PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 [100] 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. help with con rods
  2. grs inter cooler
  3. Problem with Sparking...
  4. Problem with Sparking...
  5. Oil pressure sender for oil pressure gauge
  6. water contamination in oil after h/gasket failure...
  7. Coilpack experts....???
  8. next question
  9. 4wd Sapph: Cooling Fans have stopped working
  10. help st170 breaks on s2 turbo
  11. Cossie dashboard problems.
  12. Motorsport Developments
  13. turbocharching a twinky??
  14. smoking escos
  15. Damn immobiliser - FAO security experts
  16. Central locking problem on S2...
  17. message of error....
  18. same old same old
  19. fiesta brakes
  20. help 4x4 not starting
  21. converting DOHC carb engine to injection.
  22. Drilling a air box
  23. FRST COUGHING
  24. Question about mfi and efi rst heads
  25. supercharged turbocharged focus HELP
  26. 2wd saff cossie problem
  27. PLEASE HELP ME BEFORE I BURN IT!
  28. granada scorpio diff
  29. Boost solenoid t-piece and piping - help needed
  30. False temp reading 4x4 cos
  31. selling
  32. BC boxes do they differ?
  33. efi conversion help
  34. torque settings for arp stud and nut kits
  35. Question about oil restrictor
  36. cylinder head cvh
  37. Escort rs turbo drive shaft
  38. Bailey Dump Valve
  39. cossie running problems
  40. ERST Running Problems
  41. Fans wont shut off
  42. needing advise on Series 1 brake conversion
  43. front escort cossy shocks
  44. rs 2000 fiesta van
  45. cossy /pinto power?
  46. 16v zetec turbo???
  47. 2wd wheels ???
  48. Part no. for Diamond cut RS 7 Spokes???
  49. oil
  50. Cossie Ign Amp...Different makes...???
  51. How important is vechicle speed sensor?
  52. Any ideas on whats going on with my boost
  53. valve guides
  54. torque settings?
  55. erratic temp gauge...
  56. zetec 16v turbo help
  57. saff 4x4/2wd
  58. S2 Turbo Smoking
  59. rich cossie
  60. ERST MFI Help
  61. smoking cosworth
  62. What year for the fuel computer????
  63. Oil Leak - Series 2 RS
  64. COSSIE BOTTOM END
  65. crankcase pressure??
  66. setting up a Kent cam
  67. 3dr twin fans
  68. ZETEC 1.8 RQB CAMS
  69. Pinto oil pressure troubles, advice needed!
  70. 2WD cosworth prop center bearing
  71. car wont start no fuel out of injectors!!!!!!!!!!!!!
  72. temp gauge on s2 rst goes straight to the top?
  73. Boosting Point on a S2?
  74. cosworth brakes on series 2
  75. Coswoth Exhaust Manifold
  76. EFI CUT OUT PROBLEM
  77. Engine Dies momentarily....intermittent...Any idea's???
  78. mk3 turbo front anti roll bar will it fit mk3 cab
  79. Best handling wheels for sapphire cossie ?
  80. st 24, slow! poor preformance. can you help
  81. esc cos problem
  82. Zetec turbo head bolts torque settings.
  83. cossie abs
  84. air charge sensor (brown)
  85. HELP!!!2x kenlowe fans and grs evo3 i/c fitting to s2
  86. 4x4 intercooler fitting to a 2wd Saff
  87. Gearbox.
  88. ml developments oil breather on s2?
  89. 2wd/4wd
  90. Cossie Swirl Pot
  91. Engine rattling on mates s2
  92. xr2i power problem plz help!!!
  93. engine probs
  94. What exactly does a chipped ECU do?
  95. Chip Advice on a S2 RST
  96. ford sierra cosworth real wheel drive borg warner t5 gearbox
  97. HELP!!! Gearbox trouble...i think
  98. spark plugs champion q57c plz look fast ford coming sat
  99. bw t5 bellhouseing to block bolt port lengh
  100. ford focus + cobra alarm central locking
  101. escort cosworth running problems any help please
  102. ZETEC TURBO OWNERS --------INFO PLEASE
  103. Cossie running problem
  104. HELP NEEDED HELP NEEDED HELP NEEDED
  105. A common misconception (oil viscosity)
  106. Escort Cossie wheels on Escort GTI
  107. 1996 si escort
  108. s2 - no indicators and headlights work wrong way round???
  109. cossie abs fault
  110. GTI engine in a fezza
  111. what power to expect?
  112. HELP needed
  113. quickshift on 4x4 cossie
  114. Rear Shocks
  115. In need of help (spark plugs)
  116. pics of mk 5 moded vans
  117. What lsd??
  118. erst fuel and starter motor problems. help much needed
  119. Dump Valves and GT series Turbo's
  120. Dump Valves and GT series Turbo's
  121. Transit Hubs/brake assemblies
  122. Low oil pressure after oil top up!?!?!
  123. MK3 Mondeo V6 ZetecS Rear Suspension Knocking
  124. mondy pictures
  125. 1.6 cvh blocks
  126. sticking valve on 1996 mondeo zetec 1800
  127. need EDIS spark system, which models can I lift it from?
