Is it true I cant do a ZVH whilst keeping twin coils?
Ive got a mint 1800 130ps out of my old cab. Been told I cant keep twin coils with a ZVH conversion????? Any Ideas?? Cheers, Rich.
i cant see any reason why not as you will be using yhe 16i flywheel although all of the holes on need slightly enlarging by 0.5 mm to fit the zetec crank, the 16i box is used also and fits directly to zetec block so it should work!!!!
Superb.... Will be giving that ago over the winter, Shes cammed and full st. Scorpion so a few more tweaks and should be fairly quick....... If ever back on the road!
Cheers, Rich.
Cheers, Rich.
I was originally going to do this to my RSi, but was told it wouldnt run on twin coils as the timing etc would be out in relation to the zetec although it could be rectified by installing a mappable Emerald ECU and having it mapped
Cheers.Sounds expensive that like!!
No one has answered my other question about the chassis numbers. Have you got any ideas wether ford can do them when new floor pan is fitted? No body seems to know and if im spending a fortune on the car I want it to be spot on...
Cheers, Rich
Cheers, Rich
I honestly dont know mate, Ive seen a couple of mk3s where the floorpan's been replaced and there's either no number or the original numbers been welded back on as a plate Have you tried contacting a bodyshop/restorer to see what they suggest?
If it worked I would of though the ignition wouldn't be correct or optimum.....Because the stroke on a CVH is different to a zvh and they have different requirements?
Would be a really really nice conversion if it worked
Compression ratio should be the same. 1900 Hurricane CVHs also ran very well in RSi's. I'd take some other kind of ignition, Zetec flywheel and OT-Sensor and the RS1600i twincoils
Cheers for that, Im thinking of building the engine then sending it somewhere, Any ideas who can do it I just wanna get the thing going!! But dont wanna get ripped off... Im moving to cleveland in the new year so somewhere near would be good.. Cheers
Rich
Rich
There is no reason at all why you cant run twin coils on a ZVH, the coils run off the fly wheel sensor which in turn is bolted to the gearbox.
You would have to use the CVH flywheel when doing a ZVH so run the RSi one as it has the pickup points for the sensor mounted on the gearbox for the twin coils and because you are running the CVH head then all the rest of the management would be fine as everything up top would be as original.
It really would not be a problem and would be the same as doing any other ZVH but you must run the RSi fly wheel and sensor (or something similar) for the coils to work.
Originally Posted by MattRS1600i
Like Kevs on the emerald Means junking all the K-Jetronic stuff tho too and adapting the existing, or making a new inlet manifold for suitable injectors.
Originally Posted by Jano_OddKidd
You could get a 16v working with twin coils and Mfi but whats the point?
Ask me a question!
Originally Posted by XR2
At least a ZVH looks like the original 1.6 RSi heart. If the compression ratio is just the same like on the RSi it should work
Dont worry about if it works or not, just make sure it looks right
DixieTheKid
11
06-06-2020 11:20 AM
