Cutting Cylcles...Can you stack take Deca with Winstrol.
Why do you wanna take the two together? Winstol is good for keeping you lean whereas deca will hold water hence defeating the purpose id say. Better off with some tren or masterdon etc
You can stack anything you want together but as ollie has said kinda defeats the purpose of using a classic building sted then adding a good lean,cutting sted in!!
Test,deca,Dbol or Oxies ultimate mass building simple cycle
Winny,Tren,Test classic cutting cycle if you can handle tren that is lol
Dont get me wrong seen loads of guys running test,deca,dbol then at last2/4 weeks of cycle adding in clen,winny anavar etc etc to try and harden up a bit before cycle ends but to me you either bulk or cut not both at same time as you end up cutting short your mass gains and dont really benefit greatly from the mini cut,so waste of gear and money IMHO
I was under the impression that Deca was a hardener, didnt know it bulked as well, I thought when people are on the old Sus/Deca combo the sus was to bulk and the deca to harden, oh well you learn summit new every day, thanks lads, saved me from wasting my money
does'nt your diet decide weather you are on a cutter or bulker some drugs focus more on cutting like tren a, test P, masteron but i could be wrong has anyone used the fast acting deca with the propionate ester Nandrolone Phenylpropionate shorten
name for it is NPP
sean
name for it is NPP
sean
name for it is NPP
sean
name for it is NPP
sean
Mr Brannen, have a look on here. Join up and ask the questions there mate, or use the search function.
http://www.muscletalk.co.uk/Steroids...drugs-f61.aspx
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
