View Full Version : Technical help Q & A
- cossie wont start weak spark i think help needed
- LSD question
- MT75 4X4 GEARBOX
- Lowering rear or a saph........
- Fuel
- please,please help!!
- CVH problems
- Wheel valves movement- Too close to Caliper bolts?PICS
- Escort Cos gauges
- ka rev counter
- st170 brake probs on rs turbo
- rs2k engine transplant
- One silly questiondown... One to go!
- l6 ecu testing
- cosworth transplant into S2
- frst won't start help!!!!!!!
- Strut brace
- lame - suspension problem
- t25 turbo
- Escort GTI - Engine people needed!!!
- Replacing my iB5 with an ERST BC gearbox?
- XR2 Turbo Conversion Problems
- Pinto injector sizes
- Rolling road problems
- XR4x4 front and rear brake caliper piston sizes / discs
- Boost problem...............
- Front Wheel bearing ERST S2
- Cosworth Cam Timing
- NON START 2WD AND FUEL COMING OUT OF TURBO JOINTS
- power question
- cracked header tank S2
- fitting a zetec flywheel ?help needed
- Keep it or Sell it... DUMP VALVE
- Leaking petrol tank
- Cossie Chip origin ?
- smoke problems and lack of revs on 1.8 zvh
- running in oil
- BHP ???
- What is a T04e Turbo charger???????????? Good?????
- Oil from D.V.
- batterry in the boot
- conversion
- MORE POWER FROM MY RST ??
- Strange humming noise!!!
- water pump for 2.o ltr turbo
- turbo timer
- kangerooing cossy managed frst
- Escort Cossie Missfire at 4000 rpm? (Solved)
- what smoke is this helpppppppppppppppppp
- cossie rear wheel bearings
- Cosworth 2wd head hardness
- Cossie Steering
- URGENT help!! Aaaarrrh!!
- 215 tyre on 8" wide alloy ???
- escort s1 missfire
- YB crank journals
- will seira cozzy discs fit on s2
- P8 anomolie
- HELP!!! CVH Starting Problems!!!
- dump valve
- Squeeky Strut on XR3i
- Changing a Rocker Cover
- .63 Exhaust Housing
- GRP A head gasket
- What offset???
- Problem with daughters Punto
- 2wd cossie brakes xr2
- Elecy windows and my brake servo unit
- Misfire and electrical readings
- throttle body question
- headgasket
- MK4 Escort XR3i Faulty Rev Counter
- bhp/torque
- zetec turbo how much boost?
- Fuses problem on my S2
- Fuel lines for Esc Cossi 1992
- Cossie ECT sensor housing gasket
- Cossie: ARP stud & nut kit and Grp A headgasket
- T4 Specs
- How do i get rwd in a fiesta mk2
- 3 BAR MAP SENSOR
- disconnected amal valve and just put all pipes together wat
- Dump valve position
- Auto-diag different with new EPROM
- help troublesome turbos!
- What fuel pump is needed for 1.8 ZVH?
- help with my engine coversion
- 4x4 Saph missfire. PLEASE HELP!
- 4 pot callipers
- Is this a rare limited edition ???? help
- ka rev problem.
- Zetec head gasket size
- S2 Turbo-Intermittant non starter
- fiesta rst runnin like a bag of ****
- 2wd crossmember and cosie steering rack
- piston rings helpppp
- Brake conversion question for Rally Guys esc cos
- Which Stage 1?
- xr3i turbo conversion
- Car alarm probs.....
- ABS not working properly!!!!
- Replacement front bumper
- S2 clutch question
- please help
- will a v6 fit a mk4 escort?
- steam cleaning.........
- Distance between strut towers on a Cossie
- Rocker Cover Gasket...Sealant. Whats best???
- 1.4 CVH
- cossey 4 pot cailpers seal kit
- Changing from std coil to grp A on cossie
- Sourceing parts, rocker cover gasket and cam pulley oil seal
- scotish garages
- 4x4 idle problem
- frst engine judder problem
- acceleration probs
- Flow rate for 'Cossie blue injectors'
- 2 litre zetec running rough
- Help with an unknown spec saph cossie
- Lumpy tickover
- hot start prob s2 rst
- Cossy ECU identity
- Will a saph dash fit a 3 door
- Transverse Cossie g/box
- frst wont start this morning
- steering probs s2 turbo
- what pads for my 330mm AP front discs 2wd saph?
