Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
16i Running Problems - When Warm
Old 02-10-2003, 12:45 PM
LeeBuckman
LeeBuckman's Avatar
Default 16i Running Problems - When Warm
I have a RS1600i which at the moment is ok apart from when the engine is up to running temp. When dipping the clutch to change gear or coming to a junction and changing down, the revs drop off and the engine will stall. For example, I drove the car up the road yesterday and changed from 2nd to 3rd and left my foot on the clutch to see what happened and the revs died off completely and the engine stalled. The engine started again once i released the clutch (effectively jump starting a moving vehicle)........ Can anyone help with this problem or make some suggestions what might be wrong.
Thanks In Advance
Lee
Old 02-10-2003, 01:03 PM
paul cox
paul cox's Avatar
it does'nt happen when cold then ???
only when hot ???? - whats the read out on the temp gauge ???
how much fuel you got in the tank ??
does it stall in tops gears ???
me thinking fuel pressure >>>> - at the moment
Old 02-10-2003, 04:10 PM
LeeBuckman
LeeBuckman's Avatar
Temp gauge is about half way. Does not seem to do it when cold but have not really driven car enough to say for sure. Tank is over half full with fresh petrol and car seems to tick over ok at approx 975rpm. Have not really experimented with the top gears too much but would not be suprised if it did the same thing when cold.... With regard to the fuelling, does not seem to misfire and has new fuel pump on car.................
Thx
Lee
Old 02-10-2003, 04:20 PM
Clare
Clare's Avatar
Your temp gauge is sitting half way at normal running temperature??? Blimey, mine sits just over the white marker except when im sat in traffic, thats the only time she raises that high!
Mine was doing what you've described but when it was cold, not hot, was just my idle speed.
Old 02-10-2003, 06:10 PM
paul cox
paul cox's Avatar
try taking the plugs out - see what colour they are 1st.
also - check that all the vacuum lines are conected,from the rocker cover - from the throttle body - from the plenium chamber - from the air flow meter area.
also - try just upping the idea slighty - see if that cure's the problem ???
lets us know - try and help you next step - okay
Old 02-10-2003, 06:30 PM
paul cox
paul cox's Avatar
about time pete - well said , easy as that
Old 02-10-2003, 06:31 PM
pete-rsi
pete-rsi's Avatar
Try cleaning the throttle housing with carb cleaner making shure the air filter is clean adjust idle screw so just to get it idling then have the Co checked and for any air leaks then adjust idle to suit, would'nt go looking for the complicated stuff just yet it's normally something simple
Where abouts are you by the way - somebody may be close to help.
Old 02-10-2003, 06:37 PM
pete-rsi
pete-rsi's Avatar
How did you know I was going to say that
Old 02-10-2003, 06:55 PM
paul cox
paul cox's Avatar
just magic
just re-set the clock again
Lee - keep us informed,as to how it is going ???
Old 02-10-2003, 09:17 PM
LeeBuckman
LeeBuckman's Avatar
Thanks Folks. Have spoke to another 16i Guru locally who said he is adamant the car just need setting up properly. He said much the same and said to make sure the right plugs are in it with right gap. Clean/Replace AIr Filter/Idle screw/Throttle Housing and adjust mixture etc.... I'll keep u posted.
Also, have problem when starting when hot but suspect it is just the starter motor. SOmeone else i know had a 16i that would only start from cold till he replaced the starter. Sound FAmiliar anyone ???
Thanks Again
Lee
Old 02-10-2003, 09:35 PM
pete-rsi
pete-rsi's Avatar
If it's slow and reluctant to turn over when cranking (hot) = Starter motor
Old 03-10-2003, 03:54 AM
kvflatman
kvflatman's Avatar
Sounds like my misses bless her
Old 03-10-2003, 07:25 AM
paul cox
paul cox's Avatar
nice one Lee - keep telling us whats wrong
good learning curve for all of us
Old 03-10-2003, 08:03 AM
It's Czech Mate
It's Czech Mate's Avatar
Try replacing the fuel relay and checking your vacuum hoses. Get it set up and I'll betcha that solves it as it's exactly what mine did when I had it.
