View Full Version : Technical help Q & A
- 2WD DRIVE COSSIE SPEC
- 18 Escort Cosworth Tyre Size????
- Electric mirror wiring?
- New fuel pump - will the car need setting up again??
- URGENT URGENT HELP!!
- rev counter with mind of its own
- Wiring diagram.
- metering units?????
- EFI conversion probs ( few Questions )
- T28 escy cos runin lean
- Roller bearing stage 3 turbo
- oil pipe
- Wheels
- RST ignition maps wanted
- cvh exaust
- 3 door cossie CV Joints??????
- P8 escort managment problems
- Best way to remove exh housing studs,can't move'm
- what can cause irratic idling on Sierra XR4x4??
- P8 FAULT CODES??
- XR3i Cab Thurst
- FRST RUNNING PROBLEMS, HELP!!!!!
- Door Problem
- information about the CVH23K camshaft
- abs light/brakes on rst
- F.A.O CYMRAEG
- erratic fuel gauge
- starter
- sagging exhaust
- hcs-cvh conversion
- Another Cosworth misfire problem!!
- FAO all S1 owners with 17" wheels
- HOT N BOTHERED :-(
- torque settings for rst in a rush please
- WHEEL OFFSETS
- richbrook gear shaft short to momo gear knob ?????
- low temp fan cut in switch
- Plug Gap For A 500 BHP Cosworth
- Whats the best way to polish cossie cam cover after painting
- Bailey breather what size drill bit for cam cover ?
- last one out please turn off the light
- i smell fuell
- traction control
- focus RS alternative management .???
- Smokin 2WD Cossy & cut out at 5000rpm
- Xr2I FRST heads ?
- correction
- snao off system
- Ford Orion 1.8 Zetec
- road speed signal
- Engine Spec...
- 3 door Radiator Temp switch
- Max boost on standard comp...?
- escort cossie wing question
- Sierra Cossie Injectors
- Cosworth management conversion
- strange boost cut out???
- Stalling sierra xr4x4
- Cosworth 17 inch tyre's
- S1 bad starting when hot
- Cosworth Exhaust valves - too good to be true
- cvh turbo manifold studs
- Engine spray ?!?!?!?
- Sump plug thread???
- mk4 escort floor
- Fitting rs500 size intercooler
- Relays
- RST Advice
- oil pressure4x4 saff
- Too high pressure in cooling system (Esc Cossie)
- Removing Turbo from 2wd,HELP.
- S1 TURBO CAB NO SPARK
- Will this fit??
- T3/4 with .48 housing
- overheating on the Mway
- Tremec TKO 2
- Best Cams
- Best turbo for Cossie
- Starter struggle...
- foa steve thomas
- px mint S2 , anyone
- escos chip
- uRGENT HELP NEEDED!!!
- flat spot???????????
- power surge
- manky morettes
- Help with electrics? P plate escort
- virous
- I have aircon, but I wanna run an RS500 intercooler
- Lurching s2
- Strange noise and not holding like it did can anyone help!!!
- zetec turbo Q's...
- Zetec idling problem
- The classic CVH start up puff saga. :mad:
- Best spark plugs for Escort cos?
- set up
- erst problem
- Which oils???
- What grease?
- mr worth
- s2 rs turbo wirring loom
- Any Ideas?????
- popping n banging erst2
- fuel and over reving
- Zetec inlet manifold matching
- Steering wheel lock
- Bouncing Rev Counter!!!
- Startning trubble.
- sidelights n headlights?
- uprated fiesta rs turbo gearbox
- cossie on coil packs
- Cosworth Clutch Plates
- Rear brake light
- 355s
- rst wont start no spark pls help !!!!!!!!
- Gauge lights gone out in ECOS
- Boostpressure RST
- what fuel pressure please , STU ??????
- What Mark V XR3i chip
- Compression struts - worth it?
- S2 rapid or not
- Dash lights on ECOS out!
- Gearbox for gti???
