- mk3 mondeo airbag light
- cosworth engine noise (cold)
- gtx30 turbo
- where to buy pulley bracket?
- Differences with zetec inlet?
- Escort Cosworth TCA Ball Joint - Getting it in
- IB5 Gearbox - Clutch Release Shaft/Fork - "Issues" ?!
- efi on bike carbs
- removing my mk4 crank pulley
- Mk4 fiesta fuel pump relay location
- turbo troubles
- 2wd Saph Exhaust /Turbo Elbow Removal
- St170 gearbox on zetec turbo
- Focus LX 2005 electric windows not working
- ford puma /fiesta coilover help
- mk 6 escort cataylic converter
- TPS wiring....??????
- WRC Breather fromAH
- ST220 still mis-firing after ECU repair
- Focus rear bushes
- 3 door cosworth abs pump
- Focus rs brembo's onto fiesta rs turbo?
- Cosworth tps setting
- More power needed.... Which way to go
- fiesta mk6 upgrade and reconditioning?
- XR3i EFI injectors not opening
- fiesta rs turbo running revving problems
- cosworth head bolts early or late
- 2.0 zetec or cvh on bike carbs !!!
- AB07 vs BD14 inlet cams
- Need help FAST
- Fiesta 1.4tdci sudden loss of power
- Xr3i efi engine pics....please
- Focus struggling with power, the dreaded 1/6 tdci, by the looks of it!
- Help focus engine knocking when warm
- 1990 XR3i - lazy start & lumpy at low revs
- xr3i efi misfire
- RS 2000 Mk5 engine mounting
- Rs 2000 Emmission Problems
- Alternator bracket
- Help with potential purchase please? Would this be a bad buy?
- T5 box wont select 4th gear
- Mondeo mk3 engine swap
- Tappets noisy (hydraulic)
- 1.8 zetec in to a mk4 escort
- fiesta rs turbo running problems
- Help please! Does anyone know what engine this is?
- 88 spec recaro how to swap recaro badge?
- Grp A Coil Wiring Help
- cosworth 4wd lambda sensor
- Cosworth valve stem seals fitting?
- mondeo black to by pass coded key any one no how yo do it
- zetec turbo conversion last niggles to sort need a nudge in the rite direction!
- Escort Van leaks in water
- mk 4 fiesta non start
- FOcus ST170 Cat dimensions needed
- Focus Mk1 TDdi issues
- Mappable ECU
- turbo crank or normal crank
- Cosworth yb ap clutch
- rs suspension
- Zetec turbo smoke on over run
- building a zvh, what turbo?
- Best Headgasket for a Series 2
- Series 2 head gasket help!!
- Wheel advice / opinions..
- 53 reg Mondeo 130 TDCI
- Best route to 350bhp yb
- Vw polo 1.6 8v fueling help needed
- Brake Bias Valve Help...
- Zetec air fuel gauge
- Focus 2.0 TDCI turbo help needed!
- engine revs when clutch depressed fiesta 04
- Cosworth only 1 injector firing help
- MK1 Y plate petrol Focus 1.8 Zetec issue
- fitting instructions for Matt lewis fuel pump loom
- Breather System cosworth YB
- Focus MK1 Climate control!
- T5 Gearbox selector parts
- L8 Ecu part ?
- C20xe pistons in zetec turbo
- zetec supercharger
- 3 dr cossie rear light drama
- 14mm Spacer
- Are these Valve Springs good for my ZT?
- Which fuel rail needed for rover inlet on a Zetec turbo
- RST Recaro base webbing snapped.
- gear ratios
- Focus RS ticking noise from front right!
- Fuel Volume Test
- Engine has locked
- How to check rs turbo fuel relay without a car
- Zetec fuel regulator
- Auxillaryshaftbearing problem
- Small front number plates
- Zetec se fuel rail help!
- Oil Cap Leaking on RS1600i rocker cover
- RS turbo coolant level weirdness.
- Amal Valve Wiring
- focua st fuel pressure test ?
- Cosworth Only 0.2 bar boost
- Girlfriends streetka heater?
- Roof Aerial
- Rover turbo fuel rail adapter
- Xr3 gearbox on escort 1.8d van
- intermitent total loss of power
- MK4 Escort fuel pump problem
- Reducing Torque Steer
- Rs2300/rs2000 in a sierra
- fitting boost gauge in the cos
- TDCi fuel pump or pulley failure?
- Courier Van Rear Beam Bushes Help.
- Courier Van Alt Belt Change?
- Zetec Turbo
- HELP Gearbox Auto
- Dash Bulbs?????
- radiator s2rsturbo
- dump valve
- Escort mk 4 Wing removal?
