- T 34 Turbo Question
- mondeo door help
- Smoking on deceleration
- confused
- Boost problem
- 24v boa wiring into sierra
- Help on blue smoke from a Cosworth
- Help and advice needed please
- tyres on escort cossie wheels for a Series 1
- Boot lid release micro switch
- Act sensor question
- 3 Door starts then dies
- xr3i clocks
- Ka Engine Swop
- Problem swap engine fiesta ST
- Mk2 Fiesta - RS 4 spoke wheel question
- starting problems
- 2WD Cossie oil pump
- Brake bleeding
- Mondeo Gearboxes
- failed mot :( simple things need help
- TDCI Alternator Voltage when disconnected
- cosworth abs rev counter and battery light
- Cosworth headbolts
- No fuel to 2 injectors PLEASE HELP
- cosworth wire rung block
- 1.8 mk2 Mondeo Help
- Rs turbo wont start???
- L6 coil wiring
- car wont start when cooling fan is on
- Heater Resistor
- Mk1 focus 1.8 to 2.0 engine swap help
- What head gasket for Zetec turbo?
- 1990 ford sapphire 3.0 glx
- 2.8 Viscous Fan seized
- Mondeo Driveshaft seating
- mk2 fiesta zetec conversion blackpool
- Rs turbo misfire
- what piston goes with what head
- RST S2 water hoses route?
- SportKA Battery Light
- best mods for 2wd saff
- Horn Issue
- is my brether system correct?
- Watts Linkage
- st170 crank into silvertop?
- converting CVH turbo to zetec turbo
- Where is fuel inertia switch mk2 orion 1.6 ghia
- OFAB Wiring Loom Problem..
- XR2 VS XR3 Distributor (Carb)
- Cambelt change Price on a Transit Connect
- escort gti gearbox
- 1.6/1.8 cvh rocker arms
- diesel pump
- mk3 orion 2ltr blacktop
- Fault Codes on Fiesta 1.25 Zetec?
- help 24v boa
- cosworth cutting out!
- 1.8 zvh or 2.0
- Friends XReg 2001 Focus big problem
- Focus zetec turbo mapping in Yorkshire/Lancashire?
- 3dr brake servo
- 2.0 zetec carb conversion
- full beam question
- Rst alternator fan...
- Handbrake
- rs cosworth 16v head
- fuel pressure
- Power cable run from battery no place to run
- zetec 1.25 timing
- Ford Focus tdci !.8 (mk2) Starting trouble
- new headbolt washers?
- Focus Automatic Snow / Ice Mode - Anyone with an Automatic MK1 Focus?
- Fitting Lambda kit
- Securilock / PATS / Immobiliser Problem - Focus Wont Start
- Mondeo 1.8 mrk 2 2000 year
- sierra square rear beam pics
- Focus pulling back heavy engine breaking??
- Pectel T6
- heater control stuck
- Help, list of parts needed for conversion from carbs to turbo MK3 escort
- Focus Mk1 ABS & Traction
- ford fiesta mk3 1.1
- Turbo cooler
- Small turbo escort cosworth won't start...
- rs 2000
- not getting a spark
- Still no A/C AFTER NEW RESISTOR.
- Cosworth l1 ecu chip help
- S2 non runner
- Mk4 3i Track control arms
- www.pumaracing.co.uk unavailable?
- Efi relays help
- Mondeo A/C
- ST170 Power Loss
- ST170 Gearbox Leak
- zetec centre thrust shell cutout?
- starter wire question
- Stalls\hesitating engine
- 89 rs turbo over fueling
- knock
- 3 door cosworth 170mph clocks
- Over-revving problem KA
- How do you undo a MK3 FIESTA fuel filter?
- Creaking Noise
- Sierra EFI Pinto RPM signal wire???
- T5 Speedo Drive Gear, How do i remove it??
- Your help need again
- CVH/(retroford or similar) sump measurements
- cosworth cutting out when warm
- ecu help!!!!!
- pipe beading for intercoolers etc..
- sierra rs cosworth 3 door registration plate
- Cosworth: Blue smoke on startup...
- A little brake question
- Saph 4x4 running problems
- mk2 mondie st200 estate, traction control switch pinout needed
- Light and electric mirror problem
- mk4 escort bonus w/rs turbo engine exhaust help?
- Fiesta Mk5 1.3 - Won't crank over
- Exhaust help pls
- Fiesta Zetec S. Overheating?!?
- Goodridge brake hoses fitting problem (pic)
- 1600 diesel pump mods
- Fiesta 1.25 Engine Removal
- Mk1 ford escort electrical
- none starter yb
- Which Battery
- Ford Escort Van 1.8d
- Central Locking Mk3 Mondeo (2006 Diesel)
- 1.6 cvh on weber twin 40s has a rising idle
- 02 focus tdci 113hp..turbo spinning no boost.
