View Full Version : Technical help Q & A
- 1 prob then another
- 4x4 brakes on Fiesta Help Please
- 4x4 cossie electrical problem!! please help!!
- 4x4 cossie electrical problem!!please help!!
- clifford keeps going off
- head gasket blown
- Timming belt. . . Q
- oil return and breather holes for zetec turbo
- Nuts question
- Co2 adjustment screw...SORTED!
- Problems when in Neutral????
- 3 door ecu error
- s1
- anyway to test a 2wd ECU ?
- Help needed fitting a breather
- What could cause this
- oil for cossy
- freaking idle
- de cat help!!
- SPEEDO - CLOCKS - HELP !!!!!! (FRST)
- Another ABS fault, 4 x 4 this time.
- Max boost for a -31 actuator
- Cosworth rear bumper
- escort cosworth wheels
- Expert Cosworth help needed
- Mk4 Escort Door removal
- orion 2.1 zvh help
- ect sensor(blue)
- whats wrong???
- 2wd Cossie Headgasket
- Escort MRK 1 Cossie Powered
- STEERING WHEEL ON S2 PROBLEM
- Zetec Turbo
- 3dr boot lock
- mk7 scort 1.6 questions
- Help Needed ++DESPERATE++
- sapph cos 2wd, whats the problem?
- chip and injecters
- Converting a Mk2 XR2 to rear coilovers
- xr3i starting problems
- mk4 Escort 3i keep stalling help!!!
- Alternator question
- irratic idle
- 4x4 saph cossie revving
- twin outlet master cylinder
- Tuners.......... Please Help
- zetec flywheel
- Koni suspension help required
- Best way to get a Turbo off a Cossie ?
- GTI Electrics
- Hole in hose
- rolling road tunners
- 1600i/series1 brake pipes
- On-Line Vehicle Checks
- xr3i 90
- xr3i turbo 1989-90
- xr3i efi turbo
- zetec sump
- FRST Internal Heating Problem
- Warranty Magnex full stainless steel ??? (FRST)
- wires from under rear bench?
- 2wd brakes onto 4wd?
- escort rs series 2 problem
- air fuel
- Frst ECU????
- cossie fuel pump probs
- 4X4 COSSY BRAKES
- sierra gearbox to zetec engine
- Rev Counter Not Working Correctly??
- I need help!!
- Blown H.gasket again, whats the best fix now??
- Blue Smoke FRST
- bigger brakes on 4x4
- NGK SPARK PLUG's
- Throttle Cable
- Cosworth injectors flow rating
- bhp
- fiesta rs turbo crank posistion sensor
- leaking gearbox!
- MK5 RS2000 track day car mods
- prob with escort series 2
- rs1800 electric wing mirrors
- 1600i
- 2.1 zvh
- zetec 16v turbo help needed
- 2wd manifold on 4x4, which gasket?
- rev counter retro fitting
- Weber fitment
- s2 steering problem
- leaky sapph
- rst running probs!!!
- Some Fiesta XR2i Help Please
- Rear Sierra lights?
- Escort cosworth fuel pump/sender wireing
- cossy abs fault
- Changing gearbox oil on cossie 2wd, advise please.
- crank position sensor
- Standard 2wd saff Diff ratio
- water in sump, major??
- GGR 3port breather, who has one??
- 17's onto mk4 escy
- RS1600I Help
- 2WD Cosworth Calliper Rebuild Kits?
- steering twitch
- lsd
- 2 ltr pinto turbo
- whts this noise???
- Escort 1.8 engine blown, 2.0 questions
- 2wd saff smokeing bad ???
- Help Help bonnet cable snapped on rs turbo
- management
- FRST stalling whilst driving and idleing? TUNERS ANYONE???
- turbo help
- escos rims
- Zetec turbo head gasket
- smoking on acceeration
- Cosworth wont run
- Rev Counter Bouncing
- Fuel Pressure Mod for S2 Turbo
- cutting out
- has my crank been balanced ??
- VAN
- Sounds like road noise
- Crankshaft toothed belt pulley
- ABS prob on my cossie
- cosworth ecu connector pin outs?
- Escort TD camshaft snapped!
