- which bailey oil separator
- 3 door map sensor
- new
- will a 2001 focus 1.8 exhaust fit a 2.0l
- Fiesta coolant problem.
- Misfire under boost
- And finally
- Suggestions plz: another RS2000 misfiring
- Ford P100 Headlights
- mk2 RS2000 custom door cards fitting
- Fiesta interior lock issue.
- Won't stop reving
- transit connect issues.
- CVH Camshaft Id ( believe Newman )
- Focus exh manifold in Mk4 Escort?
- getting mk3 escort fuel gauge to read correct with a mk4 efi tank
- 2009 Zetec S 2.0 136 (160) TDCi turbo trouble???
- rs turbo s2 gearbox
- injector coding
- help needed mondeo injectors
- Cosworth boa v6
- Zetec turbo throttle cable???
- cosworth rev counter and top end rev issues
- Where to recondition diamond cut RS7's?
- 2WD L6 Cosworth electrical fault :(
- Efi head
- brand new mk3 focus zetec s 1.6 182 fan query
- 53 Mondeo 130 TDCi handbrake adjustment
- cosworth asb/brakes
- Ignition Live Help (Omex)!
- Focus mk1 wheel bearing, worth changing hub too?
- Mk6 Escort master cylinder upgrade
- T5 clutch release bearing
- trying to id some part nums
- brakes :(
- Cosworth Camshaft sprocket bolts
- 2.0 zetec decompression plate
- 1.8 Silvertop 2.0 cams
- 3000rpm tickover
- Help: Best way to fit new window & seals mk1 escort?
- Grey injectors
- Ford Focus RS Fuel Consumption
- no/low oil pressure on fresh build
- Escort brake upgrade
- focus 2007 problem
- Mk6 fiesta 1.25 to 1.6 conversion
- Electrics
- rediculas fuel consumption!
- Zetec rs1800 cult ecu into xr2
- Ford focus st 2006 clock display
- Escort mk4 bonus, help needed please
- 3000-4000 idle!!!!
- Fiesta Zetec 2006 1.6tdci oil filter
- citreon c2 1.1 want stay started
- Big pain!!! 260 RST!!
- Intake manifold to Turbo Charger breather hose?
- Electronic Boost controllers
- Crank seal
- 1.8 diesel escort 5 / fiesta 3 and van gearbox on zetec turbo fiesta?
- Bushings?
- Focus RS engine conversion Drive shafts!?
- L8
- Abs Ecu question escos 4x4
- Ford Focus RS Engine Management Light
- Zetec S TDCi 110Hp Injectors?
- Focus TDDi Fault Codes
- Ford Focus Mk1 Sidelight Fault
- ECU's and unlocking?
- Bosch VP44 repairers assistance/ opinion?
- Zetec Conversion over reving
- Transit 2009 passenger door latch
- Courier starting mystery...
- xr3i Lost 5th gear
- p0087 fault code ford focus 1.6tdci
- Advice - Reliable 350bhp 2.0ltr Ford Duratec/Zetec Setup?
- Fiesta rs coilover advice
- Blacktop turbo, Which gearbox setup do i need?
- rs turbo engine?
- Revving on its own...
- Ford Sierra front camber adapter. Where to find???
- Flashing Glow Plug Light :(
- 1.6 zetec se swap
- group a wiring where am I going wrong ???
- Mk5 rear bumper on mk6 escort
- Fiesta Mk5 Zetec S starting fault
- escort mk3 mk4 brake pipes ??
- Focus noise
- How to wire up a cooling fan
- Endura DI Water leak from somthing
- Cosworth Oil Temps
- Forged 2.1 zetec turbo (please help )
- 240NM 7" diff rebuild
- swopping 1.8 dash clocks for st? mondeo mk3
- Xr4i ride height
- Cosworth no spark problem??
- 3 door measurments
- No dashboard lights/clocks and non starting ST170
- Could I use Halfords 5W30 fully synth in....
- Escort MK6 Leaking...something?
- Mondeo/st170 disc upgrade
- Piggyback loom
- Running Lumpy - testing coil pack
- wheel spacing for calipers
- Mark 4 1.3 upgrade too 1.6 zetec lump
- Bonus Zetec conversion crank sensor question
- cosworth group a front struts on standard hubs?
- escort van cambelt
- battery light on fiesta
- Pinto efi fuel air mixture too low
- 1.8tdci starting problems
- Ecu help
- 12 way boost pot wiring
- Help fitting a catalytic converter to Escort MK6 Bristol
- f - super interface
- Escort RST S2 breather system help please
- Mk3 escort estate with 2.0 zetec and fiesta si loom helppp
- mk3 fiesta si fuel pump issue
- s2 cosoworth calipers
- dhla 40s on cvh
- engine speed signal focus rs 2003
- using a megasquirt for ignition on my cosworth...
- 1.6 X/Flow Cranks Slow then ok.
