- Sapphire to saf cosworth conversion
- Vacuum Hoses T3 Conversion
- rebuilt cossie engine naturally aspirated
- air - air
- oil probs 2wd saph
- changing L1 Ecu to L6 Ecu
- how quick should my tuned rs16i be
- Blitz Turbo Timer - anyone got a wiring diagam?
- 2wd gearbox a quick question
- Too much boost.please help
- DAVE ALLWOOD FROM REDCAR
- Map sensor, where does the earth come from???
- Setting up the TPS??? Can anybody confirm figures???
- Engine managment light
- T4 question
- fitting rs headlights and sidelights
- XR2i engine tuning
- Wilwood Superlite 4 pot brakes - esc cos
- AP Organic Clutch WONT WORK ??????????????????
- morette headlamp diagram please
- Escort S2 Pressurised...
- Door source?
- is it all in the mapping???
- Warping discs
- Fiesta mk3 window switch wiring
- FAO Any Tuners...
- FRST GETTIN HOT !
- Amal Valve
- Stud and nut kit / WRC gasket question
- oil pump high or standard presure
- oil coolers and roof linings
- Wheel nuts snapped! :eek:
- turbo probs.......
- Where do you take exhaust man to get sand blasted/cleaned?
- *future plans* need help with them!
- Escort rs turbo dump valve
- Sapphire ABS problem during track day.
- Cossie problem
- ESCORT GTI - WHICH AIR FILTER
- S2 Starting Problem
- 3dr rev counter problem
- 5 door conversion
- cosworth 4x4 brake upgrage
- 2wd cos not starting
- Missing partnumber (?) - please help (gearbox)
- Electrical Geniussssseeeeesssss required!!!
- RS500 turbo damper pics WANTED
- Bailey twin piston dump valves-repairable?
- How do i replace/bleed brake fluid?
- fitting a 4x4 intercooler to a 2wd saf.
- engine coolant sensor
- HELP!!!! Spark/Fuel will not start...Cossie 4X4
- does your cos use a lot of oil??
- INSURANCE
- probs with my s2 rs turbo
- FRST Bailey Oil Separater
- sapphire not starting?
- prob with my 4x4 sapphire cossie
- Can somebody please tell me where the earths are???
- Cossy owners anyone heard of this?
- Cosworth 2wd and 4wd head gasket sets
- engine knocking
- Bleeding coolant system...???
- Boost Switch
- compresion ratio
- Fuel pump relays...
- Group A Bilstein Coil overs
- Simple Radiator question.
- s2 fusebox shorted.
- ice warning sensor
- Advise needed on compression ratio for YB cos turbo rebuild
- handling...
- Electric boost controllers
- Seek manual assembly blitz
- Deposits on pistons
- brake squeal
- Cam cap bolt/nut question
- how do i turn up the boost on my s2 turbo?
- mk5 rs2000 alloy offset
- What Brakes Under MK5 RS2000 Wheels
- Ford Scorpio Cosworth 24 Valve 2.9 BOB engine information
- temperature HOT
- Help! MOT tomorrow.. Emissions!
- cossy miss fire?
- 1.8 2.0 zetec differences
- melting clear clusters
- Front Bushes, mk6 Escort
- Esc Cos problems
- Front diff settings - Sierra Cosworth / 4x4
- Fuel pumps
- Installing guages in a saff???
- Zetec ticking noise!!
- missfire on cossie
- Uprated RST 2 brakes
- R & D Gearbox MT75
- Wideband Sensor and Monitor...Anyone seen this one???
- what turbo
- RS500 AND 4x4 THERMOSTAT HOUSING PICTURES NEEDED
- crank sensor wiring???
- Cossie starter motors??
- fiesta 1.25 zetec
- Cossie 4x4 head rebuild-pls help get my car back on the road
- thermostat
- Air Con 1992 Sapp Cossie
- Zetec And Cosworth Inlets
- Escort cos wirng diagram
- S.E.C.S. monitors
- Lambda Sendor
- stainless steel exhaust repairs
- Intercooler upgrade
- T 3 Turbo...question
- Exhaust question
- which oil filter to use?
- This can't be anything but bad
- Lower lag than a T34 .48...?
- ESCORT RS TURBO POWER
- Wee rubber seal thingies
- These Decompression plates
- testing radiator fans
- Spec R Exhaust Heat Shield
- camber on a 4x4 cossie ...