- waste gate set on rs turbo
- fiat coupe brembo brake calipers on frst questions?????????
- Gearbox
- S2 Rev Counter
- ecu chip writers
- mtx 75 gear box into s2
- IDLE SPEED ADJUSTMENT
- urgent cossy help
- Will it fit
- tick over rs2000,,????????
- Gearbox ratios?
- NGK plugs for stage 1 cossie
- vibration from my cossie
- oil breather fitting on small escort turbo (silver top)
- SAMCO HOSES HELP
- Which cam for a s1 turbo(not standard)
- rs turbo smokes a lot when cold what does it sound like pls
- CVH quiery
- Esc cos exhaust fitment?
- 4x4 cos no spark
- cosworth pectal wiring diagram needed asap
- rs1600i
- RS2000 using too much fuel
- ecu's
- [b]cranks[/b]
- tappin cossie/after oil change
- What is needed for 400BHP???
- air injector help needed please
- Cossie Turbo Problems
- ERST Alloys Buckled?????
- erratic idle when cold
- These modified plenums and airflow...??? (Technical)
- suspension { coilovers}
- 2.9 24v Cosworth into XR4i
- s2 rst heater controls relocation
- saph no longer starts please help?
- ecu testing
- Power steering fluid tank pressurised.................
- for car specialists
- RS1800 Head on a 2L Bottom End???
- would any one now what this could be
- sapphire rear springs
- XMAS pressie - cone filter - now what ? 4x4 cossie...
- abs light
- IN CAR BLEED VALVE
- Engine number for zetec
- gearboxes, bc swap to ib5 or mtx?
- rs turbo bleed valve
- rebuilding t2 help
- fiesta turbo to replace or not?
- turbo management
- Annoying 3dr reving problem
- Fitting OIL SEPARATOR on LHD Sierra Cosw. 4x4 with AC
- Bulb failure module - where is it?
- No boost & whine in transmission
- Cossie tick over fault
- lowering q..
- RS500 i/c into esccos
- cheap data loggers
- Metering head removal
- rs turbo wont start
- Oil pressure?
- DIY Engine Monitor
- INJECTOR SPECS - HELP!
- Turning turbo off ???
- What's this PIN used for?
- how much??
- where is the pressure cap on a sierra cosworth?
- Wires needed from ERST K-Jet to cossie
- Electromagnetic Pressure actuator. (Metering Head)
- series 1 ingnition problem?
- Turbo'ing a MK6 HELP>>>
- 4x4 saph
- electric power steering ?
- cossy help
- fuse box
- Carbon Bonnet
- Advise needed on swapping over injectors on cossie
- Lean fuelling
- rear noise from focus estate
- wiring help with dtm mirrors
- Scort GTi Idle
- Fitting a Breather Kit
- Car won't start - please help.....
- Overflow tank bubbling on sapph cossie
- On going running fault , help!
- 132 bhp xr3i and 132bhp rs turbo
- Suddering And Backfire
- sapphire cosy steering prob
- Tracking
- rs turbo spark plug gaps?
- Anyone cured this? Worn pedals on a saphire;
- Turbo help
- injector flow rates
- Mk6 Escort door speakers?
- Help me PLEASE B4 I torch it
- How can I tell if my Valve Seals are shot?
- Bilstein suspension kit - fitting instructions anyone?
- Is mk3 fiesta suspension different to mk 3.5?
- turbo into XR2?
- frst ofab wiring guides for s2 escort?
- cossie piston advice
- Milky Power Steering Fluid
- Cossie intercooler/radiator question??
- wireing for spot lamps
- does my car have an intercooler?? engine pic supplied
- why would my Escort RS run ruch on 1 cylinder
- Actuator vs Boost controller?
- Torque settings
- Zetec and Fiesta Turbo Throttle Position Sensors Help Please
- s2 rst rear hub nuts
- Water injection or front mount?
- THE ALL TIME QUESTION - DO DUMP VALVES WORK??
- Timing for Sierra 2.9 v6
- Identifying injectors
- Saff rear bumper fitting kit
- west wing??????????/
- noisey tensioner on esc cos
- parts cleaning
- wheels on a Mk6 escort van?
- EST Fuel Pressure's???
