Polished Bliss: 09 Frozen White Focus RS...
Old 16-06-2009, 11:46 PM
Clark@Polishedbliss
Clark@Polishedbliss's Avatar
Default Polished Bliss: 09 Frozen White Focus RS...
Well after months of waiting and constantly juggling my weekends about to fit it in, my dads new RS finally arrived and I was able to get it detailed over the weekend.
The dealers had been instructed not to prep the car so it was a bit grubby from sitting about in various compounds etc. The dealership has to be given credit (Arnold Clark Aberdeen) as they were generally pretty good to deal with and they even had the car locked away in a private hand over bay upstairs for a week and a half while it was waiting to be registered - Some of the higher end dealerships we've had dealings with could learn a thing or two!
So in order to get as much dirt off the paint as possible I foamed it with R222 Citrus Degreaser @ 60 degrees:
This was repeated and then left to dwell for 5 mins:
Then rinsed off @ 60 degrees and high pressure:
The wheels were given a quick going over with Gloss-It wheel gel, however these were to be taken off during the detail anyways:
Arches and tyres were sprayed with Meguiars Super Degreaser and scrubbed:
Door shuts/petrol cap were sprayed and agitated with Meguiars APC (4:1)...
...Then pressure washed with medium pressure:
All exterior trim/badges were cleaned with APC:
A blade was used to remove the writing from the windscreen:
Although not exactly minging, the engine bay still needed a bit of a clean:
Again, APC was used to soak the engine bay:
Then it was rinsed at medium pressure @ 60 degrees:
The car was then washed with the two bucket method and R222 and then moved inside for claying.
There was no messing about at this stage - straight to Gloss-It Aggressive Clay Bar (most aggressive clay I've come across yet) due to the fact the car was completely covered in metal filings:
This is from the back window alone:
I changed to Megs quick clay for a minute just to show the level of contamination - this was from the top of the spoiler:
3 hours later and the paintwork and glass were squeaky clean so I put the car back outside for another wash then back in and dried.
This gave me the chance to try out one of our latest new products...
With 300 mile an hour hot air being produced it doesn’t take long to dry a car with one of these, especially when the paint is well protected -
goodbye leaf blower! :thumb:
Onto the paintwork itself:
Having inspected the car at the dealers last week I knew what I was facing and in all honesty I was a bit disappointed with the amount of defects present, especially as it hadn’t been prepped for handover.
Being white it was always going to be difficult to show the defects on camera but here's a few I got:
There was also the odd sanding mark and plenty of buffer trails too, not something I've seen on a new Ford before:
I'm sure some people reading this will think its a bit OCD'ish but it's a brand spanking new car - it shouldn’t have any defects.
Onto the polishing stage:
As usual, I started with a fairly light polish and pad combination and this actually worked really well, the paint was around the intermediate level in terms of hardness - no way near as hard as the Mk1 RS.
Meguiars 205 and a Menzerna Finishing Pad was used, spread at 900rpm's, moved up to 1200rpm's for 1 pass then ramped up to 1800rpm's with fairly heavy pressure and then backed down to 1500 then 1000rpm's with light pressure to refine:
Some of the deeper defects needed something a bit stronger so Menzerna 3.02 and a Menzerna Polishing Pad were used to remove these.
While I was doing the paint, Dad turned up to seal the wheels and hubs/calipers (Blackfire Metal Sealant) and to fit a set of mud flaps to the front (you can probably see where my car cleaning bug came from...):
Back to the paint:
Spoiler before:
After Menzerna FPII and a Menz 80mm finishing pad (the black plastics were much softer than the white paint so didn’t need so much cut to correct them):
The rear diffuser needed a 2 stage machine though as it was quite badly scratched. Menz 3.02 and a Gloss-It Light Cut pad was used first:
I then refined the finish with Menz FPII and a Gloss-It Finishing Pad:
Round the front now and again I used a Gloss-It Finishing Pad but swapped back to Meguiars 205 for a bit more initial cut:
Another Gloss-It pad was used for the side skirts, but this time a green polishing pad in conjunction with Menz 3.02 to remove the deeper buffer trails left from the production line:
Trails gone:
With the polishing all completed I used the new drier to blast away the majority of the polishing dust and then removed the rest with a lambswool duster:
A Top Inspection wipe down followed in order to fully remove all the polishing oils so the sealant could properly bond.
