shoulder routiens
And for a bit of variety, upright rows, pull up to chin, then out in an arcing motion til arms are at full reach and then back down. Difficult one to describe that.
As Ollie but with seated dumbell presses instead of barbell and no standing press for me. This is twofold as I have a weak lower back and military presses put undue pressure there aswell as puting alot of stress on the shoulder joint when going heavy and expecially when lowering the bar to the back of the neck.
I also sometimes do side raises but seated and leant forward with my chest of my knees. This hits the rear head of the Delt. Also try cable side raises, one arm at a time. Sounds odd but the constant tension means you control it more and feel the pull on the down stroke of the movement.
I train traps with back but thats down to personal preference. Traps work both with the back and shoulders so either or.
Most importantly though, and more so with shoulders, make sure your form is correct. The amount of pidgeons I see half the size of me chucking up twice the weight as me on side raises is astonishing. Its one of the easiest exercises to cheat at and it will do you no good. A light controlled weight is required and personally I dont need to go over 12.5kgs per dumbell for proper side raises. Keep the arms out, only slightly bent, and don't rock from your lower back
Fleet Manager
i do pretty much every should exercise mentioned above dose any one followe a set order i.e. front side rear etc etc
usually so seated dumbbell, seat barbell in front of head (dont like behind)
the move on to side raise machine super set with standing side raises,
then front raises and seated bent over raises
i used to use cable side raises but get pain in the shoulder as with 1 armed side dumbbell raises
No specific set order for me but I do tend to go straight for the pressing after warming up as that exerts the most energy and gives me a nice pump ready for the lighter work.
Doesn't hurt to mix it up every few weeks though. Infact I would suggest it!
I'm the same - dumbell shoulder presses always the first exercise after warming up - currently on 36kgs dumbells - big jump to the next 40kgs though so its going to take a while!! I've found that dropsets can work particularly well when trying to advance your weights on shoulder presses - i.e. 8x 28kgs, 8x22kgs, 8x 16kgs all straight after one another - then 3 or 4 sets of this.
when you do a standing barbell press, ie push bar up then down whilst standing, how do you ensure your back stays straight ?
mine ALWAYS bends and hence i dont do them for fear of injury.
Im trying to get slim get my bodyfat down to around 12% AND THEN pile on the muscle, however I dont want to lose the very wide shoulders i have at the moment. Weather there is muscle under the fat I dont really know, but wouldnt be suprised
Fleet Manager
i always though that, but after speaking to many many people about it i was told to wear a belt for safety
i was also told standing shoulder press was good for building shoulder mass not general mass lol
Standing shoulder press is good for building shoulder mass, but as with most shoulder exercises, a lot of people cheat.
You caan build muscle without doing ridiculous amounts of weight, but most of the guys in my gym will stick more weight on, and be bending all over the place.
Thats when you need a belt. To save yourself an injury.
Personally I prefer seated press to standing press, as it forces you to concentrate more on form, and IMO gives me a better pump.
one of the worst things i see in the gym is when people use ridiculously to heavier dumbbell for seated press and go down an inch with there mates help. and then throw them on the floor to make noise so everyone can see what they were trying to lift. with most exercises form is way more important that than weight
cheating doesn't pay
soulweavers
29-08-2004 09:54 AM
