- Ariel amplifier........fitting help
- zvh conversion
- crank pulley quick ????
- T3 - recon or rebuild
- brake calipers
- Engine Fan
- zetec turbo
- T34 fitment
- ZVH PISTONS
- Zetec Clutch help
- Saph dump valve...
- cossie clutch
- Cossie spark plugs (again..sorry)
- Series One whining noise
- Oil Pressure switch on 1996 escort 1.4i
- HELP COSSIE PROBS
- handbrake warning light problem...!
- focus wiring diagram
- Help needed
- brakes alter revs
- Help Oil In expansion tank!!!!!!
- cossie problems
- zetec turbo questions.
- 16'' Mondey si rims wont fit! :o( help me please!
- rev counter
- Circlips
- mondeo
- FAO all with rs7 spokes on s2
- xr4i
- [size=18][b]HELP[/b][/size]
- cars just died!!!!!!!!
- ecu temp sensor
- phase sensor
- Torque settings for cosworth
- cosworth chip?
- What oil?????????????
- urgent cossie help needed
- rattleing erst
- top or bottom
- Zetec RWD
- software
- S2 brake caliper blled nipple thread size?
- building an rs turbo
- frst engine into xr2i 16v shell
- 2wd cossie head oil blanking plugs - Sorted
- [b]some alien thing in my engine bay!!! help wat is it[/b]
- Can't open boot!!!
- bigger turbo help needed
- Zetec Turbo Conversion Help
- N/A to Turbo Conversion, Equation for Head Gasket Thickness
- dash flocking
- escort cosworth spotlight pod.
- erst frst
- 2wd cossie thermostat housing question
- fiesta 1.25 zetec!!!!
- Ford Ka Help
- Wiring Loom Q
- rs turbo zvh conversion
- cossie to escort wheels...what a headache!!
- S2 ERST 2.1 ZVH FLYWHEEL HELP.... !!
- DECOMPRESSION PLATE FOR COSSIE HEAD
- Bad rear vibration from Escort Cosworth
- s1 gearbox
- titanium crank
- Fitting Sierra Cosworth suspension into Merkur
- 6sp gearbox into s1 rst?
- cossie running bad
- Intercooler in front of Rad...Performance??? Experts Please.
- XR3I TO RS TURBO CONVERSION QUESTION
- bosch part no for std fiesta rst injectors?
- frst light green injectors
- Mk3 escort brake linkage bushes, anyone know........
- boost adjustment
- racetech boost gauge problem
- fitting cossie brakes to a xr2i
- MK6 Escort water pump question
- Bang Bang Said My Cossie
- RS Turbo running problems
- car wont turn over after winter hibernation
- cam cap studs
- Changing turbo?
- passenger airbag
- valve stem seals
- Possible ABS problem with the 3dr
- suspension
- engine sizes?
- aluminium welding
- RWD conversion to mk4 escort
- QUADS WITH BAD BOY BONNET
- zetec-turbo with L6 & dizzy?
- s2 problems
- Cossie rev counter..
- Horn problem on mk6 escort
- Hot Running 4x4
- fuse box diagram
- oil pressure?
- engine transplant
- Focus RS Engine Management Light
- What have i done?
- please help me!
- Loosing power :(
- ZVH cold starting problems
- Replacing Fuel Filter
- FITTING A RS500 INTERCOOLER
- headlight fitting
- mf2 mappable injector driver? s2 rst wiring?
- !!!!HELP!!!!! escort rs turbo no spark? !!!!HELP!!!!!
- second opinion needed!!
- black smoke question
- cosworth managment
- hub bolt
- turbo size
- FAO tuners/experts - beer or two for help
- have a prob with computer comunicating with ecu
- cometic gaskets
- dam ford electrics
- Transplant
- head bolts
- Transplant Op!!! S2RST into my MK5 plz!!!!
- SLIGHT PROB WITH 2WD SAPH COSSIE
- Air to air
- ELEC WINDOWS
- 24v cossie into sierra
- Whispering sound while on boost and the smell of petrol?
- Am i being paranoid???????????