Sealant of choice was "Project Awesome" which was machined into the paint @ Speed 5 on the G220 with a Gloss-It Finishing Pad:
This was left for an hour to cure and then buffed off with a spritz of Ice cold Gloss-It Gloss Enhancing QD.
I was still feeling energetic so I applied some Concorso with a foam applicator by hand and left to cure while I did the other little details such as the tyres (Gloss-It Signature Tyre Dressing), Polished the tailpipes (Brilliant show metal polish), dressed the engine bay (303 Aerospace Protectant) and cleansed and protected the glass with the Werkstat System.
I then buffed off the Concorso and topped this with 2 coats of Werkstat Acrylic Trigger as this is what my dad will be using to keep protection topped up:
In between the curing of the 2 coats of Werkstat the interior was given a quick hoover and APC wipe down. The shuts were wiped down with Gloss-It QD:
With everything complete I just had to give the paintwork a final wipe down with Werkstat Acrylic Glos and then got the camera out for a few pics:
We initially put the car outside but it was approaching 10pm and the mist was coming down so the car didn’t really look anything special...
I'll have to get some sun shots at some point to do the finish justice
Car back inside
I still wasn’t that happy with the final pics so we took some more on the way home at ASDA where it looked a bit better
Total work time: 28 hours (4 of which were dad removing the wheels)
The car is now back in the garage awaiting the application of some paint protection film and then it shall be getting driven...hard :driver::thumb:
Thanks for reading, apologies for all the pics!
Clark
Old 16-06-2009, 11:55 PM
fezzajsy
fezzajsy's Avatar
looks awesome
Old 16-06-2009, 11:58 PM
Miller 3
Miller 3's Avatar
Wow look at that shine
well done fella
Old 17-06-2009, 12:53 AM
155lee
155lee's Avatar
cant believe its so messed up from new!looks great now!
Old 17-06-2009, 12:56 AM
Pardeep
PF's Guitar God!!!
Pardeep's Avatar
Fantastic Job Mate. 110% commitment. Best white RS i've seen.
Old 17-06-2009, 05:23 AM
Brian
Brian's Avatar
Brian
Old 17-06-2009, 05:54 AM
ROB7656
ROB7656's Avatar
top job!!!!
Old 17-06-2009, 06:15 AM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Wow, genuinely incredible work and such a shock to se how bad it actually is from new!
Old 17-06-2009, 06:32 AM
rstoughy
rstoughy's Avatar
Looks amazing Clark
Really really like the white ones
Now when did you say you were popping in past
Old 17-06-2009, 06:41 AM
cressy
cressy's Avatar
thats stunning mate i take my hat of to you picute of car now my background on pc
Old 17-06-2009, 07:02 AM
FOCUSTARD PIE
FOCUSTARD PIE's Avatar
Super job, looks stunning.
Shame your so far away.
Old 17-06-2009, 07:06 AM
JK12
JK12's Avatar
looks great! well done! how much would this cost to have a fiesta st done?
Old 17-06-2009, 07:12 AM
Twellsie
Twellsie's Avatar
top job looks stunning
Old 17-06-2009, 07:37 AM
H7 CYA
H7 CYA's Avatar
Wow what a huge transformation, excellent work!!!
Old 17-06-2009, 07:56 AM
kev 3dr
kev 3dr's Avatar
Absolutley amazing and my favouite colour too
Old 17-06-2009, 07:57 AM
Bullseye224
Bullseye224's Avatar
christ on a bike and 12 apostles in a minibus, that is mental!
Old 17-06-2009, 08:39 AM
smila
smila's Avatar
thats how you clean a car top work mate
Old 17-06-2009, 09:00 AM
MikeR
MikeR's Avatar
Saw this on the MLR as well, it looks fantastic, it is a great shame they arrive in that poor condition new,
Clarke what is the cost for a service like this?
Mike
Old 17-06-2009, 09:24 AM
Coldo
Coldo's Avatar
Amazing looking cars, dont know how anyone can say otherwise. Top job.
