fat index
from what i gather its the same as body fat %
they say you should take a good few readings before taking an avarage to allow for water retention etc
personally i'm not really inclined to use it as if you look fat then you work harder at the gym
Aye it just sounds like your body mass index.
Generally they say........
Underweight = <18.5
Normal weight = 18.5-24.9
Overweight = 25-29.9
Obesity = BMI of 30 or greater
Underweight = <18.5
I'd like to know more about this bodyfat % thing as well.. mates at the gym have had it done, I've no idea what it's all about (besides the obvious) Can anyone help?
It can't be BMI surely, one lad in particular blatently defies that, but has a low bodyfat % whatsit.
Originally Posted by gus
just got back from gym and its now 20.4
is it a percentage of your body that is fat?
It is your body fat %. So if you weigh say 12stonex14=168lb - 20% =134 is your lean body weight.
The best and most accurate measure of body fat % is done by the use of hand held calipers. You need someone who knows what they are doing and it is normally taken from several areas. See if one of the instructors at you gym is proficient with this method.
The scales or hand held items can be very inaccurate, as is the timing of when you are measured with regards to food or fluid intake which will make a difference to the readings.
Originally Posted by Steve200+
How is it measured? I've heard of being done, but haven't been paying attention... special sort of machine or something?
I think you can pick up fairly cheap bioelectricial impendance devices now, not sure though.
Riiiiiight I've seen people vaguely with the big 'pincers', makes sense now, Cheers chaps!
Rs : I packed in the gym, after they issued a 'no sweat' policy.
Dave, would you believe it
http://www.maplin.co.uk/Module.aspx?...714&doy=search
Ben26
27-08-2015 08:56 PM