- Wiring problem
- cozy misfiring on boost
- cam change 115 to 130
- Escort cosworth sender return fuel pipe
- Ford Focus ST170 Front Heated windscreen not working
- Cat 1 Alarm removal
- engine bay wiring
- Zetec main bearing issues
- Ib5 gear boxes,fiesta ,focus
- Ford festia zetec s mk5
- Mondeo 05 TDCI 115 Stalling
- Air conditioning blew up
- front anti roll bar HH1 K32
- Courier Van Timing Belt Change?
- Ditching carb for efi
- Speedo drive
- Display module showing door open Xr4I
- Removing Valve Cover on Zetec SE
- Cosworth problems
- What all do I need to t3 my fiesta rs turbo ?
- Which is more than the turbo air flow meter.
- IB5 clutch
- Ford focus engine change dv6 tdci 1.6 diesel
- xr3i wiring fault?
- granada scorpio fuel sender wiring
- Ford KA 2003 Airbag Module Locatio????
- no spark
- will 2.5 mondeo engine fit a type 9 gear box
- Kent 244 camshaft
- HELP...L8 ecu
- Fiesta 1998 pats key problem
- Temp gauge wiring help
- sierra cosworth 1986 starts but wont rev
- Focus rs mk1 help with keys
- Anyone help? Mk5 fiesta Zetec-S problem
- Ford Escort 18 Turbo Diesel
- 3dr Cossie
- St170 imrc stuck open
- RS1800 idling problems
- 2.0 Petrol Mondeo Ghia X (2002) Chirp
- Fusion 1.4tdci Speedo problem
- T5 fifth gear ratio's
- Rs turbo been sat for 18 months won't start
- 3dr Cossie Not triggering Ign & Fuel pump relay
- 2001 focus 1.8 tddi lose of power
- 06 Mondeo TDCi Won't Start
- Cosworth ISCV spring?
- Mondeo - passenger footwell damp :(
- Zetec cvh internals
- dump valves on focus ST 225
- Cpl of ST170 problems.
- Stiff clutch when engines hot
- Zetec turbo
- cosworth dizzy drive
- 2001 1.8 TD Courier Van Clutch.
- Cosworth FBA (BOA) versus FBC (BOB) and 4x4 Conversion
- 2012 Ford Focus No Longer Starts!!!
- What zetec cams are these?
- ford sapphire 3.0 irs
- 1987 Mk4 Escort 4 spd to 5 spd conversion
- mondeo v6 st24 lump
- Rs turbo reshell question
- How to reset airbag light mk5 fiesta??
- 24v BOA wiring from Thermostat housing???
- ESC Module availability
- will a zetec flywheel fit?
- Looking for parts for a type 2 gearbox.
- Mk1 Zetec power issue
- Focus st misfire?
- Zetec turbo with rover inlet help
- Idle control valve
- mahle 1mm o/s cosworth piston bore size
- Fiesta mk6 throttle pedal mount bending ??
- Ford puma 1.7 idle valve location
- Escort RS Turbo fuelling issue...
- Where Can I Get Help !!
- Mk1 escort Cossie plumbing????
- Engine Swap
- Fiesta Duratec won't start when warm
- fiesta st150. how much power steering fluid should be in resevoir
- What's the correct way to adjust rear brake shoes and handbrake?
- escos electrical help needed
- FAO Stu @ MSD (WS)
- Escort mk4 zetec auto?
- cosworth running hot then boiling over
- fiesta rattle
- tdci P0340 P0335
- Sapphire Cosworth Alloy radiator Issue
- braks on xr2i with abs on front wheels
- Spec-R cam belt cover
- cosworth n a comp ratio
- S2 wiring plugs
- Clifford concept 50
- 2012 focus powershift
- Stressed Right Out With Focus
- Barn find XR3i turbo starting problems
- recoding lnjectors on 04 20tdci
- T34 leaking oil round bolts!?!?!??
- fiesta st150 sudden unusually heavy steering help!!!
- tot choose AFR gauge kit
- Help
- help needed tdci problem
- xr2/rst bottom end question
- 3 DR running probs
- Fiesta RST brakes on a S2?
- zvh
- 4wd t3 to 2wd t3
- T5 Gearbox mount ident.. can you!
- Transit van cut out problem!
- Power roof escort cab.
- Sierra Mk1 Indicators question
- BD14 cams
- Ford Transit (2002)
- Zetec killing coil packs??
- Cylinder misfire
- Caliper problem
- Blacktop alternator set up
- Ford Fiesta P2135 error code
- Will a stage 3 head work with a rebuilt standard botttom end rs turbo engine?
- Rs turbo rear brake power??
- Escort Cabriolet 1996 Help Question
- Instrument lights help
- Fiesta and puma wishbones
- Thermo housing sensors
- what wheel nuts???
- Lambda sensors ST170
- Panel Advice - Mk1 Escort
- Uprated front diffs on 4x4 cossies with standard crossmember?
- slave cylinder help please
- Fuel cut on my 4x4 Saph cosworth ? Help
- P8 ecu fault