Old 17-06-2009, 09:41 AM
shaney t.
shaney t.'s Avatar
Default top job
awesome work mate i done some valeting in my time but nothing like that hats off to ya.
Old 17-06-2009, 11:28 AM
Rich_bloor
rich_bloor@hotmail.com
Rich_bloor's Avatar
hang on a min,
if i was buying a brand new car, i would expect it to turn up looking like this 1 !!!
How does a brand new car get so dirty? EVEN the engine? the focus RS has just been released, so its not like its been standing round for ages cos they cant sell em !!!
Old 17-06-2009, 01:50 PM
rstirl
rstirl's Avatar
amazing work. the finish is incredible.
Old 17-06-2009, 02:10 PM
Tom_Cortina
Tom_Cortina's Avatar
thats detaling to another looks ace when you coming to do mine
Old 17-06-2009, 04:49 PM
Gav Diamond
Gav Diamond's Avatar
Awesome work as always Clark
Bet your dads well happy with that
Old 17-06-2009, 06:16 PM
tregmatt
tregmatt's Avatar
thats amazing mate i just love it
Old 17-06-2009, 06:27 PM
RS Juto
RS Juto's Avatar
That cars nice and your work is a credit to you.
Can i just ask does the bumpers and side skirts match the car, the reason i ask my mate has a green one at the dealers and he has refused delivery because the paint on the bumpers etc is that diffrent from the body. Just wondering if ford had got the white ones right
Old 17-06-2009, 06:32 PM
gramsey
gramsey's Avatar
WOW amazing job. well done mate
how much would something like that cost??
Old 17-06-2009, 08:35 PM
RS2000WRC
RS2000WRC's Avatar
I could spend hours looking at threads like this!
it came out really well!
I got a question, when snowfoaming the car whats the sheet under the car for?
Old 17-06-2009, 09:25 PM
Robs Frst
Robs Frst's Avatar
looks really nice, much better
Old 17-06-2009, 09:47 PM
gra1984
gra1984's Avatar
I got to say when i started reading the thread i thought why the hell are you detailing a brand new car!!! but it just goes to show how dirty it really was!!!! fair play to you mate, thats dedication for ya!! i would love to get into doing detailing for a living. top work
Old 18-06-2009, 02:25 PM
Polished Bliss
Official Car Care Sponsor
Polished Bliss's Avatar
Mike
Between Ł695 + VAT and Ł995 + VAT depending on whether two or three working days would be required. The above took 24 hours of labour over two long weekend days, so it would have been a three job at the higher rate had it been a weekday job.
Old 18-06-2009, 04:36 PM
Mike Kerbey
Mike Kerbey's Avatar
top man! although the car is being let down by the dust on my computer screen lol
Old 18-06-2009, 11:09 PM
rs200boy
rs200boy's Avatar
bugger me thats clean hats off to you chap job well done
Old 18-06-2009, 11:53 PM
M7 COS
M7 COS's Avatar
Amazing!
Awesome job fella! Well done!
Old 19-06-2009, 01:51 PM
kosienutter
Last Time, Get Off PF FFS
kosienutter's Avatar
the guys at the production line should take a look at this thread. tip top work.
Old 19-06-2009, 10:03 PM
hunterlaar
hunterlaar's Avatar
Stunning, amazing work mate!!
Old 20-06-2009, 05:17 PM
SiST
SiST's Avatar
Absolutely amazing work!
Old 21-06-2009, 08:02 AM
pee vee
pee vee's Avatar
28 HOURS of work needed on a brand new car?! fook. you'd be all month on mine
does look very very nice though!
Old 21-06-2009, 08:35 AM
neil andeRSon
neil andeRSon's Avatar
dunno what it is with ford but we've had a few brand new ford's in at work getting bit's painted on them and there covered in grinding spark's aswell. one was a white kuga. the thing was fookin covered.
gotta say tho that is looking amazing now!!
Old 21-06-2009, 01:06 PM
BRAMMER
BRAMMER's Avatar
fantastic finish on that paint work
Quick Reply: Polished Bliss: 09 Frozen White Focus RS...
