Alpine CDE 103BT Mp3 bluetooth stereo
Old 25-06-2015, 12:17 PM
Moderator
STeve's Avatar
Default Alpine CDE 103BT Mp3 bluetooth stereo
In good used condition cames with microphone, harness & cage works as its should
£50 postage is available at extra cost
CDE-103BT - Bluetooth® CD RECEIVER / USB AND iPod® CONTROLLER
FEATURES
Tuner
Memory Presets: Preset Stations (FM:12 / MW:6 / LW:6)
Memory: Auto Memory
Seek Mode: Local / DX Selection
RDS
RDS Functions: TA, TP, RADIO TEXT
Bluetooth®
Built-In or Ready: Built-In Parrot Bluetooth® module
Hands Free: Hands Free Calling
Phone Book: Phone Book Transfer
Microphone: Microphone Included
Connection for iPod®
Connection Type: Full Speed™ Connection
Connection: Full Speed™ Cable (Required KCE-433iV)
Source Type: Dedicated iPod® Source
Compatibility for iPod®: iPod® 5th generation, iPod® nano 1st/2nd/3rd/4th generation, iPod® classic, iPod® touch 1st/2nd generation
Works with iPhone: Works with iPhone
M.I.X. (Shuffle) Capability: Song, Albums, All
Music Control: Song Up / Down / Repeat
Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer, Audiobook
Percentage Search: Percentage Search
Information Display: Artist, Song, Album
Easy Navigating: Quick Search
Disc Player
Disc Type: CD Player
Disc Playback Type: CD/CD-R/CD-RW
Music Playback: MP3/AAC/WMA Playback
DAC: 1Bit DAC
Zero data Mute: 0 Bit Mute
Digital Servo: Digital Servo
Sensor: Music Sensor Scan/Repeat
Playback Control: Play/Pause/Forward/Backward
M.I.X. Mode: One (Folder)/All (Random Play)/Random (CD Only)
USB Media Connection
USB Connection: Front Panel Input
Sound Tuning
Subwoofer Level: Subwoofer Level Adjustment
High Pass Filter: High Pass Filter Adjustment
Bass Level: Bass Level Adjustment
Bass Center Frequency: Bass Center Frequency Adjustment
Bass Width: Q Adjustment
Treble Level: Treble Level Adjustment
Treble Center Frequency: Treble Center Frequency Adjustment
Loudness: Loudness Feature
General
Power Output: 4 x 50 W High Power Amplifier
Display: White LCD (14 Segment)
Control Type: Rotary Encoder Knob
Face Color: Black
Illumination Buttons: Green / Amber / Blue / Red Illuminated Buttons
PreOut: 2 PreOuts (2 V )
AUX-In: Front AUX Input (3.5mm mini jack) / Full Speed AUX + (Required KCE-237B)
Steering Wheel Remote Control: Steering Wheel Remote Control Ready
Bass & Treble: Bass & Treble Controls
Fader & Balance: Fader & Balance Controls
DIN Trim Plate: Detachable Trim Plate
Detachable Face Plate: Detachable Face Plate
Dimmer: Dimmer Input
Power Antenna Lead: Power Antenna Output
Remote Turn-On: Amplifier Remote Turn-On Output
Audio Interrupt: Audio Interrupt Input
SPECIFICATIONS
Max Power Output Ratings
Max Power Output: 4 x 50 W
FM Tuner
Tuning Range: 87.5-108.0 MHz
Mono Usable Sensitivity: 0.7 µV
Alternate Channel Selectivity: 80.0 dB
Signal-to-Noise (S/N) Ratio: 65.0 dB
Stereo Separation: 35.0 dB
Capture Ratio: 2.0 dB
MW Tuner
Tuning Range: 531-1,602 kHz
Usable Sensitivity (IEC Standard): 25.1/28.0 (µV/dB)
Bluetooth®
Bluetooth® Version: Bluetooh 2.0 CERTIFIED
Output Power: +4 dBm Max. (Power class 2)
HFP: (Hands-Free Profile)
HSP: (Head Set Profile)
Connection for USB
USB Requirements: 1.1/2.0
Max. Power Consumption: 500 mA
USB Class: Mass Storage
File System: FAT 12/16/32
MP3 Decoding: MPEG-1/2 AUDIO Layer-3
WMA Decoding: Windows Media™ Audio
AAC Decoding: ACC-LC format/m4a file
Number of Channels: 2-Channel (Stereo)
Frequency Response: 5-20 k ±1 dB (Frequency Response may differ depending on the encoder software/bit rate)
Total Harmonic Distortion: 0.008% (at 1 kHz)
Dynamic Range: 95 dB (at 1 kHz)
Signal-to-Noise Ratio: 105 dB
Channel Separation: 85 dB (at 1 kHz)
Disc Player
Channel Separation (1kHz): 85dB
Dynamic Range (1kHz): 95 dB
Total Harmonic Distortion (THD): 0.008% (at 1 kHz)
DAC Type: 1 Bit
Wow & Flutter (%WRMS): B.M.L.
Oversampling: 8x/352.8 kHz
Audio Signal-to-Noise (S/N): 105 dB
Sound Tuning
Subwoofer Level Adjustment: 0 to 15
High Pass Filter: OFF/60/80/100Hz (Selectable)
Bass Level Control Range: ±14
Bass Center Frequency: 60/80/100/200Hz (Selectable)
Bass Band Width Adjustment (Q): 4 choices (1 =narrow, 4 =wide)
Treble Level Control Range: ±14
Treble Center Frequency: 10/12.5/15/17.5kHz (Selectable)
Dimensions
Din Size: 1
Chassis Size (W x H x D) mm: 178 mm x 50 mm x 161 mm
Nose Piece Size (W x H x D) mm: 170 mm x 46 mm x 25 mm
General
Power Requirement: 14.4 (11-16) V.DC
Pre Output Voltage (Before Clipping): 2 V
Operating Temperature (°C): 60°C to -10°C
Maximum Mounting Angle: 35° from Horizontal
Weight: 1.5 kg
STeve is offline
Old 26-06-2015, 05:20 AM
Moderator
STeve's Avatar
Sold sold sold
STeve is offline
stevecfrst1
30-09-2015 05:18 AM
S3an
26-09-2015 11:39 PM
Kam B
24-09-2015 10:40 AM
STAFFY OWNER
18
21-09-2015 02:50 PM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: Alpine CDE 103BT Mp3 bluetooth stereo
