PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 [102] 103 104 105 106 107 108 109 110 111 112 113 114
  1. clutch probs advice please
  2. Anybody know how the Sapph 4x4 Cooling system works...???
  3. Anybody know how the 4x4 Sapph Cooling system works???
  4. Mondeo ST engines
  5. Arrrghhh! cossie revs up at idle or miss fires loads!
  6. Can you fit a rwd diff to a 4x4????
  7. Amal valve
  8. Escort MK4 engine replacement
  9. wordcup crossmember
  10. ABS
  11. 4x4 conversion to 3dr cos
  12. Fitting RS500 clocks in my saff
  13. Is this normal
  14. RS turbo not starting
  15. Ford diesel engine mounts?
  16. !!HELP!! ORION RS TURBO NOT STARTING !!HELP!!
  17. fiesta mark 5 rs turbo 3 door fun model help!!
  18. s1 chip problems
  19. air conditioning
  20. MONDEO clocks in a mk4 escort ZETEC wiring help
  21. Light Steering
  22. Cossie Misfire
  23. mk1 xr2
  24. engine building?????????
  25. temp gauge 2 hot wen not
  26. wheel bearing/driveshaft problem
  27. focus 1400cc power boost
  28. Unmolested cossie - should i chip it?
  29. Uprated fuel pump
  30. Brake parts
  31. cossy cuts out ???
  32. temp guage probs??
  33. gauges
  34. engine stops (at the stoplights) after driving 1 hour.HELP!!
  35. 1300 hcs sniff
  36. 200 block advice
  37. Puma/Fiesta brake upgrade
  38. RS500 management swap
  39. A B S
  40. An interesting one for you knowledgable people
  41. twin fuel pumps
  42. Radio wire diagram?
  43. Big Brakes Help
  44. Will these alloys fit?
  45. S2 central locking
  46. Idle Control Valve at fault???
  47. replacing fuel hose return line
  48. Spark Plug Gaps
  49. Mk4 Escort XR3I EFI-Turbo CVH OR ZETEC?
  50. HELP! 87 s2 RST Engine cutting out prob....
  51. bellhousing
  52. engine mounts for 4x4 sapphire (1993)
  53. ecu swap
  54. wastegate vacuum connections
  55. s1 problems
  56. brake proportioning valves ( compensating valves )
  57. FRST efi engine managment loom onto MFI loom
  58. Strut braces!
  59. Who in England is good on live map?
  60. oil consumption for a stage 2 sapphire
  61. s2 fuel relays
  62. tyre advice
  63. 4x4 YB into Mk1 escort, Water hose query
  64. mk3 susspension
  65. Cosworth clutch kit question ??
  66. induction kit
  67. amal valve question
  68. which cam
  69. s2 turbo
  70. air fuel mixture
  71. S2 rear springs
  72. RS2000 HEADLIGHTS THE SAME AS ESCORT COSSY?
  73. 2wd saff drive engagement probs
  74. Is it a hybrid???????
  75. xr2 carb trouble
  76. MK5 RS HEADLIGHTS
  77. Thinking of going to a 2 Litre Mondeo Bottom End
  78. biggest discs under 18's ??
  79. saff cossie problems
  80. reverse switch on mk4 4 fiesta
  81. Zetec
  82. [b]cosworth misfire [/b]
  83. fuel gauge
  84. What oil is best????????????????
  85. stereo prob
  86. Finis code required
  87. zetec conversion, wireing question
  88. RS2K Engine Rebuild
  89. 4x4 conversion
  90. removing air bag to fit after market wheel
  91. ZETEC CONVERSION (LOOM)
  92. Cosworth beginning to get on my tits?????
  93. help needed with zetec
  94. Amal valve problems!!!!!!!!!!!!!!!!!!!!!!!! FFS!!!!!!!!!!!!!
  95. zvh conversion
  96. cossie brakes for rs turbo
  97. Valve seat cuts and lapping
  98. turbo help needed
  99. cossie piston slap????
  100. Funny noises between 3-4k in 4th and 5th!
  101. under body waxol/sealent
  102. TDC sensor question (saph 2wd)
  103. Heated windscreen
  104. gasket question
  105. Rolling roads in the Notts/Derbys area
  106. Zetec head bolts
  107. BD14 cams and standard pistons/compression?
  108. Bonnet Vent's *fitting*
  109. Fuel Gauge on my S2!
  110. cosworth in escort mk4
  111. cosworth group A fuel pump
  112. s2 metering unit
  113. how much is it worth?
  114. Ford Ka Steering Wheel Shudder?
  115. fiesta turbo ecu wireing?????? help needed asap
  116. Where to take a live from the sidelights?
  117. Electric Windows!
  118. Escort diesel turbo glowplug relay
  119. 17" wheels And Escort
  120. 4x4 Cam Followers - should they have springs in??
  121. Dax Rush Cosworth
  122. 1.8 zetec cams in a 1.6 zetec possible?
  123. cossie set up?
