My current routine *now with pics*
I don't stick to a specific bodypart on a specific day necessarily, I go by how I feel. However, everything will get trained once in a 7 day period and I train 3 - 4 times.
Chest and Biceps
Low incline bench press (i don't do flat as my shoulders don't get on with it)
1 x 20 x 60kg, 1 x 15 x 60kg, 10 x 100kg, 5 x 120kg, 2-3 x 130+kg immediately follwoed by a drop set of 100kg to failure then 60kg to failure.
45degree incline dumbell press
10 x 30kg, 8 x 40kg, 8 x 50kg
Low incline db flyes
10 x 25kg. 2 x 8 x 35kg
These are my main exercises. To finish off I will either use the pec deck machine, wide grip dips or cable crossovers or a mixture of all three.
EZ bar curls
12 x 30kg, 10 x 50kg, 8 x 60kg
Standing db curls
10 x 20kg, 10, 25kg
Again these are my main two exercises, and I will finish off with preacher curls (ez or db) and or hammer curls.
Legs
Leg extensions
2 x 15 warmup
Squats
Heavy day
2 x 15 x 60kg, 15 x 100kg, 10 x 140kg, 8 x 180kg, 5 x 200/210kg
Light day
2 x 15 x 60kg, 15 x 100kg, 2 x 20 x 140kg
Leg press
15 x 200kg, 15 x 300kg, 10 x 400kg, 5+ x 500kg
[b] I tend not to go heavy on leg press if I have gone heavy on squats. I sometimes alternate and do leg press first and then do light squats[b]
Leg extensions or hack squats follow for 10+ reps depending on how I feel.
Lying leg curls
I don't train these as hard as I should. I tend to pyramid over 5 sets to a maximum weight x 8 reps.
Stiff legged Deadlifts.
I only do these if I don't do regular deadlifts with back later in the week, i.e I alternate between weeks.
again I pyramid upto a maximum of 140kg x 5-8 reps
Standing Calf raises
Either pyramid upto the stack which is 250kg and keep in the 10-15 rep range or do a warmup, then stack it. Then to 5 reps at a time, each time dropping the weight by 20kgs until you are left with just 50kg on the machine and fucked calves
Toe press - I do this on the leg press machine (saves lifting all the weight off at once ) 15 reps and around 200kg. This is a good alternative tot he stg calf raises.
Seated toe raise.
3 x 15 x 40-60kg depending on feel.
I'll cover Back, Shoulders and Triceps later.
Chest and Biceps
EZ bar curls
Standing db curls
10 x 20kg, 10, 25kg
Legs
Leg extensions
2 x 15 warmup
Squats
Heavy day
Light day
Leg press
Lying leg curls
Seated toe raise.
Going by what you have written above i take it your a BIG fooker
Fair play mate thats some routine
Im just gettin into weights so this sub forum is gonna be a great help to me and others!
Nick
Nick
I've been training for over 12 years in total, and in that time just prgressed slowly, which is what it is all about. Quick progression is a sure fire recipe for quick regression.
Paul.
I'm just starting out so most of my stuff it light.
between 29-35 for Bench Press, Curls and that for the arms.
legs I'm actually on a lot more about 79kg for the leg press
then just do some crunchs 4sets of 15
Must get my motovation back and get back
fook me! i saw you in your car lining up at combe this year and didnt realise you were that big!
fair play to anyone who can sustain that routine!
so far ive been hitting every area every day on the weights. since reading your advice ive shortened it down to a couple of muscle groups each day. and moving out of the comfort zone and working them to failure which ive never done before. ive only done it for a few days but body is feeling good so far. will keep looking in here for more tips as i get on!
Thanks Stu.
I must say I'm really enjoying this room. I've actually always wanted to run my own gym and maybe one day it will happen. Until then its just a hobbie.
How are you getting on??
PassionFords Creator
Im doing ok, and it may sound daft but im "Feeling" stronger.
I have continued with my routine until Saturday Morning when i hurt my back a little, i feel a twinge and KNOW i need to leave it be for a few days so ive started to concentrate a little on my diet. Ive updated the foods topic
Originally Posted by Paul Eggleton
Cool, are you doing anything to try and strengthen your back?
Ive sticking with situps and leg raises for now, unless you have an idea of some good ones? The problem area is my lowest 2 discs. They grind together as they were damaged in an accident. The physo told me i need to strengthe the muscles that control spine movement.
Whats your flexibility like and how are you day to day?
Would you be comfortable keeping your legs fractionally bent and bending at the waist until your upper body is just past parallel with the floor.
If so, just do these for 10 reps at a time without any weights and see how you get on. Do them through the day (3 or four times) and just concentrate on good form and keeping everything straight. If, after a week or so this is ok, hold a book to your chest when you do it or a couple of cans of beans.