- hii
- Fitting S2 RS TURBO Bodykit
- Overfueling on 3 Door Cos ????
- cosworth brake pad recomandations
- Cossie Injectors
- I have a funny problem
- Oil Pressure Release Valve.
- No Phase Sensor...What would happen???
- wheel bearing seals
- Escort cosworth dash clocks
- Cosworth turbo oil return pipe
- rs turbo bonnet for sale brand new in packaging offers?
- Samco Air Filter hose
- 1.8l Zetec turbo
- GTI / RS2000 Airbox and Throttle Bodies
- cossie thermostat housing O ring
- T4 on a rst?
- s2 rst non-start
- Painting Brake Disks.
- Best prices on Cossie spares
- cossie camshaft oil seal replacement
- Knocking noise on XR3i (HELP!!!)
- esc cos mot
- engine number query
- paint code
- how hot do ERST's run??
- fiesta fuel
- mk4 3i missing when booted
- Coilovers on ERST
- Piston Sizes for an ERST
- 6 speed wiper conversion - esc van
- could it be a wheel bearing??????????2wd saph
- ISCV
- baarp barrp she goes
- cutting out,,rs turbo
- i can tell u how to fit a zetec engine in ur mk4 xr31 efi
- slight stutter
- s1 rs turbo front suspension help please
- engine missfire
- thick head
- fitting cobra alarm
- series 2 engine in a series 1
- ERST External Wastegate
- BRAKE LIGHT COMES ON WHEN BREAKING
- Urgent frst acceleration problems!
- oil breather/catch tank advice on my frst 16v zetec turbo
- Fluctuating boost ? what fuel presure for stg 3
- 2wd t5 gear box help
- 403's FITTING KIT.
- Need help getting in my van!!!
- steering prob on 4x4 saph cossie
- Fitting the Dizzy on a Sapph 4x4.....???
- Painting rocker cover. normal paint?
- TPS and ISCV - what's the score
- FRST OVERBOOSTING
- Hiy'all, newbie here...need a turbo :-(
- xr2i wheel bearing noise
- Any Real advantage in bigger injectors?
- Cossie turbo on an S2 - help!
- Wiring Diagram
- How do I modify a Ford idle bypass valve for antilag?
- RST Rebuild
- Sapph cos 4x4, three problems...
- Stage 2 sapphire co level?
- Sapph cos 4x4, Electric mirrors, blowing fuses
- speedo
- Reley
- Vernier timings..........
- Front diff esc cos knackered
- Help !!
- RST Oxygen Sensor
- Ford Fiesta '96 MK4 1.25 Zetec
- Garret T4
- ferodo ds2500 are crap
- Clutch rattle
- Gearbox experts help needed please
- rs turbo,,,no go,,,,
- Can the CR be reduced with a thicker headgasket??
- esc cos
- RS Turbo Engine Rebuild Advice Needed (UPDATE!!!).
- What turbo to go for???
- poly bush fitting
- A few things, Im new to this!!
- IS IT OVERFUELLING SAPH
- cossie big end caps
- Mintex 1155
- cossie smoking
- ECT (Blue) Sensor...Can Anyone who knows about these help???
- Alarm Troubles not too bad though.
- camshaft bearing caps torque
- SMOKING COSSIE
- battery draining.....HELP
- Little Niggles are so annoying!!!!
- throttle position setup
- wiring diagram 4x4 cosworth
- Cossie not starting????
- Cossie Fuel Regulator Set UP
- 2WD SAFF FUEL PUMP RELAY
- boost dropping
- Tuning chips
- Zetec turbo conrods??
- slowly boosting cossie
- cossie rear discs
- Oil pressure guage
- Cossie Management
- rs turbo lsd power hanling??????
- How do you de-camber the back suspension on a Sierra?
- engine mapping
- Oil Breather cossie-is this the return plug on turbo side ?
- Turbo thread sizes
- wot fuel for erst
- bd10 cams
- Suspension to raise over speed bumps/driveways ?
- how easy
- Gearbox research for series 1.............
- Boost Cut
- Advice on next tuning steps on 4x4 Saff
- Brake Calliper identification help please!
- Ap 4 pot fitting
- Pinto turbo conversion.
- RS2000 air con
- Fuel pump fuse on a 3 door Cosworth
- Tech Question on boost controlers