- RS 7 spokes on S2 need help!!!!
- focus surging
- Help needed !!! Escort S2 RST braking problem...
- No lights on Xr3i PLZ PLZ HELP ASAP :)
- What size??
- ZETEC TURBO ON FIESTA MANAGMENT
- Fans
- ZVH
- quad 2wd intercoolers?
- ERST cutting out randomly?????????????
- Cossie Handling
- Rs Turbo inlet manifold
- Timing up my Pinto
- cossie cam timing
- how do u
- fuel pressure at idle for stage 3 2wd
- what does a standard chip look like
- Auto Electricians
- Running in new engine with 803's or use yellows ?
- Turbo Connections
- s2 rear disc conversion
- ISCV
- FSE power boost valves
- excessive front tyre wear- cause?
- I NEED................
- How should I remove the Escos Dashboard ???
- abs s2 rst
- Braided Hoses
- Experts who know about Amal Valve and Cosworth System???
- Pectel monitor WIRING AND IS IT WORTH HAVING ONE
- cossie fuel pump relay
- Std Sierra Cosworth 2WD/4WD Turbo specs
- rpm wire? where is it on the cossie small turbo
- mrk3 fiesta 2.0l zetec can any one help
- distributor caps/leads
- Focus Rs Manifold
- How do I remove the Spanner symbol from my dash
- cold running??
- Rad problems
- Zetec Turbo Oil Breathing
- rst holding back & surging
- not firing on number 3
- Intercooler inlet pipe length
- Data logging
- esc cos turbo
- What spark plugs should i fit?
- Replacement fuel dial is reading wrong
- Gearbox/Engine Matching
- Key code Radio question
- Sapph 4x4 Misfire...Any Suggestions???
- erratic fuel gauge
- FITTING A BOOST GAUGE AND DUMP VALVE TO AN ESCORT RS
- kangarooing rs turbo
- 2wd rear diff what others can be fitted
- Rs gearboxes?
- Cossie Misfire
- amal valve question (mines unplugged)
- spark plugs
- Rear braided brake lines have they been fitted wrong? *pic*
- air fuel ratio's needed
- XR3i ABS Removal
- found this link
- Fiesta XR2i 1.8 16v MissFiring???
- 200 block
- zetec engine
- gear box oil
- 2wd sapphire cold running problems
- MK5 Escort Pulse Unit
- ESC COS ELECTRICAL MISS
- ESCORT COSWORTH DUMP VALVE
- whats needed to fit vauxhall turbo pistons to make 2.1 zetec
- ERST.. will not start.
- s2 rst!What 2 look out 4???
- Cossie Powersteering?
- Cossie cold running problems
- Hello All! Problem with RS Focus.
- head gasket question
- 4wd turbo
- Price for a clutch
- Paint code
- Rs turbo clutch question.
- Series 2 Idle
- Fitting comectic 4 layer metal headgasket ,wet or dry ?
- Escort hot idling/running....?.
- Excess Pressure in water system!!!!!!
- difference between L8 & P8 ecu's
- switchable boost/chip
- Focus Cosworth engine conversion?
- T3 or not T3
- oil in funny places
- will these alloys fit?
- esc cos idle
- Greersport??
- help-not starting
- Actuator idiot questions.
- escort noises and vibes....Help Please!!
- Miss fireing Cossie
- *engine mods*
- Zetec/FRST/Cosworth Capatibility
- Escort RST seat
- cossie hydraulic tappets
- Swapping over exhuast housings?
- When should a turbo have to be balanced?
- rs turbo ,doing head in
- head any good?
- What is minimum thickness allowed on 2wd cos head ?
- What symptoms would a faulty map sensor give?
- changing hub
- wheels
- Cossie 170 mph speedo into rst ?
- T3 Tubby
- DUMP VALVE PROBLEMS ON ESC COS
- fuel consumption 2wd saph cos
- Fast And Furious Oil Pressure Gauge - Wiring Help Please
- escos not turning over/starting
- Losing Oil Quickly!
- Exhaust housing on t3...experts views req'd
- Cometic headgasket - pressure in water system ?
- top speed nucance ! 2L zetec
- vibration between 50>70
- very loud whistling
- Rear diff removal hints?
- ZVH Turbo pistons
- misfire on a 4x4.. (update)
- Stumped.......
- Still Smoking :(
- escort cosworth dash lights
- cossie timing
- Where is the...
