what is the weight of the bench press bar
does anyone no the weight of the olympic bar used on the flat bench press,and the weight of the one used on the smith machine as well please
Olympic bar is 20kg yeah.
Different makes of smith machines have varying weights of bars/resistance levels.
10kg-20kg at a guess. I can lift heavier on the smith than i can with the olly bar so the one at my gym is definately lighter than 20kg.
the smith machine in are gym has the extensions on it the silver wide looking things.i can bench heavy on smith than the free weight bench press.alot of people say anyone can do it on the smith machine and that the free weight bench press is harder.i can do x2 20kg plates and x1 10kg either side but on the free weight bench press can only do x2 20kg plates either side,thats what made me ask how much do the bars weight becuase i can do more on one and less on the other
the bar on the smith machine being lighter is only a small part of why you can lift more using it.
The main factor which allows more weight to be lifted is your not using your connecting muscle or even your normal muscles to the same extent as you would normally, as the smith machine helps support the weight and guide you through a set range of movement. On a free weight you control the full weight and movement so in turn you grow more and gain strength quicker.
Yep free weights FTW!!
Ban[B][/B]ned
Benni.
wowk
30-03-2021 07:49 PM
The Enigma
12-09-2015 10:12 PM
Tony W
09-09-2015 12:08 PM
