Fitness / Weight Training Discussions Don't drive around with 4 chins! Chat to like minded folk in here and get yourself back to a decent health and fitness level in no time.
Home Equipment
Old 10-11-2005, 12:12 AM
Chris-S2
Chris-S2's Avatar
Default Home Equipment
What equipment would anyone recommend I should buy for home use as I really want to start weight training but more often than not cannot make it to a gym due to work and home commitments. Also is there anywhere you can recommend buying the equipment from?
Old 10-11-2005, 11:27 AM
Paul Eggleton
Paul Eggleton's Avatar
I started out with a Dumbbell and Barbell set from Argos. If you have room I suppose you could get a multi gym, but it will never be as good as a proper set of free weights.
If I was forced to train in the garage I would have a bench, set of posts for squats, an olympic bar and a variety of weights. With this you can train everything.
Old 10-11-2005, 01:00 PM
Chris-S2
Chris-S2's Avatar
So if i'm reading this right I don't need a multigym? To start with a good set of free weights is the way forward with a bench?
Ok what sort of bench? I looked here and there's hundreads of different ones! Benches
As for free weights would these be ok? Free Weights
Cheers,
Chris
Old 10-11-2005, 04:10 PM
Paul Eggleton
Both look fine go for one of the barbell benches
Old 10-11-2005, 05:16 PM
Chris-S2
Chris-S2's Avatar
Ok Paul cheers for your help so far
I'm going to buy these Free Weights unless anyone can see a reason not to?
I'm undecided on the bench though, I don't really no what the difference will be in terms of quality and the way (if any) it will help me work out better. These are the ones i've seen Bench1, Bench2, Bench3, Bench4 and Bench5 The main thing I can see is the squat rack on Bench5 but is it worth it in terms of quality etc?
Chris
Old 10-11-2005, 05:57 PM
Paul Eggleton
Actually the fifth one is a good allrounder and it has the extra arm curl(preacher) bit too.
Old 10-11-2005, 06:07 PM
Chris-S2
Chris-S2's Avatar
Ok I guess i'll be going shopping tommorow then!
Thanks so much for your help
Chris
Old 10-11-2005, 06:25 PM
Paul Eggleton
no worries, the postman will love you
Old 10-11-2005, 07:30 PM
dexterc
dexterc's Avatar
If you had the money, Id say free weights, power rack, bench, in that order.
The problem with the squat rack on that bench is that it doesnt have safety bars. So, basically, you cant go anywhere near a 1rm attempt. Because if you should fail a rep, youre likely to get stapled to the floor. In the power rack, of course, youd be saved by the pins. Not to mention, of course, all the attachements you can get for power racks, plus all the extra exercises it allows you to do.
Old 10-11-2005, 08:10 PM
Paul Eggleton
Ronnie doesn't use a power rack for squatting he just employs 2 people to stand next to him .
Anyway, if you go anywhere near one rep max's in your garage, on your own you are asking for trouble .
DAZZER
30-09-2015 08:43 PM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
IainRS1700T
25-09-2015 06:44 AM
Botts
22-09-2015 02:04 PM
Quick Reply: Home Equipment
