Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
130ps or 105ps.?
Old 09-09-2015, 10:10 PM
morg65
morg65's Avatar
Default 130ps or 105ps.?
Hi guys and thanks for the welcome.
I recently bought a mint 1992 MK5 Escort Cabriolet first registered in April 1992..
She moondust silver and on a J plate. She is the xr3i 1.8 16 valve.
All points to the 130ps version.Sticker on air intake says 130ps but that isn't a convincing way of being sure. Stickers can be changed.
has the MX75 gearbox with the need to pop up a ring to select reverse.
I first thought there was a problem with reverse and then felt like an idiot hehe when I realised I had to lift up the ring to select.
My problem is, I bought her and was told she is the 130ps version. But my understanding is that the 130 had disc brakes all round. On my cabriolet looks very like drums on the rear although I haven't taken a wheel off to confirm
Maybe only the 130 XR3i hatchbacks and not the Cabriolets had discs all round.? Any advice would be great. Thanks a bunch.
Morg.
Old 09-09-2015, 10:25 PM
cossiestu
cossiestu's Avatar
I had a 93 1.8si 130ps Cab, with MTX75 box, that had rear discs....
I think (and I may be completely wrong?!) the main difference, engine wise is the 130's have a bigger/different throttle body and different cams?
Old 10-09-2015, 05:05 AM
cos 4x4
cos 4x4's Avatar
Hi to identify if it's 105 of 130 you need go check the back of the inlet manifold if it's 130 if should have HO stamped on the inlet pipe closet to the drivers wing. Should have reAr disc brakes as well but they have an incorporated drum brake for the handbrake plus an mtx box. Also check code on ecu if it's 2fcd then it's a 105. Be aware that some 105 cars came with an mtx box and some have a bc box
cossiestu (10-09-2015)
Old 10-09-2015, 05:52 AM
Moderator
STeve's Avatar
alloy inlet on a 130 faces straight over the rocker with 90d bend to the right the normal versions have skinny air intake pipes and some sweep accross edge of rocker cover at 45d, should a,lso have wing back seats
Old 10-09-2015, 08:33 AM
morg65
morg65's Avatar
Thanks guys. Can I see the "HO" stamp on the rear of the inlet without taking it off.? Is it obvious.? It has a full leather interior with wing back seats. And its not the SI model its the XR3i which I believe was only made in 1992 for less than a year and then replaced by the SI. Car was originally based in the Isle of Wight for most of its life. Just wondering if the spec may have been different.
Old 10-09-2015, 12:22 PM
chris cdti
chris cdti's Avatar
I'm sure the ones with ABS has rear discs
Old 10-09-2015, 12:33 PM
Moderator
STeve's Avatar
and normally open rear qtr windows same as the cossie as well as upper front and lower front strut baces, I had a mk6 130 spec cabby that had rear discs chris
Old 10-09-2015, 12:42 PM
morg65
morg65's Avatar
Thanks guys. I suppose the only way to be sure is to check out the rear of the inlet to see if it says "HO"
How would I know if it has ABS.? It doesn't have a light on the dash. My previous MK5 had a yellow light that came on when the ignition was turned and the went off with a click a few seconds later. So is it possible if it doesnt have ABS then maybe drums on the rear.? Must say is there a huge difference in power between the two anyway.? She seems plenty fast for me anyway.
Old 10-09-2015, 01:18 PM
Moderator
STeve's Avatar
abs with drums its normal, its when it has discs at the rear it only has abs on fronts like what they do on the rs2000s
Old 10-09-2015, 02:57 PM
morg65
morg65's Avatar
Thanks again 1-PD.
Will check it out...I am concerned because I have ordered a complete stock exhaust for her. She had a really loud boy racer pipe on her and at 50 yo its embarrassing hehe.
I am hoping that the parts between the 105 and 130 are interchangeable...In short..Will the exhaust I ordered for the 130 spec be ok if she turns out to be a 105.?
Thanks again.
Morg.
Old 10-09-2015, 03:59 PM
Moderator
STeve's Avatar
the cat is different but from catback it should be the same
Old 10-09-2015, 07:43 PM
cos 4x4
cos 4x4's Avatar
Originally Posted by morg65
Thanks again 1-PD.
Thanks again.
Morg.
Have been breaking these for the past couple of years. No difference in cats and exhaust so nothing to worry about. Abs was an option and to tell if you have it you will have a separate ecu type module in the scuttle tray drivers side right behind the engine and a separate block under the brake servo. All 130 cars come with rear disc and drum brake
Old 11-09-2015, 11:14 AM
morg65
morg65's Avatar
Thanks a million guys for all your advice.
Yesterday I checked the rear of the inlet manifold and cam across " SO" so there ya go. She seems to be a 105. To be honest I wouldnt have known the difference in power. As a 105 shes quick enough for me.. Even if I had known when I looked at her she wasnt a 130 I still would have bought her. She is mint inside and out and sitting on 28 thousand miles..Spent most of her life in the Isle of Wight as far as I know. Only rust was the battery tray which has been replaced. She has the MX75 box and the full leather wing back interior.. So that little sticker on the inlet pipe duped me lol.
Old 11-09-2015, 01:36 PM
Fordmad!
Fordmad!'s Avatar
Be good to get some pics up! 130s are rare now all been broke for the engines. My mate had a red si went really well. The escort GTIS sgould of had the 130 engine in really
Old 11-09-2015, 02:01 PM
mattxr3i
mattxr3i's Avatar
130 spec engine will have RQB stamped on the head
Old 11-09-2015, 04:27 PM
cos 4x4
cos 4x4's Avatar
Thanks again 1-PD.
Thanks again.
Morg.
Old 11-09-2015, 08:05 PM
cos 4x4
cos 4x4's Avatar
Where on the head is it stamped?
Old 11-09-2015, 08:40 PM
mattxr3i
mattxr3i's Avatar
tezmanian devil
04-09-2009 05:23 PM
trevCOSS
30-07-2007 03:42 PM
robbyridz
27-05-2006 12:45 AM
mrviper
21
02-04-2005 01:58 PM
Quick Reply: 130ps or 105ps.?