- Immobiliser problem
- Weird Misfire
- stage 1 cossie chip
- erst drives but keeps spluttering when driving along
- taking out a 4x4 sapph cossie engine
- Top class site
- engine builder
- Rouse Sport
- Suspension angles??
- Steering vibration problems
- erst s2 top rad hose part number
- Urgen help - RST Rebuild
- coilovers on mk4 rs cab
- set up??????
- Changing offset of wheels (machining)
- mixture adj ERST
- XR3i Probs - High Performance Oil Pump - crank case pressure
- clicking from my mondeo
- turbo damper, what does it do??!!!!!
- A.R.P STUD & NUT KIT HELP !!!!!!!!!!!!!!!
- cossie interior
- Csowroth exhaust manifold gasket
- cossie master cylinder and brake servo
- knocing engine
- Big brakes & ABS ??
- 3Door 4x4 Conversion
- cutting out
- Loooking for info. the other way: zetec-head on cvh-block
- turbo glowing red hot
- GRS cooler fitting!!!!!
- fiesta map sensor , which pipes
- Mark V XR3i Chip help
- what could be causing this?
- 18s on a s2
- 3 door misfire/shutdown at 4000 rpm!
- Jenson 6x9's
- Dodgy running s2
- intercooler or chargecooler....which is best???
- 2WD /4WD Cosworth heads
- T-38
- Fuel surge!!?? Help!!!!!! Stu, Mike, Sean, karl, Anyone??
- test
- Twin 40's confusion
- Which clutch plate?
- Fiesta Si owners please!!!
- external wastegate
- URGENT, PLEASE LOOK
- stage three plugs
- manuals.....
- Twin Dellorto 40 carbs. Help !!!
- Problematic s1 4 yr old problem
- DERV FOCUS TUNING
- 1.6 carb into mk5 escort 1.3 help
- Please Help - FRST Running Weird!
- Head Gasket Problems
- ford fiesta .......
- battery light s2 erst
- s2 erst thrust bearing
- Valve Guides for cossie
- NOS and turbo lag
- zvh oil pressure
- Adjusting boost pressure to what gauge?
- MK5 RS2000 plugg gap
- erst missing at 5000
- help!
- engine loom wiring problems
- piston - valve clearance
- NGK 9 gaps
- What is the offset for my Fiesta XR2i
- 130bhp ecu
- Upgraded mastercylinder for rear disc conversion HELP!!!
- what wheels on an s2?
- esc cos clocks???
- help nedded
- oil in inlet... turbo or other?
- Bet this gets you thinking!
- Crank Grinding & Balancing
- Oil breather Bailey mirror image
- More RST trouble
- Cosworth P8 ECU into a Duratec 2.3
- Dash for 3 door cosworth
- Another Hydraulic lifter Question, cosworth.
- cosworth tuning??????????
- URGENT HELP,PLEASE
- pectel monitor
- 1.9 CVH Help needed !!!!
- oil breather
- Cossie BHP
- whoosh, bang, diddly
- goodridge kits for sapph's
- escort rs 2000
- Twin pumps
- interia light/clock
- erst timing query
- saph wont start
- What boost shall I run?
- problem with 3 dr cossie
- s2 guage pod to replace trip computer
- Cosworth Oil Pumps and Spray Bars
- Fuel Computer
- fiesta gear box
- Set Pressure
- darn 3 dr won't start! relay fault?
- 4x4 Cosworth belt number/sizes?
- tyre wear?
- Wet Drivers Side Footwell, Any Ideas?
- xr3i problem
- Rear Camber
- RS500 restoration
- 1.6 CVH head onto 1.8
- What Gasket for a 1.8 ZVH ??????
- Information on thermostat and operating temperature
- Help with unreliable starter
- Head gasket
- Spark plugs
- clutch prob and hello
- Helix clutch
- Rubbing Saff
- stalling on idle
- rear tracking knackered?
- focus pre cat oxygen sensor
- 1800 zetec heads
- cossie tapping/knocking please help
- FAO all the GGR/philloy strut brace boys!!! Dave etc.
- Drilled/Grooved brake discs
- Help with identitfying intercoolers!
- Funny poppy noise idle valve