  124. cossie sensors
  125. STALLING PROBLEMS!!!
  126. rs turbo conversion
  127. 4x4 brakes saff escort
  128. Recaro Seats in a Mk 6 Escort
  129. Buying 4x4 Sapp
  130. Saff Cosworth 4x4 shocks problem please help
  131. What's the best turbo oil filter?
  132. 4x4 problems help please!!!!!!!!!
  133. clutch problems
  134. Tech Help needed....pleeeeze
  135. cvh big valve heads, will it fit straight on??
  136. Air/fuel ratio gauge on a S2 Mfi
  137. valve oil seals-help meeeeeeeee!
  138. 1800 Zetec (130hp) advance timing maps
  139. Altering the Camber
  140. diffs?
  141. fiesta stalls after fast de acceleration. mk4 1.3
  142. Cosworth stutter/missing
  143. help me !!!
  144. Orion Ghia Si 130 - info please!!!
  145. CAM BELT PULLY
  146. white gack in oil filler cap/breather
  147. Whats the best suspension for saph 4x4
  148. urgent - cossie problem :(
  149. Tin Worm
  150. mondeo turbo
  151. HELP NEEDED
  152. Error codes on EECIV Rs Cosworth
  153. S2 Cutting out after 15 seconds!!!!
  154. Cosworth Engine cut @ 4250 (sometimes)
  155. Cosworth idle
  156. Tappety sounding s2 turbo, normal??
  157. suspention problems mk4 escort cabriolet
  158. Turbo Gurus - can you tell us more please ?
  159. Need help fitting a turbo please!!
  160. How do I build a 2.2 Pinto
  161. big end shells
  162. noise from gearbox or clutch helpp
  163. replacing pistons
  164. d/v 2wd cossie
  165. callipers to fit mk 5 &6 escorts
  166. Power Engineering no longer supply my required Cam
  167. Error codes on Focus RS this COLD morning
  168. Do my ingition timing have to be changed now s2 is low comp?
  169. s1
  170. 1.8 Zetec
  171. rear anti roll bar erst?
  172. cvh rattle on start up
  173. Fuel line
  174. cossie lights
  175. Simon secs ecus
  176. RS2000 rev counter
  177. how does a speedo cable work.
  178. help
  179. gearbox bolts missing... leaking oil mk4 escort
  180. Tapping Cosworth Part III
  181. 2wd chip and ecu question
  182. Fitting Seat splitter to 1990 Escort Turbo
  183. Cossie/non-cossie suspension.
  184. No power??? please help!!
  185. nut Size of wheel hub
  186. silicon hoses
  187. jerky and juddering s1
  188. what wastegate is best?
  189. t3
  190. help me piz
  191. wheel nuts
  192. overfuelin
  193. erst pistons
  194. rs 2000 4x4 filling problem
  195. 2wd to 4x4 conversion advice
  196. just fitted a t3 hybrid ,HELP plz!
  197. converting an eecIV inlet to weber
  198. wot voltage should a cossie pump have
  199. ecu is dead.... again?????
  200. injectors not opening zetc/ofab management (((resolved)))
  201. Esc Cos running on 2 cylinders only
  202. saff cos
  203. alarm
  204. Cosworth and dry cell battery
  205. engine conversion
  206. cat on escort cossy
  207. rear camber
  208. bumperstops and spotlights
  209. 2wd rad fixing holes
  210. Fiesta Zetec-SE Injectors
  211. escort s2 brake callipers
  212. Mk 4 efi wiring diagram..
  213. Cossie head bolts and block cleaning
  214. No fuel to injectors
  215. COSSIE wont rev past 3.5K!!!!!
  216. S2 Very lumpy
  217. technical help needed urgent please look
  218. Group A front cross member!
  219. Escort mk 6 probs
  220. stalling @ 4 - 5000rpm
  221. Cossie cambelt tensioner nut?? (pic)
  222. 1994 Fiesta Floods and Wont Start
  223. help!
  224. focus speedo fault
  225. Debadge
  226. can anyone help
  227. A few questions on my erst
  228. turbo diesel probelm?? any1 can help me??or shed sum light??
  229. chip and cooler???
  230. Escort Small turbo ecu limitations
  231. PTS superchip ??? (pic)
  232. Cat / Sports cat / de-cat??
  233. elaectrics
  234. cossy wiring
  235. escorth Cosworth EECIV T25rebuild it to T35 weber-marelli
  236. 4x4 prob
  237. what oil id thinner when cold?
  238. ..::Read this before posting in this forum::..
  239. Fluctuating revs on cossie, any idea?
  240. Turbo gaskets
  241. metering head ???????
  242. cat on a cossy
  243. Superchips
  244. how much power can shot peened zetec rods take ?
  245. Ok cossie Qs again
  246. help bastid fuel tank!..............
  247. how do you bleed brakes on an Escort Rs Turbo?
  248. ERST minor problems
  249. zetec fiesta track car help
  250. turbo wont start/ overfuelling?