Keep us all posted
Old 03-10-2003, 11:38 AM
Clare
Clare's Avatar
The hot starting problem could be the same issue that all Mk3 1600i escorts had, the alternator solenoid getting too hot and stops working. Once cooled down it starts working again.
Symtoms are:
When stationary for a long time and the engine gets warm enough for the fan to kick in, then you switch the car off and immediately try and re-start it, it either appears to have a dead battery or is very slow and sluggish turning over.
Good luck in sorting it out thou, just remember, we're all in the same boat and we all drive tempremental cars that often throw hissy fits!
Old 03-10-2003, 12:16 PM
paul cox
paul cox's Avatar
clare - mine dont (not yet anyway)
good luck - lots of things to try out now ???
Old 03-10-2003, 12:49 PM
Clare
Clare's Avatar
Not every car will suffer with the problem Paul, but it is a known fault with the Mk3.
Old 03-10-2003, 01:06 PM
paul cox
paul cox's Avatar
ahhhhhhhhhhhhhhhhhh
just around the corner for me then
Old 03-10-2003, 06:52 PM
Quickie
Quickie's Avatar
Get a series2 RST heat shield from fords to fit on yer starter stops them from getting TOOOO hot worked on mine A diesel starter motor out of an escort fits a lot more heavy duty than a std item
Old 03-10-2003, 07:02 PM
paul cox
paul cox's Avatar
quickie - you've got some S2 stuff then,on your motor !!!!!
yo-yo-yo , big up to ya man !!!
Old 03-10-2003, 07:06 PM
Quickie
Quickie's Avatar
SSSSSHHHHHHH dont tell everyone
Old 03-10-2003, 07:10 PM
paul cox
paul cox's Avatar
Old 03-10-2003, 07:14 PM
Quickie
Quickie's Avatar
It was a secret
Old 03-10-2003, 07:31 PM
paul cox
paul cox's Avatar
its oh so quite
dont mention the ????????????
Old 03-10-2003, 07:35 PM
Quickie
Quickie's Avatar
I thought i would pass on the helpfull tip
Old 03-10-2003, 07:42 PM
paul cox
paul cox's Avatar
and very usefull it is to
Thanks mr quickie
helpful as ever
Old 03-10-2003, 07:45 PM
pete-rsi
pete-rsi's Avatar
Yes but S2 diesel bits
and a sig test - i thank you and Alan.
Old 03-10-2003, 07:46 PM
Quickie
Quickie's Avatar
LOL
Old 03-10-2003, 07:48 PM
paul cox
paul cox's Avatar
pete - looks nice matey !!!!
S2 bit's - love it (shall i put my S2 engine in the RSI ??)
Old 03-10-2003, 07:59 PM
pete-rsi
pete-rsi's Avatar
no the diesel
Old 03-10-2003, 08:02 PM
paul cox
paul cox's Avatar
thats kev's 3 cylinder RSI !!!!
Old 03-10-2003, 08:06 PM
pete-rsi
pete-rsi's Avatar
Of corsa! it is
Old 03-10-2003, 08:07 PM
paul cox
paul cox's Avatar
thats no corsa - even though kev did win the "vauxhall t-shirt"
Old 03-10-2003, 08:10 PM
pete-rsi
pete-rsi's Avatar
Quickie will get it aaarrrrrhhhhhh
Old 03-10-2003, 08:12 PM
paul cox
paul cox's Avatar
will he now ???
he has had some cornish air in side him !!!!!
Old 03-10-2003, 09:41 PM
Quickie
Quickie's Avatar
Cornish beers fugged me up a bit
Old 03-10-2003, 09:44 PM
pete-rsi
pete-rsi's Avatar
and plugged you up a bit - i bet
Old 04-10-2003, 07:43 AM
paul cox
paul cox's Avatar
"bang"
any pastie's ??????
Old 04-10-2003, 01:51 PM
kvflatman
kvflatman's Avatar
Old 04-10-2003, 01:54 PM
Quickie
Quickie's Avatar
Yep had some pasties and brought some home
Quick Reply: 16i Running Problems - When Warm