  128. cosworth, please help
  129. idle prob frst
  130. fia battery master switch
  131. compressed volume for series1 zetec 1.8 and 2.0 litre
  132. escort rs alloys
  133. xr2 chargeing
  134. BD12'S?
  135. timming
  136. HT LEAD OHMAGE
  137. ABS light 2wd cosworth
  138. points to electronic ign
  139. Small turbo Escort Cosworth injector impedance query
  140. help what carb and lowering kit plz plz plz
  141. Oil in the boost hose (S1)
  142. mk1 fiesta ghia left hand drive door mirror
  143. 4x4 gearbox
  144. diff gone on my 2wd saph
  145. escort rs turbo cuts out when the oil filler cap is removed
  146. escort gearbox markings??
  147. Escort 1.3 4 speed box 2 a 5 speed - help needed
  148. Stud kits/head gaskets
  149. diff split
  150. actuator advice please!!!
  151. ESC COS DASH PROBLEM
  152. coilpack question
  153. cosworth misfire
  154. Squeak in wheel area
  155. ECU identification
  156. Escort Cosworth Fuse box.
  157. sump gaskets 4x4 2WD
  158. cosworth rear disc conversion
  159. air bag light escort td
  160. very strange escort cossie boost problem
  161. cosworth inlet manifold Q
  162. How to get air out of my Cossies Coolant ???
  163. FAO Alarm people / clifford avantguard 5 owners
  164. Misfire on 2wd cosworth
  165. BIKE CARB TUNERS IN LEICESTER AREA
  166. Cossie 2wd brakes, 4 pot calippers repairkit
  167. Escort SI 1996
  168. Custom Inlet for Bike Bodies??
  169. Advise needed on changing fuel filter 2wd cossie
  170. ECU Query
  171. 2wd saff cossie ride height
  172. oil pressure
  173. Escort Cosworth Fuel Pump.
  174. daft question possibly
  175. Carbon fibre bonnet wont fit
  176. ABS light
  177. PROBABLY A DUM QUESTION
  178. Head Gasket?
  179. Cossie boosting problem???
  180. air induction kit advice needed
  181. broken 2wd diff
  182. Poor man's Cosworth ARB?
  183. help
  184. Fiesta turbo Missfire
  185. zetec turbo
  186. Any way to get more lock on a sierra
  187. gearbox
  188. ***URGENT HELP, S1 HAS NO BAT/OIL/H-BRAKE DISPLAY????***
  189. flywheels
  190. RS1800 wobbly speedo
  191. Uprated brakes FRST on a budget any suggestions???????????
  192. head gasket?
  193. fuel pump
  194. Need help identifying part
  195. Rev counter is not working on my frst ?
  196. frst problem
  197. ford capri v6 blocks
  198. xr3i cabriolet and turbo fuel tank?
  199. starting Problem on Esc Cos
  200. 24v capri x-member
  201. automatic choke problem??
  202. Probs removing bolts from 2.8i leaf spring front anchorage
  203. Cossie fuses
  204. Removing speedo cable from cossie 2wd T5 box
  205. lowering mk2 orion 30mm - anybody done it?
  206. Shearch OE eprom file Cossie 2WD 204hp
  207. MFi to EFi on an Escort RST
  208. fuel pressure regulator on rs turbo
  209. TURBO TIMER HELP !!
  210. cossy rad fans not working (sorted thanks guys!!)
  211. fiesta rs turbo steering rack
  212. rear shockers for escoss
  213. whats in a T34
  214. Just wondered...Effects of cam change??? (Cossie Experts)
  215. help with ka 2.0 zetec engine
  216. 2wd saph piston slap
  217. Arch Rolling
  218. Rear Disc Conversion
  219. stalling when cold
  220. cossy shocks
  221. Focus locks
  222. ERST S2 Oil Pressure
  223. MK4 ESCORT XR3I EFI 1990 POWER BOOST VALVE
  224. ERST OFFSET?
  225. Cossie won't start Please help
  226. s2 displays no oil light/bat light/handbrake light etc
  227. got a problem my cosworth wont boost properly :(
  228. ODBII connections
  229. XR3i to RST
  230. XR3i to RST
  231. Mondeo V6 brakes
  232. volt probs ??
  233. OFAB or OFAC
  234. HELP does anyone know about PATS(passive anti-theft system)
  235. FRST Engine problem
  236. Advice on fitting 2litre black top to an RS1800
  237. fuel smell in 2wd saph
  238. -1.1 psi with engine not running?
  239. zetec turbo wiring
  240. DTC codes - please help!
  241. rst crank sensor
  242. REUPHOLSTERING LEATHER RS STEERING WHEEL
  243. leaky 3dr brake pressure reduction valve
  244. Injector frequency oscilloscope traces
  245. help idle control valve can i...............?
  246. rs2000 engine conversion in to mk3 escort
  247. cossie top end oil leaks
  248. Escort Cosworth Fuse Box.
  249. What the best offest for 16" for a 4wd sierra cosworth.
  250. LSD help??