I think the key is to keep it simple and start from the basics. There are other machines which allow you to use your own bodyweight, but this maybe too much if your back is not used to it.
You should still be able to train around your back problem. e.g. If doing dumbell curls sit on a bench/chair to stop you swinging or lean against something. This is also good anyway as it adds a bit of variety and causes you to adopt a stricter movement without 'cheating'
Cheating is effectively the term used for using a bit of body motion to swing weights up. Its Ok to do it a bit to squeeze the last few reps out of a set but if you do it from the start, the weight is too heavy.
BACK
Usually start with Deadlifts
2 x 15 x 60kg, 10 x 100 kg, 10 x 140kg, 8 x 160kg, 5 x 180kg. I don't go any heavier anymore due to a back injury.
T-Bar rows: 12 x 40kgs, 10 x 60kg, 10 x 80kg, 8 x 100kg
Reverse grip Pulldown Hammer machine: 10 x 60kg, 8 x 80kg, 6x 100kg
Seated cable rows, close grip: Not sure on weight just 10 x 1/2 stack. 10 x 3/4 stack and 8 x full stack.
Straight arm pulldowns(on tricep pushdown machine) 2 or 3 x 15 x 30kg - just to pump them up.
Occasionally I will through in Bent over barbell rows, chinups, dumbbell rows and wide cable pulldowns. The BB rows will replace the t-bar rows.
SHOULDERS - the shulders are made up of three muscles. The front side and rear deltoid. The pressing hits the front and side, the side raises the side(obviously) and the bent one does the rears
Seated Dumbell Press: 2 x 15 x 20kg, 10 x 27kg, 10 x 35 kg, 8 x 40kg, 5 x 47kg.
or Press behind neck on smith machine.
Standing (sometimes seated) dumbbell side raises: 12 x 15kg, 2 x 10 x 20kg.
Bent over dumbbell raises - 12 x 20kg, 2 x 10 x 27kg
Shrugs or Upright rows: I either do shrugs with a barbell, two dumbbells or on the old style bench press machine.
My gym has a couple of other shoulder machines which I may use if feeling up for it, otherwise its basic and heavy free weights.
TRICEPS
Close grip bench press: 2 x 12 x 60kg, 10 x 100kg, 6-8 x 140kg. Maybe a dropset too - 6x140kg - 6 x 100kg - failure x 60kg.
or Skull crushers: 15 x 30kg, 10 x 60kg, 6 x 80kg. Last set will be a dropset.
Pushdowns (using a variety of bars or the rope): 3 sets x 10reps
One arm DB extension over head: 2 x 10 x 15kg
Narrow Dips - 2 x Bodyweight to failure.
TRICEPS
what size are you arms in inches ?
how long did it take you to get from normal muscle mass (skinny) to your state in those pictures ?
v. impressive
v. impressive
I don't know what my arms are now. I do know they broke the magic 20" barrier when I was 18 stone . They are probably around 18.5-19" now.
I've been training since I was 17 and I am now nearly 30. I have used steroids in the past, but I've also had testicular cancer which made me drop a couple of stone when I was 22. I haven't used anything other than over the counter supplements for the last 7 years, and these have only been protein powder and creatine.
Hope that helps
Hope that helps
Just to emphasis I don't fo it all in one go:
MOn:chest and bi's
Tues:quads and calves
Thurs: shoulders and tri's
Fri: Back and hamstrings
MOn:chest and bi's
Have you ever found any problems having two pressing workouts 3 days apart? Did you ever do any power/oly lifting or strongman competition? What were your maxes in the big 3 lifts?
Sorry for all the questions.
I won the Uni power lifting contest one year. I was quite happy as I don't train as a powerlifter as such.
Bench: 150kg
Deadlift: 250kg
Squat: 250kg
Bench: 150kg
Deadlift: 250kg
Squat: 250kg
Bench: 150kg
Deadlift: 250kg
Squat: 250kg
Bench: 150kg
Deadlift: 250kg
Squat: 250kg
Just another 80 to go!!
Looking good Paul. Your lucky enough to have the frame set that you do as I weigh 230lb, push some fairly decent weights but look no-where near the size of you!
As for the fighting comment, I always find some cheeky little chav with something to prove wants to try it on. Best to just ignore them.
Thanks, being a short arse does have its benefits
Although I carry quite a lot of thickness around the waist, despite the photo above, and I will never naturally be very lean. Just do it now to maintain size and some degree of fitness.
Only managed to train twice this week due to work and family commitments
Well I did tryto put it politely!
How short is short ?
5ft 8" as above.
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