- Sapphire ariel amplifier..... fitting guide please
- ported head 4x4
- TOYO R888 User
- Parts required for N reg 4x4 RS2000
- tyre size help
- Quick COSSIE question...
- 4x4 Sapphire Cosworth... God knows!!
- MK6 Door Speakers
- Hesitating cosworth off-boost..........
- 2 Litre Zetec Silver Top
- rs turbo tappets
- Where did my post go?!
- FRST problem
- MK2 XR2 Headlights
- wht power/boost can i run with stdcos4wd injectors on efi1.6
- cossie probs AGAIN!
- Escort TDi tuning
- what pistons are best
- Immobilizer problems
- 3dr brake wear indicators
- Escort cosworth boost clocks wiring
- Need help with coilovers
- Missing torque....what do you think?
- Help please, fitting RS500 clocks in a saff
- Who can explain the basics of Mapping to me please :-)
- CHATTERING
- COSWORTH WATER PUMP
- FDS/WDS diagnostic systems question
- temp sensor
- zetec injectors
- FRST Cuting out
- s2 only running on 3
- RS500 T4 wastegate
- fuel mods for s1 turbo
- Overfueling?
- whats the prob here ??
- No power
- heater matrix
- WHO IS RIGHT
- Innovative Wideband lambda?
- Help wanted to identify wastegate actuator
- Going to look at a escort cabrio tomorrow, any advice?
- fiesta si problem
- polys and coilovers
- mercury Sable Front end swap
- Help - Overboost then no boost
- ARE ALL ESCORT COSWORTH CAR LOOMS THE SAME?
- Cosworth Air Temperature sensor, supplier, size, resistance
- 2ltr pinto turbo inj 205 block
- rumbling/grinding from front of mk4
- 14 inch wheels on rst front brakes?
- flamer kit - idea
- -31 actuator - Different ratings?
- boreing a 1800 zetec to 2000cc
- S2 judder in reverse
- escort brake lights sissing
- will eec1v head fit 4x4 cossie
- leaking gbox
- Need parts for my bilstein coilovers
- si problem
- What oil in a Zetec??
- Camber & Castor Angles
- spark gap
- Correct Battery Voltage
- knocking from front suspension
- Help with Colour Authenticity of Cosworth- Pics 56k beware
- solid lifters, s2
- who can supply a phase sensor pick up and bracket for a cvh?
- mondeo 2.0 wiring for conversion
- Mondeo Problem
- NGK 'R' PFR7B plug gaps...
- Fiesta - slight worry
- cosworth fuel pump
- Saff Cos fuel hose layout
- s.e.c.s monitor wiring
- headlights keep going off
- Cash paid 2 come & sort out problem wit my S2 - Somerset
- saph front driveshafts
- Escort cos wiring loom
- advise required boost adjustment
- 2wd ignition timing
- 4x4 shaft problems
- Cosworth fuel pump probs........
- Boost Problem With S2
- Help! Inlet manifold broke after NOS kicked in
- Cosworth shims sizes
- EFI XR3i management on Zetec HELP!
- oz rim
- dizzy!!!!
- Turbo model numbers
- Mk5 cab front wings
- 3 Door wheel offsets
- Wot fuel flow@5 bar is needed for 500 bhp cossie.
- cossie revs up at idle to 3k then nearly dies! any ideas?
- Clutch cable snapped...............help info.
- mondeo gearbox problem
- fuel smell!!
- Starting a garaged s1
- standard air filter 4x4
- A Couple Wiring Questions
- s2 running problem!!
- Underheating S2 RST
- newbie needs cam help :)
- RS 7 spoke help needed a.s.a.p
- charge cool
- Valve pockets needed?
- Cosworth management - only sparking on no:4
- Escort Cosi tracking setting in degrees?
- overheating s2 rst
- ECU
- please help! technical info needed
- going looking at a saph 4x4
- electric sunroof
- xr3i 90
- Spark Plug Gap
- Fiesta mk5 - Sticky Throttle
- another engine swap
- Engine swap
- MK5 rs turbo
- [b]Cossie Fuel Pump[/b]
- RS1600i gear linkage..........
- help needed
- help
- clutch probs advice please
