test 400
test 400
one week into my cycle with test 400 and oxy's and 3days after injecting the test into my glutes i get a lump cum up like it hasnt gone in properly. I wouldnt say it hurts as its liveable but usually if i get a lump its within a day of injecting.
Researching it on the net it says it known for site pain as its so thick. But my decca was 300mg per ml and went in easy. The test 400goes in nice and easy too.
Anyone had issues with this?cheers
post whore
You probably haven't went deep enough.it is thick stuff and might just be a one off.if your definetly going deep then all I can suggest is after pinning give your glute a deep massage.like properly work it in.it might be a bit sore but really press in to the glute to dispers the oil.
just 1ml twice a week. I used greens so 1.5inchs so it went in enough. Just weird how it took 3days to come up. I massage it for about 30seconds as thats usually long enough and never had any issues with sus and decca
yer i'l try. I think from my research its hard to despence in the body as its so thick. I'l try warming it up but the net said it is painfull stuff to inject
..BS Motorsport..
Fuck using a green, Jesus, I draw with green and pin with orange, much less scar tissue. Greens are like throwing darts!!! I push test 400 through no probs, just nice and slow.
Zee Germans are coming
As sais draw it out with the green pin and I'd say inject with a blue
The green is to thick a needle tbh
I used to inject with green as it didn't bother me
Also heat the test up before injecting as it can help thin it out
Your body will get used to it but just takes time
Also don't inject the same body part to often
So 1 week inject the bum cheeks then shoulders then biceps etc etc
Let the scar tissue heel before going back in
Sounds normal to me. Prochem can be a bit hit an miss with pip I have found.
If its not heated up it takes ages to go through a Blue but doable. I tried a Green last time to get a couple of ml in deep and the pain and swelling was terrible. Uncomfortable to walk even. Only lasts a couple of days but the last lot of PC I had done exactly the same. Does toake a few days to develop too. It's thick ole stuff and takes a while to disperse as had been said.
Unless its red and hot to touch I wouldn't worry too much about it.
TPM961
15-01-2018 10:50 AM