- Zetec conversion help please
- Cosworth cam cover refurb
- Ford KA 2001, limp clutch and brake pedals
- Mk6 Fiesta TDCi power steering and diesel leak
- Turbo
- Rebuilding a Borg Warner T5
- focus st2 loss of power
- FIESTA 2007 heater motor and switch problem
- Mondeo diesel mk3
- Help on pinto turbo please
- Flywheel sensor ??
- MK6 Fiesta braking issues
- Help Reqd - 2005 Focus - Banging noise under accelleration....
- cvh rs turbo oil return union
- Key Issues - Ford Fiesta 2001
- Fiesta Mk5 Zetec S power upgrades
- Zetec tuning
- Zetec Auto to Manual ECU.
- escort 1.8 td van
- mk6 escort, my reverse gear went missing
- help! focus bonnet release with intercooler
- Mk5 escort fusebox - ecu and abs power
- blacktop turbo,efi mani
- Central lock problem on Sapp Cosworth..?
- Escort Van Runs Lumpy & Loss Of Power...
- Puma injectors
- Rwd fiesta chassis inspection ??
- Help please sierra sapphire electrical fault
- MK1 focus non start
- bell and rotor question
- Going rate to change both cats on a Mondeo v6?
- Sierra sapphire turbo technics pinto help!
- Focus RS MK2 Issue
- st170 throttle sensor info
- MK1 Twin cam, Brake advice needed.
- Torsion Bar Assembly Help please.
- are all wipers the same? passoinmercedes peeps
- Alloy hubs- cortina uprights- which bearings?
- A little help needed, handling or power?
- engine conversion!!
- escort engine swap question
- Siemens injector in yb fitting problems
- IB5 Speedo Drive?
- Stereo Wiring for my 91 Scorpio
- Renault clio wheel bearing torque?
- Please Help - ESP light then engine malfunction
- Which pin# to add the extra wire into for coilpack conversion on cossie loom?
- 2wd cosworth prop shaft
- How simple to convert 2.0 DOHC to Turbocharged
- focus st 225 question
- Draining IB5 Gearbox Oil?
- ST170 no reverse and now a very slack gear lever
- Mk3 Fiesta 1.3L Questions?
- MTX75 gearbox is it a front wheel drive box
- cosworth cylinder head
- Escort mk4 wing replacement.
- Ford focus
- p1518 problem
- 2.0 zetec turbo conversion into a mk4 erst
- Rs2000 van conversion wont idle properly and cuts out under acceleration?
- Focus abs help
- 2002 Fiesta Endura-e J4J over revving and TPS dtc code
- focus st225 electrical probs
- ib5 bell housing swap
- series 1 bulb types
- Focus rs mk2 flutter
- furl tank prob
- Transit t350 75 ps
- Help with naming a pipe mk2 1.8tdci
- Focus st headlight help please :)
- cosworth ecu plugs same as anything else?
- Need help identifying 2 parts
- zetec turbo wiring
- mk5 fiesta idle issues
- 2nd throttle return spring- HELP!!!!!
- mfi xr3i to efi turbo querie
- Ford Ka Battery Drain
- Escort MK6 Stainless Steel Exhaust?-Advice Needed
- Ford S Max
- Focus turbo help
- Knife edging cosworth crank
- Blacktop turbo
- Turbo charging st170 motor
- Mk4 escort MTX info pls
- f super formidable software
- battery light glowing mk3 escort
- AP 6 paddle friction plate
- another transit connect abs light
- Fiesta ST gearbox
- Oil pressure and oil temp problems
- what 15's have largest id?
- Idle drop when warm
- DTA E48 cosworth map
- stage 3 = stage 1
- LED brake light
- V6 12v 2.9 sump gasket same as 2.8 sump gaskets?
- Fiesta st fuel pressure
- Escort mk6 1.8 alternator removal
- temperature gauge
- Help with T3 ID
- Zetec engine code
- 1.6 head on 2.0 efi pinto
- l8 ecu no power
- tddi problem
- L8 Pectel Super 8 Engine Management Loom
- Zetec turbo timing belt
- Help Electrical Problem :(
- indicator relay info needed
- What oil to use when running in my yb
- Space heater help
- 1.4 cvh not starting, nothing there at all.
- cosworth original 4wd lambda sensor wires?
- Revs drop off advice please
- Denso question
- Sapph cozy rear window rubbers
- Subframe bent upwards?
- Cosworth ABS
- welding my mk3 fiesta
- s2 rs turbo
- Mk4 Escort 1.1 Xflow to 1.8 Zetec help please
- T3<>T34 turbo
- Ford Focus RS Sony Head Unit
- Focus MkII TDCi EGR fault
- where to get resonable new parts from
- looking for a mobile welder birningham?
- Mk4 Ecsort cab battery light
- Ford focus fan stays on
- cosworth setting up surrey
