- Coolant temp
- DIY two stage boost on RS Turbo
- Pectel Control Systems
- Need help with Galaxy PLEASE
- Assistance with rebuild
- duel mass flywheel vrs solid conversion!
- Problem with distributor / ignition - SOLVED
- 1998 mondeo
- Food 1990 P100 diesel pump leak?
- sierra front brake upgrade
- In car fuel tank
- sapp cos wont start
- cosworth 2wd power steering heavy
- Zetec s ap coilover problem mk5 !
- VDO fuel level sender
- IB5 stronger than a RS1800 box?
- PLEASE HELP weird cut-out
- 3 door cosworth won't rev past 4 1/2 thousand rpm
- Mondeo 16" Alloys
- puma conversion problems
- 1991 escort eclipse + rs turbo motor? Thanks
- Pinto Identification
- Please HELP
- MK1 Escort 4x4 Conversion
- Mondeo TDCI injector variations
- can i do away with break bias (laden) vale??????????
- High front suspension
- another no spark cossie :P
- alternative zetec thermostat housing?
- Chip ?
- mondeo tdci fusebox
- st200 horn stopped working and airbag flashing light.
- Zetec Water Rail
- escort 55 diesel top end rattle
- ERST wont start, fuel to metering head, no further
- escort 1.8 turbo diesel
- Checking Lambda Sensor
- MK1 Focus 1.8 petrol, chugging during acceleration
- Avo Coilover problem rear. Sierra OHC
- Replacing rear quarter panels on mk3 Fiesta
- N/A cossie in a Mk2
- Omex help!!
- Ignition advance probs/ how to find out level car tuned too?
- focus rs mk 2 2nd service
- zetec water system help
- T28 Small Turbo Escort Cosworth Misfire Problem??
- HELP building zetec turbo!!!!
- Timing on 2.0 pinto.
- Will 355mm ap 6pot front brakes fit under 9"x17" et23 team dynamics pro race 1.2's
- Focus Estate Brake Light Fault
- New key/barrel required - 2001 Mondeo
- Focus rs spark plugs
- cosworth not starting when warm? help :(
- clutch problem
- Stereo Wiring Help
- Atlas Axle Rebuild - Help
- st estate 06 model 2.2 tdci diesel
- st170 wheel nuts
- sierra dohc not starting, no power to injectors! new loom fitted.. BIG UPDATE
- How much to replace Clutch?
- Ka turbo
- Focus 1.6 duratec engine replacement
- Ford Escort Mk4 Brakes upgrade
- Frst oil pump
- Pinto re build crankshaft problems
- Turbo injection controller
- st200 hesitation
- 6 deg beams
- help needed
- 4x4 saff engine removal
- Rs turbo crank
- pinto misfire
- some help from some pro's please
- Which throttle cable???
- Escort RS Turbo massive running problem please read!....totally stuck
- st170 wheel nuts
- 24v cosworth questions
- What's going on with this zetec?
- Blower not working on 1 and 2 - Focus MK2
- Escos seats in sierra
- relocating battery to boot
- rear hub in front upright
- saph cossie brake problem, spongey pedal. help!!!
- Xr4i Race Set up (rear beam help)
- i4 in mk4
- Which Tyres For Track Use
- Battery light flashing when wipers are on, low voltage?
- Puma new clutch
- rs turbo wont rev
- hks evc 5
- 1.8 ZVH Turbo Cambelt
- MIG Welding Setup - Help
- Sierra Cosworth gearbox?
- cam belt troubles
- help t5 box
- help, really poor mpg on my 1.6 cvh
- S2 Rs turbo
- hego sensor and power steering switch???????
- engine malfunction
- Ford Focus 59 1.6 TDCi heater not working
- Mk2 escort bare shell weight ?
- 3DR COSWORTH MISFIRE pls pls help :(
- New sapph fuel lines?
- dump valve
- running cozy in??
- dump valve
- mk6 Fiesta 6000cd radio fault
- st170
- Fuel pressure (stress)
- Mondeo TDCI injection question!
- bora compression setting?
- do small ends need machining?
- WRC Rack - PAS Fitting help...
- electrical problem
- central locking/power window faults
- Couple Of Zetec Turbo Questions
- AP Racing 4 Pot Brake Pads
- greys and grp a coil
- Fusion cold start issues
- Mondeo 6000CD Stereo Displays Phone
- anyone no what fords got the 3.3 crown an pinion
- Injectors zetec-e blacktops
- Sierra Pinto early injection - what ECU?
- Replacing headlight bulb in a 08 plate Fiesta Zetec S
- zetec turbo bit of help needed
- Rose joints instead of drop links
- smart relay or not..
- Rear prop sits different with new 4x4 box?
- dellorto 48 set up
- Most Suitable Engil Oil Grade
- ARP Head Studs and Nuts, CVH Turbo
- escort endura de
- whats cost of ford
- Mondeo Mk3 2002 TDCI Intermittent Heaters
- boost capsule diaphram
