Fitness / Weight Training Discussions Don't drive around with 4 chins! Chat to like minded folk in here and get yourself back to a decent health and fitness level in no time.
My workout.. Ok?
Old 09-07-2007, 07:08 AM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Default My workout.. Ok?
Right here goes, Been doing this for the last 27 weeks....
Any pointers, nit picks, suggestions or comments welcome please as thats what im after
Been training 5 days a week without fail, Thing is.. Im not after big legs, So I dont weight train them! But I do do Cardio... Mainly bike riding and a little bit of running.. Not after a '6 pack', I just wanna be big.. I train my ab's, But not to much ( Guessing cardio and sit-ups does that?! Which is all I do )
Is this program 'ok', Even though I've seen a good improvement.. I just wanna get opinions
(Im benching 70kg, Which is including the bar weight)
Shoulders, Back and Biceps
Dumbbell Lateral Raises to Front
1 Warm-up set of 10 reps
2 Heavy sets of 4-6 reps
Cable Lat Pulldowns to Front
1 Moderately heavy set of 6-8 reps
Barbell Shrugs
Standing Alternate Dumbell Curls
Standing Straight Barbell Curls
Chest and Triceps
Flat Bench Press With Straight Bar
1 Slightly heavier set of 6-8 reps
1 Even heavier set of 3 reps
Dumbbell Flat Bench Chest Press
Lying Tricep Extension
Standing Tricep Pushdown on Cable Machine
Back and Biceps
Dead Lifts
Cable Pull Downs to Front
1 Arm Barbell Row
Dumbbell Shrugs
Standing Alternate Dumbbell Curls
1 Warm-up set or 8-10 reps
Standing Straight Bar Curls
Thanks, Look forward to replies
Old 13-07-2007, 07:06 PM
Manchester Mike
Manchester Mike's Avatar
Default Re: My workout.. Ok?
Chest and Triceps
Good work out mate, is this a typo or is this all you do for chest?
These two are basically the same excercise so maybe after your bench press, you could do incline dumbbell press, or if you don't work the top of your chest and stay on a flat bench, do dumbbell flys instead of the press?? (i normally do around 4 chest excercises per session and work nothing else that day).
Also do you work shoulders, back and biceps all on the same session? I'd be fucked after that, i see you do your front lateral raises for the front delts... but what about your side and back delts??
From the pics you sent your coming on well mate
Old 13-07-2007, 07:25 PM
Manchester Mike
A very breif run down of my workout..
Chest... (change order around each visit)
Barbell press
Incline smith machine press/ or incline dumbell press
Flat dumbbell flys/ or incline dumbbell flys
Decline smith machine prees/ or decline bumbell press
Go home
Back....
Chins, palms facing away... (untill failure)
Heavy barbell rows/ or dead lifts
machine lat pull downs/ or cable pull toward you thingys
Wide grip cable pull downs/ or close grip pull downs
Go gome
Arms....
Lay down tricep extensions (alternate between z-bar and dumbells)
Cable pull down tricep extensions (change grip each visit)
Bent over rear dumbell extensions/ or seated dumbell extensions above head
Barbell curls (heavy)
21's with z-bar (torture )
Concentration curls or preacher curls... Done
Soulders....
Seated dumbell press/or machine seated press (can go heavier with machine)
Heavy dumbbell shrugs (weak point training for me but many people do them at end of session)
Bent over dumbell raises/ or reverse pec dec flys (rear delts)
Side lateral dumbell raises (side delts)
Arnold press/ or front leteral raises (front delts)
Behind head smith machine press/ or malatary press
Done.
Abs at home but not enough, don't train legs
Also mix up heavy days/drop sets in there etc.
Hope you see something that helps
Old 15-07-2007, 03:11 PM
maxrs16
maxrs16's Avatar
i was told but it could be bollocks because i wasn't listening at the time that 4-6 reps is a strength builder not a muscle builder and 6-10 was a size builder so if you dropped the weight a little to let your self perform a few extra reps you may see improvements
Old 15-07-2007, 04:28 PM
JoeE30
JoeE30's Avatar
heavy weight and low reps wil mainly tend towards strenth, ideally and as basic as possible you need to exhaust the muscle with slightly lower weight and higher rep...
I normally train each day, 4-5 sets of each exersize including a warm up. start on a low weight just to loosen and stretch. then start at about 50% of my one rep max for about 14, working up to 8-10 on my last(4th) at about 75-80% of that one rep max and i go to failure on every set....
Thing is what works for one dont work for the other....Just keep changing around till you find what works and when you are happy with the results.
Normal chest for me is flat,incline,decline bench. Flat, incline flys(sometimes decline) cable xovers or dips. Im benching 242lb at the moment or 110kg.
Keep going mate it will all come together, i have been training for a while now and im still no way near where i want to be and learn something new everyday.
Old 16-07-2007, 02:38 AM
Charlie Chalk
Unknown.
Manchester Mike
Mike, I do more exercises for my chest, Im not just sure on what the name of the exercise is
Cheers for advice
Old 18-07-2007, 01:11 PM
ballin
ballin's Avatar
Radders increase your 'heavy' sets to 8-10 reps, rather than 4-6.
Old 18-07-2007, 09:21 PM
Kam B
Kam B's Avatar
good thread..iv took some pointers
i need a training buddy...anyone from slough? lol
Old 19-07-2007, 05:29 PM
Charlie Chalk
Unknown.
I'm from Uxbridge.... But I train on an RAF camp
Old 19-07-2007, 07:16 PM
marky_g
Fleet Manager
marky_g's Avatar
i been told if u want mass u'll need to do more reps mate
warm up each muscle with 2 sets of 12 i personaly then follow with my max weights and do 3 sets
1st 12
2nd 10
3rd 8
just do 3 excerises per muscle . but u must do max weight you can lift i.e what ur doin on ur last set
i might be wrong but its what i was advised for mass
Old 29-07-2007, 01:45 PM
foreverwhite
foreverwhite's Avatar
your doing the 10 rep warm up set correctly, and i like to see the fact that your keeping things heavy, with low reps.
too many people go doing 15 reps on fairy weights wondering why they arent getting any bigger.
Old 30-07-2007, 02:41 AM
Charlie Chalk
Unknown.
My aim is to get big! I'm getting there
Old 08-08-2007, 08:10 PM
Paul Eggleton
Paul Eggleton's Avatar
I haven;t had a good look at the workout yet radders, I see others have done that, but I did notice you don't like training legs, tut tut
Putting squats in your routine will have big impact all over. Its such a powerful exercise that calls on most of the bodies muscles that it has a very big anabolic effect for the whole body and can help gain overall size.
Try and start to squeeze it into your workout.
Also you'll end up looking like a right 'bar-body' with chicken legs if your don't train them
Old 09-08-2007, 12:01 AM
Charlie Chalk
Unknown.
LOL Cheers Paul
