Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Deleting breather hose. Ok?
Old 03-08-2016, 06:55 AM
Shaunc
Shaunc's Avatar
Default Deleting breather hose. Ok?
Hi
Has anyone ever permanently removed the breather hose on an MFI CVH? The one I'm talking about is the long hose that runs from the rocker cover to the air box still keeping the shorter hose connected to the inlet plenum and blanking off where the old hose was.
Will it have any adverse effect at all? I wouldnt be worried on any other engine but as the MFI engine is so temperamental when it comes to air leaks etc and I've now just got it running sweet after a lot of work and parts I don't want to cause problems but I am now going round the engine tidying it up, replacing hoses for silicone ones and painting various parts.
This long hose just looks messy to me and is currently held up with cable ties!
Old 03-08-2016, 07:59 AM
haz87
haz87's Avatar
Block off the plenum hose, then run a single hose from the cam cover to a breather or atmos. Block off the metering unit/airbox hole that is left also
Old 03-08-2016, 03:38 PM
Shaunc
Shaunc's Avatar
Yeah that's a good idea. Maybe fit a small catch can somewhere with the breather hose running into it. I would like to block off the plenum hose because I don't like the idea of unfiltered air coming from the engine directly back into the air supply
And it won't have any effect on the running of the MFI system HAZ?
Because the k jet system can be as touchy a woman on her time of the month!
Old 03-08-2016, 06:33 PM
haz87
haz87's Avatar
If you do as i said (block off plenum, block off metering unit end) they you've essentially removed all air leak points. Then the cam cover can naturally breathe to whatever you choose
Will keep the mfi happy and the engine a bit cleaner inside
Old 04-08-2016, 07:38 AM
Shaunc
Shaunc's Avatar
Cheers HAZ you've don't it again!
Chopshop85
26-08-2016 12:45 PM
rs_jim
Fiesta XR2
18-03-2016 11:37 PM
JPA
25-02-2016 08:35 AM
biglez
15
18-03-2004 10:56 PM
3door
15
29-11-2003 07:22 PM
Quick Reply: Deleting breather hose. Ok?