- Metering unit issues no fuel to injectors
- c/o setting
- Weber Carb??
- Is this true
- Laguna dci 1.9 brake pedal issue
- focus wont start
- Mondeo tdci power loss 59 plate
- Mk2 fiesta with 1.6 zetec s engine?
- Rs turbo running problems
- zvh turbo cossie management help needed
- Rs / st differance
- Fiesta turbo no injector pulse
- Limited slip diff
- dohc not getting spark :(
- Check out my bushes...
- cigarette lighter fuse location mark 2 08 focus
- Escort rs turbo battery...
- Fiesta MK5 timing belt tensioner
- Mk3 2.0 tddi Mondeo issues
- Inner Track Rods replacement
- exhaust putty or bandage?
- exhaust downpipe
- What is this Part?
- 3 plugs behind battery
- wiring diagram saph 4x4 needed
- Turbos
- Newbie with focus problems
- 3door sierra fuel sender help!?!!
- No power to my dash 4x4cosworth help
- How do you measure blowby??
- saph cos 4x4 problem
- Efi to bike carbs?
- 06 Fiesta
- Crank case breather filter
- Focus Turbo conversion
- Bigger alloys on my mk5 fiesta!! Need some questions answered please?
- ka rst engine mount
- Help. 2wd Saph not boosting
- garrett turbo identification?? help!!!
- T5 box speedo/Tacho
- 2wd rear diff lsd cosworth rally car
- sierra xr4 x 4 turbo fan wiring
- wanting to run l8 ecu in 2wd car????
- St200 police car
- CVH HEAD
- What looms will plug into a L6 2wd Saph ECU?
- Anyone ever seen this before ?
- MT75 or type 9
- can any one tell me how to tighting my rocker arms on my rs turbo properly
- Any Focus Mk1 Suspension Guru's please?
- sierra cossie cam caps
- westfield cossy issues arghh
- RST Turbo upgrade
- mk5 fiesta with big brakes
- Can anyone tell me if these are correct :(
- I need your help, MTX75 on Focus ST170
- B&m quick shift 2.0 dohc sierra (mt75)
- Mtx into fiesta rst
- Mk4 1.8 tdci juddering
- Help Ford Focus 1.8 Tdi (2000) Reverse Lights Not Working
- mtx75 gearbox cv joint
- mirrors stopped working.
- need helo rs turbo running rough and noisey tappets
- Can you tell me what turbo i have ??? pretty please
- Top Hat stem seals damaged after 200 miles?
- would a flywheel skiming cause clutch slip?
- mk5 fiesta help
- Mk 4 escort 1.3 1987 no power to selonoid
- Central locking problem - Focus Style 1.6 facelift 2008
- 2.0 transit pinto
- st170 juddering at 4000 - 5000 rpm
- New Resistor but no ice cold air
- xr4x4 2.9 change to rear wheel drive.
- 2wd saff wont idle cold?
- new engine or head gasket
- Coil-over Spring lb and length
- Can anyone help? Focus ST
- Re Resistor for Focus 2002
- MK4 RS MFI Turbo Wont Fire
- st170
- Speedo
- air con problem
- why is clutch slipping on cosworth??
- scary driving,
- ST170 supercharged problem
- Zetec Turbo Breather Relocation
- Twin plate clutch not releasing
- MK1 Escort Link Boxes
- whats the best zetec turbo con rods to use value for muney?
- Focus 1.6 engine conversion questions PLEASE HELP!!
- MK4 Escort 1.3 HCS OHV to 1.6 Zetec?
- Clearing EML light on Ford Focus mk2
- ST170 code P1381
- zetec conversion
- Mk4 escort
- st170
- Focus RS Rod and Piston directions
- Problems fitting front spot lights
- series one missfire only after 4k revs
- 1.6 TDCI hesitation at 1800RPM
- Disaster changing stem seals on CVH
- Has anyone fitted a TDCi engine into a TDDI Focus?
- street ka, faulty lambda how do i tell which 1 is faulty
- Electrical GREMLINS!!
- how to get these arches
- mk6 fiesta van 1.4 tdci
- rear hub torque setting
- Mk2 Mondeo - battery & gauge problems
- cosworth misfire on boost problem
- Replacing a clutch on a 2ltr pinto sierra help
- level 8 into 3dr
- Anyone no were can get mk3 s1 front mount intercooler
- mk4 fiesta locking problem!
- Engine conversion
- Dissy cap and rotor replacement
- RSturbo running problems
- ford focus 03 wont start and fault finder says tps
- Tuning in Yorkshire
