Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Escort Van MK6 Steering Wheel Swap
Old 17-07-2016, 10:49 PM
Jpu121265
Jpu121265's Avatar
Default Escort Van MK6 Steering Wheel Swap
Hi, new to all this, just got a 52 plate Escort to do up and, amongst other things, the steering wheel is grotty as.
Was wondering how possible it would be to fit a wheel from, say, something like a mk6 Fiesta (fairly cheap to buy)? Will they fit straight onto the column, and presumably there will be fun and games with the airbags in them.
Any mileage in the above, or what have others done instead? Interested to hear any ideas.
Old 18-07-2016, 08:09 AM
Moderator
STeve's Avatar
not a straight forward swap best wheel would ne from a mk6 rs2000 or si as gti models etc have wheels like a bus
Old 18-07-2016, 07:28 PM
Jpu121265
Jpu121265's Avatar
Thanks for that, I'll have a look. Just the later Ford wheels are available for peanuts (more or less) and seem to be much more common.
May buy one and see what it takes to fit one, so long as the 'splines' fit up ok and the airbag will fit and wire up it may be worth a shot. If not can sell the wheel for what I pay for it.
Old 18-07-2016, 07:47 PM
Moderator
STeve's Avatar
splines and depth are different on other fords hence why you will run into issues unless you go aftermarket but then boss kits are expensive
Old 18-07-2016, 09:34 PM
Jpu121265
Jpu121265's Avatar
Ok thanks for that, I wasn't sure about the interchangeability but sounds like a lot of hassle. I'll try to find a decent MK6 wheel instead.
bigchris1984
11-05-2016 05:51 PM
RayT
03-04-2016 01:31 AM
paceo
23-03-2016 05:28 PM
Rs(555)
28-02-2016 08:31 PM
Quick Reply: Escort Van MK6 Steering Wheel Swap
